Shaimaa Badr
RS485 HAT
Sun May 19, 2019 10:35 am
I don't find RS485 HAT shield here in Egypt,, Can I use IC MAX485 and any help for how to connect with raspberry pi to the device has a rj45 socket or use CH340 USB to RS485 485 Converter Adapter Module??!
mikronauts
Re: RS485 HAT
Mon May 20, 2019 1:28 am
A usb adapter is your best bet.
danjperron
Re: RS485 HAT
Mon May 20, 2019 1:33 pm
You could make your own adapter!
This is one of my link.
https://www.raspberrypi.org/forums/view ... 44&t=75189
There is a better method,
I can't give you the link because the fonction to check my post doesn't work today. It gives me an error.
But I was able to find it using google
https://www.raspberrypi.org/forums/view ... 3#p1383709
