caij
Problem with video capture
Tue May 28, 2019 8:34 am
when I capture the video then I always get the video like that one? anyone knows what's the problem with camera? the light works 200hz
HermannSW
Re: Problem with video capture
Tue May 28, 2019 12:27 pm
Raspberry camera?
If so, v1 or v2?
What is the command [line] you use to capture the video?
⇨https://stamm-wilbrandt.de/en/Raspberry_camera.html
https://gitlab.freedesktop.org/HermannSW/gst-template
https://github.com/Hermann-SW/fork-raspiraw
https://twitter.com/HermannSW
caij
Tue May 28, 2019 1:19 pm
Hi HermannSW,
it's V2. the python code is
# -*- coding:utf-8-*-
import numpy
import cv2
cap=cv2.VideoCapture(0)
fourcc=cv2.cv.FOURCC(*'XVID')
out=cv2.VideoWriter('/home/pi/Documents/output.avi',fourcc,90,(640,480))
while(cap.isOpened()):
    ret,frame=cap.read()
    if ret==True:
        frame=cv2.flip(frame,0)
        out.write(frame)
        cv2.imshow('frame',frame)
        if cv2.waitKey(1) & 0xFF == ord('q'):
            break
    else:
        break
cap.release()
out.release()
cv2.destroyAllWindows()
then use command:
$ sudo modprobe bem2835-v4l2
$ python2 VideoCapture.py
_______________________________________________________________
today I try just to capture a photo with decreased exposure time:
the photo is still with this black streak.
6by9
Tue May 28, 2019 2:05 pm
That looks like corruption from the sensor.
Please run
raspistill  -w 640 -h480 -ISO 100 -ss 1-out2.jpeg -r
and post the resulting file to somewhere like Dropbox and Google to share it. The file will be 8-11MB as it includes the raw data off the sensor. That enables us to analyse whether it is the sensor or the Pi at fault.
caij
Tue May 28, 2019 2:33 pm
so I have done this command
the result can be downloaded under this link
https://drive.google.com/file/d/1dbCI0F ... sp=sharing
6by9
Tue May 28, 2019 3:44 pm
So the corruption is on the data coming off the sensor. I'd put that down to either a faulty sensor, or interference on the CSI2 bus (the ribbon cable).
I do note that this is an OV5647 5MPix sensor. Raspberry Pi haven't sold that sensor since 2016, so I suspect that it is from some other supplier. Sorry, but you really need to raising this with them.
caij
Wed May 29, 2019 6:35 am
The problem has been solved. It is not software even hardware problem. What we see on the photo is so called flicker. Cause the light works at 200Hz, is so strong that the exposure time will be set under 5ms based on the automatic focus, then the flicker happened. The solution under this situation is setting the exposure time longer than 5ms, at the same time putting filter on camera to avoid overexposure.
Return to “Camera board”
