castleromeo
How to get Stacer to work on Raspbian Stretch
Wed May 29, 2019 9:43 am
I found a no arch package of Stacer 1.1.0-1 and installed it but it will not open up.
How do I get it to work??
Mike
topguy
Re: How to get Stacer to work on Raspbian Stretch
Wed May 29, 2019 11:01 am
If you had provided a link or something so we could have an idea of that Stacer are, and exactly what you downloaded, we might be able to help.
castleromeo
Wed May 29, 2019 11:26 am
I got the .deb file directly from the ppa.
LINK:
http://ppa.launchpad.net/oguzhaninan/st ... /s/stacer/
I chose the one for Ubuntu Disco Dingo.
castleromeo
Wed May 29, 2019 11:27 am
I should add that I downloaded the .deb file to my Pi and installed it using Gdebi.
Wed May 29, 2019 11:32 am
Researching Stacer would suggest it is NOT for ARMHF Linux:
https://github.com/oguzhaninan/Stacer/b ... /README.md
https://github.com/oguzhaninan/Stacer/issues/180
Retired disgracefully.....
castleromeo
Wed May 29, 2019 11:35 am
Should I compile from source tarball then?
davesteele
Wed May 29, 2019 3:37 pm
You could try a debuild from a copy of the git repository on the Pi, to make a proper deb. You would also need the orig.tar file in the parent directory.
Roughly:
sudo apt-get install build-essential devscripts git
wget ...orig.tar.xz
git clone ...
cd ...
debuild
Note that the Architecture field in debian/control should be "any" instead of "all".
davesteele
Wed May 29, 2019 7:39 pm
I'm going to have to retract that recommendation. There are many problems with the debian directory configuration for that project.
Return to “Raspbian”
