tomtomcat
Which 4G Huawei Dongle work on the Raspberry Pi 3 B+?
Fri Jun 14, 2019 4:03 pm
Hello!
Thank you!
Andyroo
Re: Which 4G Huawei Dongle work on the Raspberry Pi 3 B+?
Fri Jun 14, 2019 5:21 pm
Look for any manufacturers one that creates an access point.
This has a disadvantage that you need another power supply / charger but has the advantage that you can connect more than one device at once (eg Pi and phone) at the same time. I found they where more reliable than USB dongles.
Failing that, see if your phone allows you to tether the Pi to it and use that contract.
Need Pi spray - these things are breeding in my house...
Fri Jun 14, 2019 5:25 pm
Hello!
Thank you!
I am from UK and used:
http://www.three.co.uk/Discover/Devices ... lour=White
Though had to change out the supplied USB Cable.
adieu
