gordon77
sudo pip3 install opencv-python fails...
Mon Jun 24, 2019 2:32 pm
using latest Raspbian...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting opencv-python
  Could not find a version that satisfies the requirement opencv-python (from versions: )
No matching distribution found for opencv-python
Anyone know /explain why ?
ben_nuttall
Re: sudo pip3 install opencv-python fails...
Mon Jun 24, 2019 4:52 pm
opencv don't release soirce distribution to PyPI, so there's nothing to build.
The only reason it's been available recently is that the piwheels project builds it from github and releases it.
We haven't built opencv for Buster yet. You'll have to be patient.
Ref:
https://pypi.org/project/opencv-python/
https://www.piwheels.org/project/opencv-python/
https://blog.piwheels.org/raspberry-pi- ... an-buster/
Community Manager - Raspberry Pi Foundation
Author of GPIO Zero and creator of piwheels
gordon77
Mon Jun 24, 2019 4:57 pm
Thanks for the explanation.
plugwash
Tue Jun 25, 2019 9:40 pm
You can also try the version from raspbian.
apt-get install python3-opencv
gordon77
Wed Jun 26, 2019 7:03 am
Thanks, modified my install..
sudo apt-get install python3-opencv
sudo apt-get install libhdf5-dev
sudo apt-get install libhdf5-serial-dev
sudo apt-get install libatlas-base-dev
sudo apt-get install libjasper-dev
sudo apt-get install libqtgui4
sudo apt-get install libqt4-test
opencv now works, but gives a few anomalies on the image, lines, which I need to investigate.
but works OK when using pygame to display, opencv to capture (screen.jpg)
ggNoOpenCV
Wed Jun 26, 2019 12:49 pm
This command is only for version 3.2.0, is there no way to get a higher version on buster currently? Is there any stable os that supports new versions of opencv?
gordon77
Wed Jun 26, 2019 5:10 pm
Jessie and pip3 install opencv-python used to install v 3.4.4
Return to “Python”
