tripletopper
Dreampiu failed once I updated form Dreampi 1.6 to 1.7
Sun Jun 09, 2019 1:39 am
I bought a Dreampi with version 1.6. I did not analyze what was on my Dreampi SD card.
I have no idea how to flash a DreamPi image for a Raspberry Pi whose only purpose will be a broadband-to-dial-up converter for a real Sega Dreamcast. All I need it for is for the Dreamcast and a couple unix commands to add Sega Swirl Email and MAYBE an ethernet-based Wi Fi device.
Most of the instructions talk about using windows, and there is no definitive video for flashing the Image using a Macintosh.
I read things about a Raspbian something, and NOOBS. And I don’t understand their relationship with Dreampi is.
I tried using 2 different image makers, Etcher for OS X, and Apple-Pi Baker. In both cases I tried straight installing DreamPi, and neither worked neither with the Dreamcast nor with the Unix-based OS that comes on when you hook the card into the Pi, and the TV to the HDMI output.
Do I have to install either NOOBS or some other Raspbian in addition the Dreampi?
How do i install Dreampi so I can see some Unix commands when the Dreampi SD card plugged into a Raspberry Pi 1B. I want to make sure that works first before I test it with the Dreamcast.
Is a 4 GB SD card enough to run Dreampi 1.7 on a 1B/
Re: Dreampiu failed once I updated form Dreampi 1.6 to 1.7
Mon Jun 10, 2019 6:54 am
Maybe best to ask the Software Developer ?
http://blog.kazade.co.uk/p/dreampi.html?m=1
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
tripletopper
Mon Jun 10, 2019 3:51 pm
My main concern is flashing the image correctly. Every time I flash the image, the modem doesn’t work, and the Pi does not have a Unix-style command line editing page.
No one on the dreamcast help sites are able to tell me how to flash the DreamPi file properly to get it working independent.
After I done the update, plugging the Pi in the USB port gives me a black screen of nothing.
These are issues concerning Raspbeery Pi. It seems the Dreamcast help pages assume you have a Pc and not a Macintosh.
Dreamcast help website are not specific enough about the directions of flashing the pi memory.
I understand the Raspberry Pi s very versatile. The only reason I’m in the Pi universe is to get a Dream I working. Ever since I updated nothing works as far as the Pi s concerned. And too many of the directions on the DreamPi help sites assume you are proficient enough in Pi. All I want is their proper flashing instructions on using a Macintosh to Flash a DreamPi properly so I can get the Unix-like OS from the HDMI output, and get the DreamPI to work with my Modem. I understand most of the Dreampi specific instructions, it’s just the Raspberry Pi instructions I don’t understand. And all I want it to do is work as a Dreampi.
Mon Jun 10, 2019 5:06 pm
Etcher is the recommended software for creating a bootable SD Card, but the SD Card Reader needs to be SDHC compatible, alternatively try PiBaker:
https://www.tweaking4all.com/software/m ... -pi-baker/
adieu
tripletopper
Tue Jun 11, 2019 3:32 pm
I have both Etcher for Macintosh and Apple-Pi Baker. But I’m not sure if I’m following directions right or not to get a Bootable Pi image on there.
Do I use the .7z or do I use the .img ?
Do I have to format the SD card a specific way?
How do I tell if my SD card is an SDHC or not?
Tue Jun 11, 2019 4:22 pm
Etcher does not require to unzip, it does everything for you..
...though PiBaker will require unzipping with 7zip to leave you a .IMG file.
I stated Card Reader should be SDHC not the SD Card, it is your hardware.
adieu
tripletopper
Fri Jun 14, 2019 5:28 am
I Know SDHC is a higher "speed" format than a standard SD card. So If I have a Standard SD card, that can be the answer. I’ll go check once I get an answer to this?
And, would it say what type of SD card I have, like would it say SDHC or whatever veriosn of SD I have, and if if it says nothing other than SD, it’s standard SD? Are these other "speed versions" I heard of something called SDXC, there might be more. So i knwo my compatibilitty, what is considered SDHC and higher, and what is consideredlower than SDHC? Also I need full size right, not mini or micro for Pi, even though I could uae a Micro-to-full adapter or a mini-to-full adapter to stick one of those 2 in a Pi?
Finally waht’s the minimum size SD card needed to run Dreampi 1.71 on a RasperyyPi, and is a 1B considered a high enough Pi for Dreampi 1.71?
If a 1B can’t run dreamPi 1.71, what’s the highest version of Dreampi a 1B can run.
If I buy a dreamPi, is it as simple as buying a high enough pre-built Pi anywhere, buying the premade Voltage induced Dial Up modems somewhere in the DC2019 community, loading the software on my Macintosh, adding an Ethernet cable or ethernet bridge, and a standard telephone cord M-M and then inserting card and booting? If I need to do Sega Swirl Gmail, jsut have a USB keyboard to type commands.
One last question, is a Macintosh in Terminal mode related close enough to a Pi where where I can copy and paste the commands on the Macintosh with the DreamPi SDHC card while in Mac Terminal mode. I heard Terminal gets Mac in "UNIX MODE" and some if not all Raspberry Pi stuff uses Linux, which is a more user friendly and/or more powerful version of Unix. I know there are cross-GUI-to-Terminal copying and pasting of text. I prefer to use that if the hoops I have to jump through is easier than double checking to make sure my typings are exactly right.
One thing I know is one wrong letter can permanently ruin a file, and if you don’t know what you did, it’s just easier to start over. Thankfully DreamPi 1.71 s already downloaded as a 7g file.
Which reminds of something funny. When programming in AppleSoft Basic, enough times I accidentally typed "ruin" instead of "run". thankfully no one had a sick sense of humor to randomly change every letter in your program in memory wen given the "ruin" command. :)
Fri Jun 14, 2019 7:55 am
Not quite. SDHC is a higher "capacity" format than a "standard" SD card. Almost any card over 2GB is SDHC (or higher - SDXC or SDUC - for the really big cards). The card reader needs to be SDHC or above to write to those cards correctly.
tripletopper
Sun Jun 16, 2019 3:06 am
Well I checked my card, and it’s a 4 GB SDHC. The only question is are all USB 2.0<-> SD card converters able to do SDHC (or even higher) or does it only do baseline SD? I know I don’t have a USB 3.0 one.
Would the internal card reader within a 21.5 inch late 2013 iMac have an SDHC or faster speed? If the upstairs Mac does,a dn the USB atachment doesn’t then maybe I got to try the upstairs Mac.
I always thoguth all USB 2.0<-> SD?C readers were able to fully rtransfer everything. The only issue is the speed of the transfer.
By the way, is DreamPi 1.71 up yet? I know where to check, except Dreampi 1.6 was having the same errors downstairs
tripletopper
Sun Jun 16, 2019 4:32 am
Do I need to both install NOOBS AND DreamPi using Apple Pi Baker? I don’t understand the directions of Apple Pi Baker enough to install both NOOBS and Dreampi.
I assume noobs is the brains of the OS, and Dreampi is a specific program that runs in NOOBS.
So My I have Instructions on how to Install both NOOBS AND Dreampi using my Macintosh and Apple Pi Baker?
Also is there a way to access NOOBS on Macintosh Terminal using Unix so I can make sure what I type is correct by copying from the GUI and pasting to the Terminal? Can Mac Terminal be used to alter either the Noobs or DreamPi program in such a way that will work just as well as typing it directly on the Pi with a USB keyboard
Sun Jun 16, 2019 5:06 am
The majority of USB2.0 card readers support SDHC. The ones in the Pound shops do.
Internal slots in older computers tend not to support SDHC. I don't know about the slot in your Mac.
NOOBS is not a full OS. It is customised to provide a method for installing a real OS like Raspbian, but many of us prefer to install Raspbian without using NOOBS.
I don't know anything about DreamPi, sorry.
