castleromeo
Cirrus Logic Sound Card for R-Pi3 control issue
Wed May 22, 2019 7:45 am
I just installed a Cirrus Logic sound card for my Raspberry Pi 3 and installed the drivers. However, when I go to configure the Input-Output jack settings, I get almost 100 different options...Which ones do I check and which ones do I leave alone??
I have no sound yet.....
Mike
castleromeo
Re: Cirrus Logic Sound Card for R-Pi3 control issue
Wed May 22, 2019 8:04 am
Here's a screenshot of what I'm referring to....
Select Controls.jpg (75.88 KiB) Viewed 511 times
castleromeo
Wed May 22, 2019 11:12 am
I forgot to mention two things: First, I am trying to get sound through the green 3.5mm jack on the sound card add on not the RCA jacks and my OS is a custom version Raspbian Jessie. The only difference is three programs added to it.
Wed May 22, 2019 11:15 am
May we ask why you are using obsolete and unsupported Raspbian Jessie OS ??
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
castleromeo
Wed May 22, 2019 11:24 am
Actually I'm not sure which iteration of Raspbian I am using.......How do I find out?
Wed May 22, 2019 11:28 am
lsb_release -a
adieu
castleromeo
Wed May 22, 2019 11:32 am
Ok, I am using Raspbian Stretch.
castleromeo
Wed May 22, 2019 3:03 pm
I did manage to get the sound card working. I had the headphones plugged into the green jack instead of the black headphone jack. Music sounds quite nice as it should but, what control or controls do I choose??? There must be 100 different ones!!!! :o :o :o
HiassofT
Thu May 23, 2019 8:37 am
You can control the headphone output volume with "HPOUT1 Digital", the lineout volume with "HPOUT2 Digital".
When recording audio adjust "IN3L" and "IN3R" for line-in - there are separate controls for left/right.
The WM5102 chip supports very complex signal routing, therefore I wrote a bunch of (shell script) helper functions to set these up - these are in rpi-cirrus-functions.sh, which is used by all the setup scripts like Playback_to_Lineout.sh.
At the beginning of the script you'll find definitions for the mixer base names, you can use that as a cheat-sheet to find the right ones if you want to change them manually. see https://github.com/HiassofT/rpi-cirrus- ... sh#L21-L35
# input base names
headset_in="IN1"
dmic_in="IN2"
line_in="IN3"
# output base names
headset_out="HPOUT1"
line_out="HPOUT2"
speaker_out="SPKOUT"
so long,
Hias
