Daveolw1
Function going through twice
Fri Jun 14, 2019 6:36 pm
Why does it go through this function twice, I thought it was button bounce but increased the value to 1000 but it still happened. I then added the sleep 50 at the end and it waits there and then goes through again. There is nothing in the function that refers to any other part of the programme it is just taking values from lists and saving them to files. Going through a second time it is adding more items to the list and then saving it to file.
def my_callbackp18(channel):
    global all_play_list
    global playlist_tmp
    global playlist_files
    total_playlist = len(playlist_files)
    digit8_value = total_playlist
    dig6 = str(digit6_value)
    dig7 = str(digit7_value)
    dig8 = str(digit8_value)
    play_list_file_string = dig6 + dig7 + dig8 + '.txt'
    play_list_file = play_list_file_string
    list_num = total_playlist + 1
    playlist_files.insert(list_num, play_list_file)
    f = open("/media/pi/PI_STORAGE/play_list/all_play_list.txt", 'w')
    for item in playlist_files:
        print('item = ', item)
        f.write(item + ',')
    f.close()
    f = open("/media/pi/PI_STORAGE/play_list/" + play_list_file, 'w')
    for item in playlist_tmp:
        f.write(item + ',')
    f.close()
    time.sleep(50)
GPIO.add_event_detect(18, GPIO.FALLING, callback=my_callbackp18, bouncetime=1000)
pcmanbob
Re: Funtion going through twice
Fri Jun 14, 2019 10:35 pm
I can't see anything that would make the function run twice, so may be its some thing in the rest of your code , but as you have not posted that we can't say what it might be.
ghp
Sat Jun 15, 2019 6:44 am
For checking the behavior, you could add a print-statement just at the beginning of my_callbackp18.
Your full code could possibly help to help.
Most possibly you checked the connection to your button (?) many times. Is it the only code running on this pi ?
B.Goode
Sat Jun 15, 2019 9:17 am
It doesn't directly help, but there are reports of this behaviour in this forum dating back to 2012.
My suggestion would be to try reimplementing your code with a different gpio library, perhaps gpiozero. Although gpiozero can use RPi.GPIO as its 'backend', there are alternatives you can specify instead.
https://gpiozero.readthedocs.io/en/stab ... igpio.html
Daveolw1
Sat Jun 15, 2019 3:30 pm
Thanks for the replies.
I have worked out it is the "open file/For" section of code that is causing it, if I remove this part of code it only goes through the once.
        f.write(item + ',')
 f.close()
        f.write(item + ',')
 f.close()
This code is taking List data and saving to a file and at the start of the programme it reads these files back into list. There is something strange with the way it presents these because it keeps adding them like ['002.txt'] and when I try to access List[0] I get [ instead of 0 as expected. I search to try and find an example of writing a list to file and reading back into a list.
Thanks David
pcmanbob
Sat Jun 15, 2019 3:48 pm
I don't see how the file write is causing the function to run twice.
the first file write.
        f.write(item + ',')
 f.close()
will simply open a file called "all_play_list.txt" and over write what ever is in it with the new data as specified in the for loop before closing the file.
the second file write
        f.write(item + ',')
 f.close()
is slightly different because you have a variable as the file name " play_list_file " which is set by these lines in your code
so what ever " dig6 + dig7 + dig8 " equals is what your file name will be.
so for example if dig6= 3, dig7= 5, dig8= 9, your file would be called 379.txt
again the file is opened for writing so all data will be over written as specified in the for loop before closing the file.
again nothing there to make your function run twice.
Daveolw1
Sat Jun 15, 2019 4:01 pm
So when I remove those two sections of code, does it only go through once, with either of them in it goes through twice?
pcmanbob
Sat Jun 15, 2019 4:16 pm
To make the function run twice you would need to have it called again , if one of your file writes was doing this then it would never exit because on each call it would call the function again and so enter an endless loop.
like this
function called by gpio.
function runs and calls it self again
and so on.
have you tried adding some print statements to your function so you can watch it being executed , if you run your program from the command line.
    print ("function run")
    global playlist_tmp
    print ("write date to all_play_list.txt")
        f.write(item + ',')
    f.close()
    print ("write date to ",play_list_file)
        f.write(item + ',')
    f.close()
    print (" file writes completed")
    time.sleep(50)
Daveolw1
Sat Jun 15, 2019 5:43 pm
Yes, I have already got a lot of print statements in it but I removed them before posting so the code could be read easier.
Below code and output, I have a workaround at the moment with the If statement " if not digit5_value == 0:" but have commented out the line at the bottom " #digit5_value = 0" to show the function goes through twice.
    print('write file callback18')
    global digit5_value
    global playlist_tmp
    global play_list_file
        print(play_list_file_string)
        print("TPlen = ", total_playlist)
        print(list_num)
        print('PLF = ', playlist_files)
            f.write(str(item) + ',')
        f.close()
        print('all play list file saved')
        f.close()
        del playlist_tmp[:]
        print('play list file saved')
        seg.text[4:5] = '0'
        #digit5_value = 0
OUTPUT:-
[["['000.txt']"], ["['001.txt']"], ["['002.txt']"], ["['003.txt']"], ['004.txt']]
['0519.txt']
['0519.txt', '1213.txt']
write file callback18 "first time through adds item ['005.txt'] "
005.txt
TPlen = 5
6
PLF = [["['000.txt']"], ["['001.txt']"], ["['002.txt']"], ["['003.txt']"], ['004.txt'], '005.txt']
item = ["['000.txt']"]
item = ["['001.txt']"]
item = ["['002.txt']"]
item = ["['003.txt']"]
item = ['004.txt']
item = 005.txt
item = 0519.txt
item = 1213.txt
write file callback18 "second time through adds item ['006.txt'] but file is empty because songs were selected "
006.txt
TPlen = 6
7
PLF = [["['000.txt']"], ["['001.txt']"], ["['002.txt']"], ["['003.txt']"], ['004.txt'], '005.txt', '006.txt']
item = ['004.txt']
item = 005.txt
item = 006.txt
ghp
Sun Jun 16, 2019 7:31 am
I was curious to see how these callback work. Especially in case the runtime in the callback is longer than the event input.
The setup is: use a microcontroller (arduino zero) and produce a square wave with 3 sec low and 3 sec high. At each edge, I added some jitter (50 times, 2 ms period).
Code in RPi:
import  RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(21, GPIO.IN)
def f(channel):
    print("f start", time.time() )
    time.sleep(0)
    print("f end  ", time.time() )
GPIO.add_event_detect(21, GPIO.RISING, callback=f, bouncetime=50)
time.sleep(60) # just to leave code running some time
When code is having time.sleep(0), then result is
f start 1560668382.7183247
f end   1560668382.7185113
f start 1560668388.7176194
f end   1560668388.7178047
f start 1560668394.716907
f end   1560668394.7170556
f start 1560668400.7163208
f end   1560668400.7165692
The printout shows that each 6 sec the "f start" is printed. This is as expected.
When a delay of 8 sec is added inside the f-function, things change and look like 'function called twice'
f start 1560668232.7351942
f end   1560668240.743672
f start 1560668240.7438862
f end   1560668248.751989
f start 1560668248.7522573
f end   1560668256.7589428
f start 1560668256.7592444
f end   1560668264.7669976
f start 1560668264.7672117
f end   1560668272.7753232
It is clearly visible that the next start after the processing ends is immediate after the function stops. Keep in mind that my controller places a signal still each 6 sec. So the intermediate pulse is 'queued' and processed immediately when the callback is terminated.
As a rule of thumb, keep the runtime inside the callback as short as possible.
If changing the code a bit, and using wait_for_edge in a loop, the result are different. Assuming the time needed in the function is 8 sec, trigger is still each 6 sec.
f start 1560669912.5439527
f end   1560669920.5523303 # trigger at 18 is skipped
f start 1560669924.5425208
f end   1560669932.5507638 # trigger at 30 is skipped
f start 1560669936.541285
f end   1560669944.5497527
f start 1560669948.5398061
f end   1560669956.5480206
The code is
import time
def f(channel):
    time.sleep(8)
while True:
    GPIO.wait_for_edge(21, GPIO.RISING)
    f(21)
It is easy to have a thread in python which runs th eloop independent from other tasks.
Daveolw1
Sun Jun 16, 2019 12:37 pm
I gave my function a different name and just called that from the callback function but the result was the same it went through twice.
pcmanbob
Sun Jun 16, 2019 2:34 pm
one other thing you could try is to remove the event detect as soon as your function is caled then once the function is completed you can add it back in.
like this
    GPIO.remove_event_detect(18)
    global playlist_tmp
        f.write(item + ',')
    f.close()
        f.write(item + ',')
    f.close()
    time.sleep(2)
that way no other events can be called while the function is running, it should prove if its a true event ( ie gpio input ) that's calling the function a second time or some thing in your function that making it run twice.
Daveolw1
Sun Jun 16, 2019 6:06 pm
Thanks for the information, I tried as you suggested and it only goes through once so this prove it is a true GPIO input.
Thanks David
pcmanbob
Sun Jun 16, 2019 7:49 pm
So we have finally proved it's an actual second input on the gpio causing the function to run twice.
So your a step closer to solving the problem or you could just leave the function as it is so it stops the calling of the function while it's running.
I would guess it's switch bounce causing the second input.
Daveolw1
Sun Jun 16, 2019 8:11 pm
Can not see it is switch bounce, as stated in my first post I suspected that and increased it to 1000.
pcmanbob
Re: Function going through twice
Mon Jun 17, 2019 9:33 am
If its not switch bounce , have you check your wiring for a bad connection ?
I cant see it being interference or induced voltages at your function would be running randomly, could it be your power supply being loaded and dropping its voltage ?
Daveolw1
Mon Jun 17, 2019 9:42 am
Have checked wiring, originally I used internal pull ups but got spurious events so disabled them and have 10k connected to the 3.3 volts.
I used a different button which was working ok with other code and the same happened, it went through twice, I still think it is something to do with the open file/for section of code because removing that it does not happen.
pcmanbob
Mon Jun 17, 2019 10:14 am
Well if you disabled the event and still had the file writes in place and then re enabled the event after the file writes , it has to ether be a button press or something causing your pi to think there has been a button press , as you still have not posted your complete program or a digram of how you have the switch/s connected we are working with limited information.
Return to “Python”
