soheilsabz
Failure to build QT5 5.12.3 on Raspberry Pi zero
Fri Jun 14, 2019 5:17 pm
Hi:
Following the instructions in https://www.tal.org/tutorials/building ... spberry-pi,:
 wget http://download.qt.io/official_releases/qt/5.12/5.12.3/single/qt-everywhere-src-5.12.3.tar.xz
    tar xf qt-everywhere-src-5.12.3.tar.xz
    git clone https://github.com/oniongarlic/qt-raspberrypi-configuration.git
> cd into the clone repository and run (adjust DESTDIR in case your Qt
> sources are extracted somewhere else):
    cd qt-raspberrypi-configuration && make install DESTDIR=../qt-everywhere-src-5.12.3
    apt-get update
    apt-get install build-essential libfontconfig1-dev libdbus-1-dev libfreetype6-dev libicu-dev libinput-dev libxkbcommon-dev libsqlite3-dev libssl-dev libpng-dev libjpeg-dev libglib2.0-dev libraspberrypi-dev
So for running the `configure` file i entered this command to terminal:
export PATH="$PATH:/usr/lib/llvm-3.8
     sudo PKG_CONFIG_LIBDIR=/usr/lib/arm-linux-gnueabihf/pkgconfig:/usr/share/pkgconfig \
        ../qt-everywhere-src-5.12.3/configure -platform linux-rpi-g++ \
        -v \
        -opengl es2 -eglfs \
        -no-gtk \
        -opensource -confirm-license -release \
        -reduce-exports \
        -force-pkg-config \
        -nomake examples -no-compile-examples \
        -skip qtwayland \
        -skip qtwebengine \
        -no-feature-geoservices_mapboxgl \
        -qt-pcre \
        -no-pch \
        -ssl \
        -evdev \
        -system-freetype \
        -fontconfig \
        -glib \
        -prefix /opt/Qt5.12 \
        -qpa eglfs \
        -qt-xcb
I have gone until the configure process so get this output:
 rying source 0 (type pkgConfig) of library pulseaudio ...
    + /usr/bin/pkg-config --exists --silence-errors libpulse '>=' 0.9.10 libpulse-mainloop-glib
    + /usr/bin/pkg-config --modversion libpulse '>=' 0.9.10 libpulse-mainloop-glib
    > 10.0
    > 10.0
    + /usr/bin/pkg-config --libs-only-L libpulse '>=' 0.9.10 libpulse-mainloop-glib
    + /usr/bin/pkg-config --libs-only-l libpulse '>=' 0.9.10 libpulse-mainloop-glib
    > -lpulse-mainloop-glib -lpulse -lglib-2.0
    + /usr/bin/pkg-config --cflags libpulse '>=' 0.9.10 libpulse-mainloop-glib
    > -D_REENTRANT -I/usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include
    + cd /home/pi/Desktop/qt-raspberrypi-configuration/config.tests/pulseaudio && /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake "CONFIG -= qt debug_and_release app_bundle lib_bundle" "CONFIG += shared use_gold_linker warn_off console single_arch" 'QMAKE_USE += pulseaudio' 'QMAKE_LIBS_PULSEAUDIO = /usr/lib/arm-linux-gnueabihf/libpulse-mainloop-glib.so /usr/lib/arm-linux-gnueabihf/libpulse.so /usr/lib/arm-linux-gnueabihf/libglib-2.0.so' 'QMAKE_INCDIR_PULSEAUDIO = /usr/include/glib-2.0 /usr/lib/arm-linux-gnueabihf/glib-2.0/include' 'QMAKE_DEFINES_PULSEAUDIO = _REENTRANT' /home/pi/Desktop/qt-everywhere-src-5.12.3/qtmultimedia/config.tests/pulseaudio
    + cd /home/pi/Desktop/qt-raspberrypi-configuration/config.tests/pulseaudio && MAKEFLAGS= /usr/bin/make
    > g++ -c -pipe -mfpu=vfp -mtune=arm1176jzf-s -march=armv6zk -O2 -w -fPIC -D_REENTRANT -I/home/pi/Desktop/qt-everywhere-src-5.12.3/qtmultimedia/config.tests/pulseaudio -I. -isystem /usr/include/glib-2.0 -I/usr/lib/arm-linux-gnueabihf/glib-2.0/include -I/home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/mkspecs/linux-rpi-g++ -o pulseaudio.o /home/pi/Desktop/qt-everywhere-src-5.12.3/qtmultimedia/config.tests/pulseaudio/pulseaudio.cpp
    > g++ -Wl,-O1 -fuse-ld=gold -o pulseaudio pulseaudio.o   /usr/lib/arm-linux-gnueabihf/libpulse-mainloop-glib.so /usr/lib/arm-linux-gnueabihf/libpulse.so /usr/lib/arm-linux-gnueabihf/libglib-2.0.so
     => source accepted.
    Trying source 0 (type pkgConfig) of library libresourceqt5 ...
    + /usr/bin/pkg-config --exists --silence-errors libresourceqt5
    pkg-config did not find package.
      => source produced no result.
    Done running configuration tests.
    Configure summary:
    Build type: linux-rpi-g++ (arm, CPU features: <none>)
    Compiler: gcc 6.3.0
    Configuration: use_gold_linker enable_new_dtags largefile shared rpath release c++11 c++14 concurrent dbus reduce_exports stl
    Build options:
      Mode ................................... release
      Optimize release build for size ........ no
      Building shared libraries .............. yes
      Using C standard ....................... C11
      Using C++ standard ..................... C++14
      Using ccache ........................... no
      Using gold linker ...................... yes
      Using new DTAGS ........................ yes
      Using precompiled headers .............. no
      Using LTCG ............................. no
      Target compiler supports:
        NEON ................................. no
      Build parts ............................ libs tools
    Qt modules and options:
      Qt Concurrent .......................... yes
      Qt D-Bus ............................... yes
      Qt D-Bus directly linked to libdbus .... yes
      Qt Gui ................................. yes
      Qt Network ............................. yes
      Qt Sql ................................. yes
      Qt Testlib ............................. yes
      Qt Widgets ............................. yes
      Qt Xml ................................. yes
    Support enabled for:
      Using pkg-config ....................... yes
      udev ................................... yes
      Using system zlib ...................... yes
    Qt Core:
      DoubleConversion ....................... yes
        Using system DoubleConversion ........ yes
      GLib ................................... yes
      iconv .................................. no
      ICU .................................... yes
      Tracing backend ........................ <none>
      Logging backends:
        journald ............................. no
        syslog ............................... no
        slog2 ................................ no
      Using system PCRE2 ..................... no
    Qt Network:
      getifaddrs() ........................... yes
      IPv6 ifname ............................ yes
      libproxy ............................... no
      Linux AF_NETLINK ....................... yes
      OpenSSL ................................ yes
        Qt directly linked to OpenSSL ........ no
      OpenSSL 1.1 ............................ yes
      DTLS ................................... yes
      SCTP ................................... no
      Use system proxies ..................... yes
    Qt Gui:
      Accessibility .......................... yes
      FreeType ............................... yes
        Using system FreeType ................ yes
      HarfBuzz ............................... yes
        Using system HarfBuzz ................ no
      Fontconfig ............................. yes
      Image formats:
        GIF .................................. yes
        ICO .................................. yes
        JPEG ................................. yes
          Using system libjpeg ............... yes
        PNG .................................. yes
          Using system libpng ................ yes
      EGL .................................... yes
      OpenVG ................................. yes
      OpenGL:
        Desktop OpenGL ....................... no
        OpenGL ES 2.0 ........................ yes
        OpenGL ES 3.0 ........................ yes
        OpenGL ES 3.1 ........................ yes
        OpenGL ES 3.2 ........................ yes
      Vulkan ................................. no
      Session Management ..................... yes
    Features used by QPA backends:
      evdev .................................. yes
      libinput ............................... yes
      INTEGRITY HID .......................... no
      mtdev .................................. yes
      tslib .................................. yes
      xkbcommon .............................. yes
      X11 specific:
        XLib ................................. yes
        XCB Xlib ............................. yes
        EGL on X11 ........................... yes
    QPA backends:
      DirectFB ............................... no
      EGLFS .................................. yes
      EGLFS details:
        EGLFS OpenWFD ........................ no
        EGLFS i.Mx6 .......................... no
        EGLFS i.Mx6 Wayland .................. no
        EGLFS RCAR ........................... no
        EGLFS EGLDevice ...................... yes
        EGLFS GBM ............................ yes
        EGLFS VSP2 ........................... no
        EGLFS Mali ........................... no
        EGLFS Raspberry Pi ................... yes
        EGLFS X11 ............................ yes
      LinuxFB ................................ yes
      VNC .................................... yes
      Mir client ............................. no
      XCB:
        Using system-provided XCB libraries .. no
        XCB XKB .............................. yes
        XCB XInput ........................... yes
        Native painting (experimental) ....... yes
        GL integrations:
          GLX Plugin ......................... no
          EGL-X11 Plugin ..................... yes
    Qt Sql:
      SQL item models ........................ yes
    Qt Widgets:
      GTK+ ................................... no
      Styles ................................. Fusion Windows
    Qt PrintSupport:
      CUPS ................................... yes
    Qt Sql Drivers:
      DB2 (IBM) .............................. no
      InterBase .............................. no
      MySql .................................. yes
      OCI (Oracle) ........................... no
      ODBC ................................... yes
      PostgreSQL ............................. yes
      SQLite2 ................................ yes
      SQLite ................................. yes
        Using system provided SQLite ......... no
      TDS (Sybase) ........................... yes
    Qt Testlib:
      Tester for item models ................. yes
    Qt SerialBus:
      Socket CAN ............................. yes
      Socket CAN FD .......................... yes
    Qt QML:
      QML network support .................... yes
      QML debugging and profiling support .... yes
      QML sequence object .................... yes
      QML list model ......................... yes
      QML XML http request ................... yes
      QML Locale ............................. yes
      QML delegate model ..................... yes
    Qt Quick:
      Direct3D 12 ............................ no
      AnimatedImage item ..................... yes
      Canvas item ............................ yes
      Support for Qt Quick Designer .......... yes
      Flipable item .......................... yes
      GridView item .......................... yes
      ListView item .......................... yes
      TableView item ......................... yes
      Path support ........................... yes
      PathView item .......................... yes
      Positioner items ....................... yes
      Repeater item .......................... yes
      ShaderEffect item ...................... yes
      Sprite item ............................ yes
    Qt Scxml:
      ECMAScript data model for QtScxml ...... yes
    Qt Gamepad:
      SDL2 ................................... no
    Qt 3D:
      Assimp ................................. yes
      System Assimp .......................... no
      Output Qt3D Job traces ................. no
      Output Qt3D GL traces .................. no
      Use SSE2 instructions .................. no
      Use AVX2 instructions .................. no
      Aspects:
        Render aspect ........................ yes
        Input aspect ......................... yes
        Logic aspect ......................... yes
        Animation aspect ..................... yes
        Extras aspect ........................ yes
    Qt 3D Renderers:
      OpenGL Renderer ........................ yes
    Qt 3D GeometryLoaders:
      Autodesk FBX ........................... no
    Qt Bluetooth:
      BlueZ .................................. no
      BlueZ Low Energy ....................... no
      Linux Crypto API ....................... no
      WinRT Bluetooth API (desktop & UWP) .... no
    Qt Sensors:
      sensorfw ............................... no
    Qt Quick Controls 2:
      Styles ................................. Default Fusion Imagine Material Universal
    Qt Quick Templates 2:
      Hover support .......................... yes
      Multi-touch support .................... yes
    Qt Positioning:
      Gypsy GPS Daemon ....................... no
      WinRT Geolocation API .................. no
    Qt Location:
      Qt.labs.location experimental QML plugin . yes
      Geoservice plugins:
        OpenStreetMap ........................ yes
        HERE ................................. yes
        Esri ................................. yes
        Mapbox ............................... yes
        MapboxGL ............................. no
        Itemsoverlay ......................... yes
    QtXmlPatterns:
      XML schema support ..................... yes
    Qt Multimedia:
      ALSA ................................... yes
      GStreamer 1.0 .......................... yes
      GStreamer 0.10 ......................... no
      Video for Linux ........................ yes
      OpenAL ................................. no
      PulseAudio ............................. yes
      Resource Policy (libresourceqt5) ....... no
      Windows Audio Services ................. no
      DirectShow ............................. no
      Windows Media Foundation ............... no
    Qt Tools:
      QDoc ................................... no
    WARNING: QDoc will not be compiled, probably because libclang could not be located. This means that you cannot build the Qt documentation.
    Either ensure that llvm-config is in your PATH environment variable, or set LLVM_INSTALL_DIR to the location of your llvm installation.
    On Linux systems, you may be able to install libclang by installing the libclang-dev or libclang-devel package, depending on your distribution.
    On macOS, you can use Homebrew's llvm package.
    On Windows, you must set LLVM_INSTALL_DIR to the installation path.
    Qt is now configured for building. Just run 'make'.
    Once everything is built, you must run 'make install'.
    Qt will be installed into '/opt/Qt5.12'.
    Prior to reconfiguration, make sure you remove any leftovers from
and by running
`make -j2`
i get this output:
 bcommon.so /usr/lib/arm-linux-gnueabihf/libdl.so -lbrcmGLESv2 -lbrcmEGL /usr/lib/arm-linux-gnueabihf/libgthread-2.0.so /usr/lib/arm-linux-gnueabihf/libglib-2.0.so /usr/lib/arm-linux-gnueabihf/libfreetype.so /usr/lib/arm-linux-gnueabihf/libz.so
    /usr/bin/ld.gold: error: .obj/qxcbwindow.o: file is empty
    .obj/qxcbclipboard.o:qxcbclipboard.cpp:function QXcbClipboard::requestor() const: error: undefined reference to 'QXcbWindow::setWindowTitle(QXcbConnection const*, unsigned int, QString const&)'
    .obj/qxcbconnection.o:qxcbconnection.cpp:function QXcbConnection::getQtSelectionOwner(): error: undefined reference to 'QXcbWindow::setWindowTitle(QXcbConnection const*, unsigned int, QString const&)'
    .obj/qxcbconnection.o:qxcbconnection.cpp:function QXcbConnection::clientLeader(): error: undefined reference to 'QXcbWindow::setWindowTitle(QXcbConnection const*, unsigned int, QString const&)'
    .obj/qxcbconnection.o:qxcbconnection.cpp:function QXcbConnection::event(QEvent*): error: undefined reference to 'QXcbWindow::updateSyncRequestCounter()'
    .obj/qxcbintegration.o:qxcbintegration.cpp:function QXcbIntegration::createForeignWindow(QWindow*, unsigned int) const: error: undefined reference to 'QXcbWindow::QXcbWindow(QWindow*)'
    .obj/qxcbintegration.o:qxcbintegration.cpp:function QXcbIntegration::createForeignWindow(QWindow*, unsigned int) const: error: undefined reference to 'vtable for QXcbForeignWindow'
    /usr/bin/ld.gold: the vtable symbol may be undefined because the class is missing its key function
    .obj/qxcbintegration.o:qxcbintegration.cpp:function QXcbIntegration::createPlatformWindow(QWindow*) const: error: undefined reference to 'QXcbWindow::QXcbWindow(QWindow*)'
    .obj/qxcbintegration.o:qxcbintegration.cpp:function QXcbIntegration::createPlatformWindow(QWindow*) const: error: undefined reference to 'QXcbWindow::create()'
    .obj/qxcbkeyboard.o:qxcbkeyboard.cpp:function QXcbKeyboard::handleKeyEvent(unsigned int, QEvent::Type, unsigned char, unsigned short, unsigned int, bool): error: undefined reference to 'QXcbWindow::updateNetWmUserTime(unsigned int)'
    .obj/qxcbscreen.o:qxcbscreen.cpp:function QXcbVirtualDesktop::QXcbVirtualDesktop(QXcbConnection*, xcb_screen_t*, int): error: undefined reference to 'QXcbWindow::windowTitle(QXcbConnection const*, unsigned int)'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbBackingStoreImage::setClip(QRegion const&): error: undefined reference to 'qRegionToXcbRectangleList(QRegion const&)'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbSystemTrayBackingStore::initXRenderMode(): error: undefined reference to 'QXcbWindow::visualId() const'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbSystemTrayBackingStore::QXcbSystemTrayBackingStore(QWindow*): error: undefined reference to 'QXcbWindow::visualId() const'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbSystemTrayBackingStore::QXcbSystemTrayBackingStore(QWindow*): error: undefined reference to 'QXcbWindow::setParentRelativeBackPixmap()'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbBackingStore::flush(QWindow*, QRegion const&, QPoint const&): error: undefined reference to 'QXcbWindow::needsSync() const'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbBackingStore::flush(QWindow*, QRegion const&, QPoint const&): error: undefined reference to 'QXcbWindow::updateSyncRequestCounter()'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbBackingStore::composeAndFlush(QWindow*, QRegion const&, QPoint const&, QPlatformTextureList*, bool): error: undefined reference to 'QXcbWindow::needsSync() const'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbBackingStore::composeAndFlush(QWindow*, QRegion const&, QPoint const&, QPlatformTextureList*, bool): error: undefined reference to 'QXcbWindow::updateSyncRequestCounter()'
    .obj/qxcbbackingstore.o:qxcbbackingstore.cpp:function QXcbSystemTrayBackingStore::recreateImage(QXcbWindow*, QSize const&): error: undefined reference to 'QXcbWindow::xcbScreen() const'
    .obj/qxcbnativeinterface.o:qxcbnativeinterface.cpp:function dumpNativeWindowsRecursion(QXcbConnection const*, unsigned int, int, QTextStream&): error: undefined reference to 'QXcbWindow::windowTitle(QXcbConnection const*, unsigned int)'
    .obj/qxcbnativeinterface.o:qxcbnativeinterface.cpp:function QXcbNativeInterface::platformFunction(QByteArray const&) const: error: undefined reference to 'QXcbWindow::setWmWindowTypeStatic(QWindow*, QFlags<QXcbWindowFunctions::WmWindowType>)'
    .obj/qxcbnativeinterface.o:qxcbnativeinterface.cpp:function QXcbNativeInterface::platformFunction(QByteArray const&) const: error: undefined reference to 'QXcbWindow::setWmWindowRoleStatic(QWindow*, QByteArray const&)'
    .obj/qxcbnativeinterface.o:qxcbnativeinterface.cpp:function QXcbNativeInterface::platformFunction(QByteArray const&) const: error: undefined reference to 'QXcbWindow::setWindowIconTextStatic(QWindow*, QString const&)'
    .obj/qxcbnativeinterface.o:qxcbnativeinterface.cpp:function QXcbNativeInterface::platformFunction(QByteArray const&) const: error: undefined reference to 'QXcbWindow::visualIdStatic(QWindow*)'
    .obj/qxcbdrag.o:qxcbdrag.cpp:function QXcbDrag::move(QPoint const&, QFlags<Qt::MouseButton>, QFlags<Qt::KeyboardModifier>): error: undefined reference to 'QXcbWindow::windowTitle(QXcbConnection const*, unsigned int)'
    .obj/qxcbconnection_xi2.o:qxcbconnection_xi2.cpp:function QXcbConnection::xi2ProcessTouch(void*, QXcbWindow*): error: undefined reference to 'QXcbWindow::xcbScreen() const'
    .obj/qxcbconnection_xi2.o:qxcbconnection_xi2.cpp:function QXcbConnection::xi2ProcessTouch(void*, QXcbWindow*): error: undefined reference to 'QXcbWindow::doStartSystemMoveResize(QPoint const&, int)'
    .obj/qbackingstore_x11.o:qbackingstore_x11.cpp:function QXcbNativeBackingStore::flush(QWindow*, QRegion const&, QPoint const&): error: undefined reference to 'QXcbWindow::needsSync() const'
    .obj/qbackingstore_x11.o:qbackingstore_x11.cpp:function QXcbNativeBackingStore::flush(QWindow*, QRegion const&, QPoint const&): error: undefined reference to 'QXcbWindow::updateSyncRequestCounter()'
    collect2: error: ld returned 1 exit status
    Makefile.xcb_qpa_lib:260: recipe for target '../../../../lib/libQt5XcbQpa.so.5.12.3' failed
    make[6]: *** [../../../../lib/libQt5XcbQpa.so.5.12.3] Error 1
    make[6]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/xcb'
    Makefile:90: recipe for target 'sub-xcb_qpa_lib-pro-make_first-ordered' failed
    make[5]: *** [sub-xcb_qpa_lib-pro-make_first-ordered] Error 2
    make[5]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/xcb'
    Makefile:102: recipe for target 'sub-xcb-make_first' failed
    make[4]: *** [sub-xcb-make_first] Error 2
    make[4]: *** Waiting for unfinished jobs....
    make[6]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs'
    ( test -e Makefile.eglfs-plugin || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile.eglfs-plugin /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/eglfs-plugin.pro ) && make -f Makefile.eglfs-plugin
    cd deviceintegration/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/deviceintegration.pro ) && make -f Makefile
    make[6]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration'
    cd eglfs_kms_support/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support/eglfs_kms_support.pro ) && make -f Makefile
    cd eglfs_x11/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_x11/eglfs_x11.pro ) && make -f Makefile
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_x11'
    make[7]: Nothing to be done for 'first'.
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_x11'
    cd eglfs_brcm/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_brcm/eglfs_brcm.pro ) && make -f Makefile
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support'
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support'
    cd eglfs_emu/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu/eglfs_emu.pro ) && make -f Makefile
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_brcm'
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_brcm'
    cd eglfs_kms/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms/eglfs_kms.pro ) && make -f Makefile
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu'
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu'
    cd eglfs_kms_egldevice/ && ( test -e Makefile || /home/pi/Desktop/qt-raspberrypi-configuration/qtbase/bin/qmake -o Makefile /home/pi/Desktop/qt-everywhere-src-5.12.3/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice/eglfs_kms_egldevice.pro ) && make -f Makefile
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms'
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms'
    make[7]: Entering directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice'
    make[7]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice'
    make[6]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs/deviceintegration'
    make[5]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms/eglfs'
    make[4]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins/platforms'
    Makefile:104: recipe for target 'sub-platforms-make_first' failed
    make[3]: *** [sub-platforms-make_first] Error 2
    make[3]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src/plugins'
    Makefile:725: recipe for target 'sub-plugins-make_first' failed
    make[2]: *** [sub-plugins-make_first] Error 2
    make[2]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase/src'
    Makefile:50: recipe for target 'sub-src-make_first' failed
    make[1]: *** [sub-src-make_first] Error 2
    make[1]: Leaving directory '/home/pi/Desktop/qt-raspberrypi-configuration/qtbase'
    Makefile:83: recipe for target 'module-qtbase-make_first' failed
    make: *** [module-qtbase-make_first] Error 2
So, what can i do to solve this problem?
my question link via raspberry stack exchange:
[https://raspberrypi.stackexchange.com/q ... ry-pi-zero](https://raspberrypi.stackexchange.com/q ... ry-pi-zero)
My question link via Qt forum:
https://forum.qt.io/topic/103934/failur ... ry-pi-zero
thanks
Re: Failure to build QT5 5.12.3 on Raspberry Pi zero
Fri Jun 14, 2019 5:43 pm
That is normal.
All instructions I have ever found for building Qt on the Pi have failed.
Or anywhere for that matter, going back a decade or two.
I did manage to build Qt 5 on a Pi after a week or two of research and trying this and that.
But that was some years ago. I'm sure things have changed since then.
Persist and it can be done. Good luck!
