Atari2020
Wed Oct 09, 2019 10:28 pm
Thanks, I am a noob at the tech stuff, but all info is good. I just want to give any info that might help.
TideMan
Thu Oct 10, 2019 2:39 am
I'm running buster on an RPi 4 4GB. The RPi is connected to a Samsung TV by HDMI cable.
In Chromium, when I try to stream, the pictures come through just fine, but I need both RPi and TV at 100% volume to hear sound.
Is there a way to tweak the volume up a bit?
rootscv
Thu Oct 10, 2019 2:48 am
[Retropi On Raspberry Pi 4]
Last month i bought two raspberry pi 4 RAM 4 Gb, in hope i can plays retro games.
After long journey, i still cant play retro games on my raspberyy pi 4. COuld someone tell me why ??
laurent
Thu Oct 10, 2019 9:49 am
Because it's simply not yet supported. Let some time to the Retropie's team to add the Pi4 support. This SBC is a huge update, compared to previous versions, they may have a lot of work. The only other distribution which has support at launch time was LibreElec, and it's still beta.
Thu Oct 10, 2019 9:55 am
The developers of Retropie have no relationship to RPF / RPT so it is not fair to complain when you have not investigated before buying, caveat emptor....
Maybe ??
https://www.lakka.tv
https://www.lakka.tv/articles/2019/08/0 ... 4-support/
Retired disgracefully.....
jcyr
Thu Oct 10, 2019 1:32 pm
To be fair, the RPF/RPT has a long history of maintaining backward compatibility. Things have suddenly changed with the introduction of the PI4.
It's um...uh...well it's kinda like...and it's got a bit of...
davidcoton
Thu Oct 10, 2019 1:47 pm
Not at all. Backwards compatibility means that the new software runs on old hardware. That has been achieved (give or take the odd bug). Getting old software to be compatible with new hardware requires ... no (or severely constrained) new hardware. That is not something RPT has ever tried or claimed. It has always been necessary to update software to run (optimally) on new hardware.
Signature retired
Thu Oct 10, 2019 2:17 pm
The main change is moving to the the more standard OpenGL 3D - that does break a bit of backwards compatibility, but swaps it for a much better long term option. In most others areas we should be fairly OK.
jcyr
Thu Oct 10, 2019 3:04 pm
I think you've got that backwards (pun intended.) Backwards compatibility means that old software will run on new hardware or OS.
https://en.wikipedia.org/wiki/Backward_compatibility
Thu Oct 10, 2019 3:29 pm
Yes and no. It depends what is claimed to backward compatible. Is it the software or the hardware?
In this case it is the new software that is backward compatible with the old hardware.
ejolson
I didn't have any problem running the old btrfs binary from Stretch on a Pi 4B under Buster. In fact, that old binary worked better than the new one.
https://www.raspberrypi.org/forums/view ... 6&t=249873
I think running new software on old hardware is also reverse compatibility.
Having sufficient RAM is an expected issue. With Intel-compatible software, we are also seeing situations where certain software tools no longer support 32-bit architectures. Before that, some code wouldn't run on on pre-SSE2 machines; before that 486 was left out; before that hardware x87 float was required.
From a save-the-planet point of view, it is not green to throw away an expensive battleship, mobile phone or space station because new software no longer runs on the built-in computers. Maybe a big slice of Raspberry Pi could save the day.
chwe
Fri Oct 11, 2019 3:01 am
From https://www.raspberrypi.org/documentati ... minary.pdf
The Pi4B has a dedicated SD card socket which suports 1.8V, DDR50 mode (at a peak bandwidth of 50Megabytes / sec). In addition, a legacy SDIO interface is available on the GPIO pins.
can someone elaborate this a bit more?
e.g. with a modified bootloader it should be possible to attach an eMMC module here?
Imperf3kt
Fri Oct 11, 2019 8:12 pm
This has bothered me since I purchased it, but I ignored it for a while.
However it's really starting to bug me.
The Australian version of the Official Pi4 power supply is upside down, why?
I have to bend the cord 180° in order to use it. I imagine in time, gravity will ruin it.
(those lugs on all four sides so you can unplug it, make it difficult to use the switch too)
55:55:44:44:4C
52:4C:52:42:41
dickon
Fri Oct 11, 2019 8:43 pm
As they say, gravity is a myth. The Earth sucks.
More accurately, the mass of that cable won't do it any damage despite it being in the 'wrong' orientation. We see this sort of thing in the UK all the time...
jbudd
Sat Oct 12, 2019 12:50 am
Could it be that Australia is upside down? :D
ps I know Australia isn't upside down, I went and checked. Oddly though, the night sky there WAS upside down.
TideMan
Sat Oct 12, 2019 2:50 am
And the lugs on the sides of the PS are really annoying if you're using a power board, because they protrude over the adjacent slot meaning you can only use every second one.
Sat Oct 12, 2019 9:31 am
Could you pop the lid off, turn it "widdershins" then glue it back on?
This is a doctor free zone.
ejolson
Sat Oct 12, 2019 2:51 pm
It would be easier to turn the house upside down. That way gravity will pull things towards the ceiling the way it is supposed to work down under. Another thought is to hire an electrician to install a new mains socket upside down.
Here in the liberal frontier we intentionally install about half the sockets in a new house using the upsidedown orientation, just in case anthropomorphic global warming causes both the magnetic and gravity fields to reverse. It's also used to indicate which sockets are connected to the light switches.
Imperf3kt
Sat Oct 12, 2019 7:46 pm
That's probably on purpose.
It's a legal requirement that power supply blocks are designed so you cannot place two side by side on a power board due to the heat they can generate.
The solution is to get a power board with "wide" sockets.
A wide selection is available here: (excuse the pun)
https://hpm.com.au/powerboards/
55:55:44:44:4C
52:4C:52:42:41
andrum99
Sun Oct 13, 2019 12:47 am
There are two SD card interfaces on Pi Zero to 3: one is the Broadcom SDHOST interface, the other is the Arasan SDIO. Both are present on the Pi 4 as well, but are not currently used by any official hardware. The Compute Module and Compute Module 3 use the Broadcom SDHOST interface to talk to their eMMC modules. The old Broadcom interface is not normally accessible on the Pi 4, since it uses the same GPIOs that are used for the new DDR SD card interface, and those GPIOs are hardwired to the SD card slot (and not the GPIO header).
When the Raspberry Pi was first released, it used the Arasan interface to talk to the SD card. I'm not sure if the Compute Module also used it to talk to its eMMC module, or if the Pi had switched to use SDHOST instead before that.
You can also attach an eMMC module to any Pi using an adaptor - for example one that plugs an eMMC module into a USB slot, or an SD card slot. On Pi 4B this should mean you could use an eMMC module with the new DDR-capable SD card interface, and boot from it.
RossDv8
Sun Oct 13, 2019 7:21 am
I don't know if this has been answered already, because I can;t find any replies. However, there is a way to get the Pi volume up to about 150% fairly easily. First, you will have to check if you have pulseaudio on your Pi. in a Terminal type pulseaudio and hit Enter. If you get something like "E: [pulseaudio] pid.c: Daemon already running." you have it. If it says something like "pulseausio command not found" you don'e, so just do a sudo apt-get pulseaudio
Now, the bit that will help you is called pulseaudio volume control. you can get that by:
sudo apt-get pavucontrol
Once you have those, do a reboot to make sure the pulseaudio daemon is running. Then you should fine 'PulseAudio Volume Control' in the Sound and Video section of your Main Menu. On mine it is a little red square with three white vertical stripes. (representing sliders).
Open that and you should be able to change the Volume. BUT !!!
When you first open it, look at the 'Playback' tab. You might find the only thing you can change is the slider for 'System Sounds'. That is because there is no media plaing.
Just start playing something, in VLC or whatever makes some noise, and look at the Playback tab again.
Now there should be a listing for VLC, and the slider below it can be taken up to about 150%.
NOTE ! If you adjust the normal volume control on the Pabel, it will set pavucontrol back to 100% and you will have to manually adjust it again.
There is a way to set it to default above 100% but I can;t remember what I did (it is on my other Linux computers).
I'm nit certain that something else isn't causing the problem, but that 'answers your question'.
I hope if helps. You can also just add an icon for PulseAudio Volume Control to your panel to make it easy :-)
Pi 4B 4GB - Samsing128GB EVO plus microSD
