THX1182
Re: Trouble Getting HDMI Output From RPi4
Tue Nov 05, 2019 7:51 pm
THX1182 wrote:
Tue Oct 29, 2019 8:23 pm
I've been having issues with hdmi as well, basically tried everything I could find, but nothing seems to resolve the issue...
(Swapping cables, config.txt editing, reinstalling, new Power supply)
The Pi loses connection with my TV for two seconds, after playing media of any kind... I think it's hdmi audio related, because it does not happen with analogue audio.
Here's a video of what's happening:
https://imgur.com/gallery/n2bRnWE
These are some of the outputs of tvservice:
1 attached device(s), display ID's are :
Display Number 2, type HDMI 0
HDMI events what happens after media is played:
Starting to monitor for HDMI events
HDMI cable is unplugged. Display 2
HDMI is attached
HDMI is attached
state 0xa [HDMI CUSTOM RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
Audio information:
PCM supported: Max channels: 2, Max samplerate: 48kHz, Max samplesize 16 bits.
AC3 supported: Max channels: 6, Max samplerate: 48kHz, Max rate 640 kb/s.
DTS supported: Max channels: 2, Max samplerate: 48kHz, Max rate 640 kb/s.
Not to hijack this thread but since the raspi team is looking into "hdmi problems", i decided to link my thread here before my thread dies.
Here's a link to my original thread:
https://www.raspberrypi.org/forums/view ... 5#p1558785
Hope that my issue falls under the "hdmi issues", that the developers are looking at, because this has been driving me crazy for weeks now.
Well i ended up buying a usb audio adapter, and a good rca cable to "fix" my issue... It's completely bonkers when you think of it, every hdmi machine I have functions normally with my tv... (Sharp Aquos).
I understand the Pi team have thousands of issues to fix, but a simple sorry we can't resolve your issue would have been nice.
Anyways keep up the great work!
dominic03
Thu Dec 26, 2019 9:38 pm
My Raspberry Pi 4 that I got yesterday has no output from HDMI 0 when using PINN, unless I leave it unplugged and plug it in after the Pi starts up. Then I get very low resolution video, with messed up colors. Note that if it is plugged in while booting, HDMI 0 gives a black screen while HDMI 1 gives 'No Signal'.
I checked the HDMI cable with another HDMI 1080p device, and it works perfectly fine on it.
Any suggestions on what to try?
By the way, HDMI 1 works just fine, but is not compatible with PINN.
Edit: I got the output to work, I don't know how, but I get weird corruption/ interference. I tried adjusting hdmi_boost but it doesn't help.
Edit 2: Working fine with the cable in a certain position, guess it is a cable problem. Never buy cheap HDMI cables!
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
procount
Fri Dec 27, 2019 12:16 am
If your HDMI cable connections are flaky, the RPi is probably not reading the monitor EDID information reliably.
In this case you can force a particular resolution by adding the following to config.txt on the PINN partition (create it if it doesn't exist):
hdmi_ignore_edid=0xa5000080
hdmi_group=2
hdmi_mode=28
Change the hdmi_group and hdmi_modes to suit your monitor.
dominic03
Fri Dec 27, 2019 12:25 am
hdmi_group=2
hdmi_mode=28
Can I use custom CVT modes?
-or-
procount
Fri Dec 27, 2019 12:33 am
Of course.
