ronnih
Re: Buster bug report thread - Capture Sound
Mon Oct 07, 2019 7:58 pm
Microphone is not working in Browser pre-installed Chromium and Firefox. But the Sound capture works with audacity
I tried to record sound with a USB Webcam.
lsusb
Bus 001 Device 005: ID 041e:4088 Creative Technology, Ltd Live! Cam Chat HD [VF0700]
andrea.varesio
Tue Oct 08, 2019 12:37 pm
Update:
I tried the 26 sept 2019 buster release - same behavior
I tried removing the edimax wifi dongle and performing a ifdown / ifup on wlan0 that is using the internal wifi of PI 3B+ at it works.
I ll try with another dongle, in order to determine if it is a Edimax driver related issue.
Andrea
hippy
Sat Oct 12, 2019 12:02 pm
Oops: 5 [#1] ARM - Pi Zero W, Buster
Linux Pi0W-DPF 4.19.66+ #1253 Thu Aug 15 11:37:30 BST 2019 armv6l GNU/Linux
Message from syslogd@Pi0W-DPF at Oct 12 12:43:13 ...
 kernel:[ 1233.157249] Internal error: Oops: 5 [#1] ARM
 kernel:[ 1233.314921] Process modprobe (pid: 1944, stack limit = 0xd7455885)
 kernel:[ 1233.323508] Stack: (0xd69fdd88 to 0xd69fe000)
 kernel:[ 1233.330470] dd80:                   d92f5740 00000000 dc800000 00000001 dc813000 00000000
 kernel:[ 1233.343636] dda0: 00000001 dc800000 c015fb5c 24ace29e c06c18f4 00013000 00000022 006000c0
 kernel:[ 1233.356483] ddc0: 00000001 dc800000 d743da20 d9334460 d69fde0c d69fdde0 c014e480 c014e000
 kernel:[ 1233.369125] dde0: ffffffff 006000c0 00011488 ffffffff ffffffff d69fdf24 006000c0 00000000
 kernel:[ 1233.382030] de00: d69fde4c d69fde10 c014f528 c014e3e0 ff800000 ffffffff 006000c0 c017b1b0
 kernel:[ 1233.395010] de20: d76f8680 c017b1b0 ffffffff c09e9028 d69fdf24 7fffffff 00000000 d9334460
 kernel:[ 1233.408403] de40: d69fde7c d69fde50 c014f734 c014f4cc 006000c0 0000024f 00000000 ffffffff
 kernel:[ 1233.422402] de60: c017b1b0 00000000 00011488 00000000 d69fde94 d69fde80 c014f780 c014f6ec
 kernel:[ 1233.436137] de80: ffffffff c017b1b0 d69fdedc d69fde98 c017b1b0 c014f750 d69fdec4 d69fdf28
 kernel:[ 1233.450065] dea0: b6fa5000 00000002 00000001 24ace29e 00000071 d9334460 d9334460 d69fdf28
 kernel:[ 1233.464203] dec0: d69fdf24 7fffffff 00000000 00000000 d69fdf0c d69fdee0 c017b2cc c017aff8
 kernel:[ 1233.478287] dee0: 7fffffff 00000000 00000003 c002d260 c09e9028 00000000 00000003 0002d064
 kernel:[ 1233.492431] df00: d69fdfa4 d69fdf10 c0092df4 c017b288 7fffffff 00000000 00000003 00000000
 kernel:[ 1233.506541] df20: 00000000 d69fdf24 d69fdf24 24ace29e 00000000 00000000 00000000 00000000
 kernel:[ 1233.520584] df40: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
 kernel:[ 1233.534648] df60: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 24ace29e
 kernel:[ 1233.548831] df80: 2c452400 00000000 00000000 0000017b c00091a4 d69fc000 00000000 d69fdfa8
 kernel:[ 1233.563010] dfa0: c0009000 c0092d88 2c452400 00000000 00000003 0002d064 00000000 01000200
 kernel:[ 1233.577199] dfc0: 2c452400 00000000 00000000 0000017b 010001b8 00000000 01000200 00000000
 kernel:[ 1233.591332] dfe0: be936958 be936948 00022cb8 b6ce8af0 60000010 00000003 00000000 00000000
 kernel:[ 1233.761082] Code: ea00000b e5922018 e1520008 0a000045 (e5121018)
ejolson
Sat Oct 12, 2019 4:16 pm
Is the oops immediately during boot?
hippy
Sat Oct 12, 2019 6:34 pm
No. It was while, or after, doing a 'cat /sys/devices/platform/soc/20980000.usb/gadget/lun0/file" while a background process was possibly modprobing, installing or removing, g_mass_storage.
hippy
Sat Oct 12, 2019 9:26 pm
Also, after an apt-get update/upgrade I then got the following from my background program -
sudo modprobe -r g_mass_storage
modprobe: ERROR: ../libkmod/libkmod.c:586 kmod_search_moddep() could not open moddep file '/lib/modules/4.19.66+/modules.dep.bin'
Presumably because it hadn't yet rebooted, and a reboot seems to have fixed things.
I really do wish apt-get would report when a reboot was necessary because I'd have hated to have had to debug that issue in a couple of days time when I wouldn't have so quickly related the issue to an upgrade and not having rebooted.
pfletch101
Mon Oct 14, 2019 1:09 am
For this and other reasons, I have got into the habit of always following an apt update/upgrade with a reboot. I recommend this habit!
Shadow_7
Sat Oct 19, 2019 11:29 pm
On a RPi 4b 4GB, after update, when I reboot with the monitor plugged in, there's overscan (underscan?). Resulting in a non-native resolution with a large black border where pixels should be. IF I boot with the screen unplugged from HDMI, this is NOT an issue. But if I boot with the screen plugged in, it IS an issue.
When it IS and IS NOT an issue.
$ xvidtune -show
"1920x1080" 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync
extracted from /home/pi/.local/share/xorg/Xorg.0.log
booted when plugged in...
[    17.857] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:1920x1080M@60,margin_left=48,margin_right=48,margin_top=48,margin_bottom=48 ...
booted when NOT plugged in...
[    21.172] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 cma=64M cma=256M video=HDMI-A-1:640x480M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0 ...
Seems like that's the offending line. 48px *2 for borders seems about right from what I'm seeing. Seems like it should be =0 for both on my system. I've never edited anything in /boot/ outside of the initial install and updates. Starting from noobs.
jazzgeek
Wed Oct 23, 2019 3:48 am
thatchunkylad198966 wrote:
Thu Jul 11, 2019 6:44 pm
Ectra wrote:
Thu Jul 11, 2019 12:25 pm
I have found two issues so far.
First is that YouTube stutters heavily in chromium although I believe it is a known issue and there's a patch on the way. Any updates on that would be appreciated!
Second is with VLC using a Bluetooth headset. An mp4 will only play the first half a second of sound before going silent. If I jump forward, unpause etc I get another short burst before silence. Issue doesn't exist on analogue audio nor when sound is played via browser etc. I am not sure if this should be raised to vlc instead.
The "fix" for Chromium is out; not sure about the VLC problem though, I don't use it; I either use MPV or Kodi.
Hi to all,
i am new here and a newbe to Raspberry 3 B+ and linux , so please bear with me ;)
Issue : stuttering HDMI audio in chromium when trying to stream any video sites :youtube, dailymotion, etc
My installation is Raspbian Buster Lite 10 with manual raspbian RPD desktop installation and only minimum packages installed , maybe i am missing some package that is required for a smooth audio playback ?
What is the chromium "fix" mentioned above?
thanks in advance for replies.
JazzGeek
Raspberry Pi 3 B+ / Raspbian Buster Full
c4y
Wed Oct 23, 2019 3:40 pm
$ xvidtune -show
You can enter
 video=HDMI-A-1:1920x1080M@60,margin_left=0,margin_right=0,margin_top=0,margin_bottom=0
on the end of your /boot/cmdline.txt (no new line just one single line).
I had the same, this fixes it. I have now my 'whole' screen back. :D
You can check this afterwards with
 journalctl | grep HDMI
dchao99
Mon Nov 04, 2019 12:30 am
LXPanel 0.10.0 regression bug
I have a virtual interface uap0 of type __ap.
In dhcpcd.conf I added:
denyinterfaces uap0
So the dhcpcd can ignore this interface.
In the past (0.9.xx), this setup used to work correctly.
However, in 0.10.0, LXPanel now reports "Wi-Fi country not set", in fact it is already set in wpa_supplicant.conf. And if I click the set country button, it won't let me set it now.
Thanks!
jazzgeek
Wed Nov 06, 2019 10:15 pm
Hi to all,
JazzGeek
the audio fix update :
i have installed Raspbian Buster Full instead of Lite + GUI and it fixed the sound in youtube , no more audio stuttering.
Shadow_7
Thu Nov 14, 2019 1:15 pm
I fixed it by modding /boot/config.txt
overscan_left=-48
overscan_right=-48
overscan_top=-48
overscan_bottom=-48
hdmi_drive=2
With hdmi_drive=2 to enable HDMI audio. Although my primary audio is pulseaudio over the network (less resource intensive on the client machine(s)). Oddly setting those all to 0 didn't fix it. Not sure if -48 will break it again on the 2nd reboot. But the 1st one was fine, technically 2nd since =0 didn't fix it.
sinnlos
Fri Nov 15, 2019 3:48 pm
The installation of squirrelmail is in a fully updated (and not unstable) Raspbian Buster because of unmet dependencies not possible. In the repositories only php7.x is offered, which doesn't resolve that dependency.
:~# apt install squirrelmail
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have requested an impossible situation or if you are using the unstable distribution that some required packages have not yet been created or been moved out of Incoming. The following information may help to resolve the situation:
squirrelmail : Depends: libapache2-mod-php5 but it is not installable or php5 but it is not installable or php5-cgi but it is not installable
Recommends: squirrelmail-locales but it is not going to be installed
Recommends: squirrelmail-viewashtml but it is not going to be installed
Recommends: php5-mhash but it is not installable
Recommends: ispell but it is not going to be installed or aspell but it is not going to be installed or aspell-bin
E: Unable to correct problems, you have held broken packages.
Fri Nov 15, 2019 6:36 pm
It looks like Squirrelmail got dropped by Debian after Jessie. I can't see an obvious reason for that other than it relied on outdated software.
I don't know why the old version is still in Raspbian.
plugwash
Sat Nov 16, 2019 3:15 am
It seems that the main reason for it's removal in Debian was the lack of php 7 support.
Because we don't automatically remove packages that debian removes (probablly we should, but there are some complicating factors) and we don't check installability for arch all packages (because there are many arch all packages in debian that are uninstallable on some architectures). So stuff like squirrelmail doesn't get picked up.
I have just removed squirrelmail from raspbian buster and bullseye.
yan
Sat Nov 16, 2019 7:57 pm
Ι install few updates 1 hour ago, it was something about the desktop because during the install it ask me to choose a desktop setting from Desktop preference after the reboot. Maybe pipanel, i don t remember very well.
Now, every time i try to open the file manager the screen is flashing and file manager close.
I install the updates to a second SD card that i have for backup and i have the same symptom's.
(Raspberry PI3, Rasbian Buster/Noobs Lite 3.2)
Edit: I run
sudo apt-get dist-upgrade
and the problem solved.
Botspot
Mon Nov 18, 2019 9:11 pm
Using VLC to play a video in fullscreen: Good until another window/dialog box pops up in front of the VLC window.
Since the fullscreen video is actually an overlay, the video still covers the screen, but now the VLC window is not "focused", meaning the video is uncontrollable from the keyboard.
This has happened to me more than once...
My doctor told me my brain is as useful as a Raspberry Pi. Is that a compliment?
yan
Tue Nov 19, 2019 6:24 pm
After the last updates it is not possible to umount a usb drive(fat32 or ntfs). I am clicking the eject button, the message appear in the corner, but the drive is still mount.
Linux raspberrypi 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
ShiftPlusOne
Tue Nov 19, 2019 6:55 pm
How have you determined that it's still mounted?
Botspot
Tue Nov 19, 2019 7:01 pm
I tried to use lxhotkey to add some keyboard shortcuts. It didn't work. After investigation, I discovered that lxhotkey modifies /home/pi/.config/openbox/rc.xml, but openbox ignores these changes since it uses /home/pi/.config/openbox/lxde-pi-rc.xml.
Solution:
Make /home/pi/.config/openbox/rc.xml a symlink of /home/pi/.config/openbox/lxde-pi-rc.xml. I used these 2 commands:
rm /home/pi/.config/openbox/rc.xml
ln -s /home/pi/.config/openbox/lxde-pi-rc.xml /home/pi/.config/openbox/rc.xml
yan
Tue Nov 19, 2019 8:19 pm
It was possible to access the usb drives after the umount. Also, i run lsblk in the terminal and the devices are still mounted.
pi@raspberrypi:~ $ lsblk
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
sde           8:64   1 14.9G  0 disk
└─sde1        8:65   1 14.9G  0 part /media/pi/RETRO_USB
sdf           8:80   1 14.9G  0 disk
└─sdf1        8:81   1 14.9G  0 part /media/pi/NX2
I try to umount the drives (fat32 and ntfs) from the terminal :
pi@raspberrypi:~ $ umount /media/pi/RETRO_USB
Error unmounting block device 8:65: GDBus.Error:org.freedesktop.UDisks2.Error.DeviceBusy: Error unmounting /dev/sde1: target is busy
pi@raspberrypi:~ $ umount /media/pi/NX2
Error unmounting block device 8:81: GDBus.Error:org.freedesktop.UDisks2.Error.DeviceBusy: Error unmounting /dev/sdf1: target is busy
ShiftPlusOne
Tue Nov 19, 2019 8:31 pm
yan wrote: the message appear in the corner, but the drive is still mount.
What does the message say?
yan wrote:I am clicking the eject button
Which one?
yan wrote:It was possible to access the usb drives after the umount.
Access how? I'd just like to make sure you're not clicking the device in the file manager and mounting it again.
yan
Tue Nov 19, 2019 8:46 pm
ShiftPlusOne wrote: What does the message say?
SanDisk Cruziel Glide 3.0 has been ejected
it is now safe to remove the device
ShiftPlusOne wrote: Which one?
The eject button in the taskbar
ShiftPlusOne wrote: Access how? I'd just like to make sure you're not clicking the device in the file manager and mounting it again.
I can access the drive from the desktop shortcut and from the terminal.
ShiftPlusOne
Tue Nov 19, 2019 9:20 pm
Return to “Raspbian”
