Gavinmc42
Re: FreeCAD on PI4 and Raspbian Buster.
Sat Aug 24, 2019 12:41 am
I got OpenSCAD to work in Gentoo64.
Under Buster I had similar errors on compiling OpenSCAD as the FreeCAD errors.
Coin3D emerged ok on Gentoo64.
Just wondering if it might be a 32/64bit issue?
Not sure if FreeCAD runs on Gentoo x86 32bit?
Are there any 32bit Linux's around for x86?
No ebuild for Arm8 version, so it must be done the hard way :(
emerge: there are no ebuilds to satisfy "freecad".
Is there a way to test coin3d without FreeCAD?
Google time
I'm dancing on Rainbows.
clicky
Thu Aug 29, 2019 3:48 pm
Just to keep this thread alive - I've picked the latest from git and compiled it as on https://www.freecadweb.org/wiki/CompileOnUnix and without any errors. Of course it didn't do me any good as it fails in exactly the same way as pre-packaged version...
Any news on finding the winning combination?
ShiftPlusOne
Thu Aug 29, 2019 3:50 pm
Not until this coin3d issue is fixed - https://freecadweb.org/tracker/view.php?id=4083
Gavinmc42
Fri Aug 30, 2019 1:41 am
I have been getting a "segmentation fault" error on other apps when compiling and running on Gentoo64.
Linux Combat Simulator compiles, runs and then crashes with "seg fault".
What is common? OpenGL?
But there is massive libraries and dependencies in both.
What does "segmentation fault" mean?
google time
kkremitzki
Sat Oct 12, 2019 12:39 am
Hello all, I just wanted to give an update. I've finally got my Raspberry Pi 4—this thing is amazing! After some further troubleshooting, we've hit a dead end on fixing the segmentation fault problem. However, it looks like it isn't present when FreeCAD is built with the Python 2, Qt 4 configuration. So, my plan is to provide a diff of the debian (packaging) tarball to Raspbian maintainers which will change the build rules and possibly some of the install manifests, and once that is applied and a new package built and uploaded to the archive, then people will for sure be able to start running FreeCAD on RPi4's. Woohoo!
After I get that diff prepared I can continue troubleshooting the Python 3, Qt 5 build.
Gavinmc42
Sat Oct 12, 2019 5:09 am
I have run into seg faults during compiles etc when Pis runs out of memory.
Happens on Pi3's and smaller 4's.
Not sure if it is GPU/CPU memory clash, but that is my theory at the moment.
Need to make it repeatable before I can say that with more confidence.
Buster seems worse than Gentoo64 for seg faults too.
My current Pi4 stress test is Buildroot.
Don't think I have tried making FreeCAD on my new Pi4B4, the older 1 and 2GB ones did not work.
For big compiles the 4GB Pi4 is best or the 2GB one without desktop.
Some stuff will compile on the 1GB 3,4's it I have a 1GB swap file.
roweder
Thu Jan 09, 2020 5:39 pm
Any updates? I have 2 Pi 4B4s, one running raspbian and the other running OctoPi, both running with the latest updates. I recently installed FreeCAD on both Pi 4B4s and I'm having the exact same problem as OP. I installed with just
sudo apt install freecad
Gavinmc42
Fri Jan 10, 2020 5:10 am
Have not heard of any progress yet.
I might have to learn how to fix it myself ;)
Jeepsterjc
Tue Jan 28, 2020 1:57 am
No luck here... So🍿
Gavinmc42
Tue Jan 28, 2020 3:07 am
Time to try again?
Mesa 19.3.2 is out, but I think from memory it was coin3d, qt5 or python issues?
Reading my old posts I don't think I tried compiling on the 4GB Pi4.
"Segfaults" is something I have run into since then, they seemed to be memory related in some cases.
Yikes, those links show a complex set of problems.
Yep pull up a chair , grab the popcorn and let the experts figure it out.
Diablo2_Fan
Thu Feb 13, 2020 7:59 pm
Hello and thank you!
Is the RPI4 maybe incompatible or is the work still in progress?
Gavinmc42
Fri Feb 14, 2020 1:23 am
I tried again with newer Mesa 3D driver on the weekend.
Same problem and the forum posts suggest it is a dependency issue.
Python has moved to 3 now and that affects things too.
Investigate Coin3D?
It takes some time to figure this stuff out.
clicky
Fri Feb 14, 2020 9:46 am
If you are after it - it is definitively worth reading instructions in this thread and building it on your own.
Diablo2_Fan
Fri Feb 14, 2020 1:00 pm
Maybe someone from the raspberry-team has more informations?
kkremitzki wrote he provide a diff tarball to the raspbian maintainers.
clicky
Fri Feb 14, 2020 1:14 pm
My fault - I misread which thread I was posting in. There *is* a winning combination - see here:
viewtopic.php?f=63&t=253367&p=1551336#p1551336
Diablo2_Fan
Fri Feb 14, 2020 10:28 pm
Many thanks clicky, maybe I will try to compile it now with Py2/Qt4.
scruss
Sat Feb 15, 2020 10:43 pm
Can confirm its builds and runs well enough to get started on some simple tutorials.
I used a slightly modified version of MartijnD's method to build 0.18.4. Some of Martijn's paths aren't valid any more on an up-to-date Buster system.
I built this on a Raspberry Pi 4 with 4 GB of RAM. It takes quite a bit of free storage: I wouldn't attempt to build this with less than 4 GB free. make -j4 takes 95 minutes, and even with a fan my Raspberry Pi 4 was at 70°C.
sudo apt install cmake build-essential libtool lsb-release swig libboost-dev libboost-date-time-dev libboost-filesystem-dev libboost-graph-dev libboost-iostreams-dev libboost-program-options-dev libboost-python-dev libboost-regex-dev libboost-serialization-dev libboost-signals-dev libboost-thread-dev libcoin-dev libeigen3-dev libgts-bin libgts-dev libkdtree++-dev libmedc-dev libopencv-dev libproj-dev libvtk6-dev libx11-dev libxerces-c-dev libzipios++-dev qt4-dev-tools libqt4-dev libqt4-opengl-dev libqtwebkit-dev libshiboken-dev libpyside-dev pyside-tools python-dev python-matplotlib python-pivy python-ply python-pyside libocct*-dev occt-draw libsimage-dev doxygen libcoin-doc dh-exec libspnav-dev
wget https://github.com/FreeCAD/FreeCAD/archive/0.18.4.zip
unzip 0.18.4.zip
rm 0.18.4.zip
mkdir freecad-build
cd freecad-build
cmake -DPYTHON_EXECUTABLE=/usr/bin/python2.7 -DPYTHON_INCLUDE_DIR=/usr/include/python2.7 -DPYTHON_LIBRARY=/usr/lib/arm-linux-gnueabihf/libpython2.7.so  -DPYTHON_PACKAGES_PATH=/usr/local/lib/python2.7/dist-packages/  ../FreeCAD-0.18.4/
make -j4
Yes, it's using Python 2.7, but it works. I've got no idea how to make it install properly, but it runs from the freecad-build/bin directory.
Return to “Raspbian”
