John_Spikowski
Re: A Final Fibonacci Challenge
Fri Jun 14, 2019 8:44 am
This seg faults for me. Maybe you can see what I'm doing wrong since it's your code. Probably doesn't like the undef's being passed to GMP.
DECLARE SUB BI_ADD    ALIAS  "bi_add"  LIB "gmp"
DECLARE SUB BI_SUB    ALIAS  "bi_sub"  LIB "gmp"
DECLARE SUB BI_MUL    ALIAS  "bi_mul"  LIB "gmp"
function fiboNoMemo(n)
  if n <= 1 THEN
    fiboNoMemo = n
  else
    k = n \ 2
    a = fibo[k]
    b = fibo[BI_ADD(k + 1)]
    if even(n) then
      fiboNoMemo = BI_SUB(BI_MUL(a, BI_MUL(b, 2), a))
    end if
  end if
  fiboNoMemo = BI_ADD(BI_MUL(a, a), BI_MUL(b, b))
end function
print fiboNoMemo(78),"\n"
Fri Jun 14, 2019 10:25 am
It's not my code. It's your code. In a different language.
fiboNoMemo = n
Be sure that n is a big integer you are returning there.
fibo[BI_ADD(k + 1)]
You do not want to do a big addition to k. k only ever needs to be a regualar integer.
Be sure that "BI_MUL(b, 2)" is using a big integer 2.
What undef's ?
I have to dash, I'll have another look when I get back.
John_Spikowski
Fri Jun 14, 2019 4:29 pm
Confused where the array is coming from. Isn't n a simple integer?
@hippy,
Can you translate Heater's Python code to ScriptBasic?
Fri Jun 14, 2019 5:36 pm
ScriptBasic,
Yes, n is a simple integer. I see no reason for it to be a big integer. We are not about to be computing fibo(2000000000) any time soon!
It's not Python. It's Javascript.
Anyway, if I understand the intention of the ScriptBasic language that is not a translation of the JS.
The original and working JS looks like this:
function fiboNoMemo (n) {
  if (n <= 1) {
    return BigInt(n)
  let k = Math.floor(n / 2)
  let a = fibo(k);
  let b = fibo(k + 1);
  if (isEven(n)) {
    return a * ((b * BigInt(2)) - a)
  return (a * a) + (b * b)
Notice those "return" statements there. They exit the function immediately with whatever value is in the expression following.
The last posted translation of that looks like this:
  if n <= 1 THEN
    fiboNoMemo = n
  else
    k = n \ 2
    a = fibo[k]
    if even(n) then
    end if
  end if
end function
Now, if I understand correctly, making an assignment to fiboNoMemo does not exit the function. It merely sets the returned value.
So, whatever this thing dose, it will run through to the end and return a value of "BI_ADD(BI_MUL(a, a), BI_MUL(b, b))". Which is not the intention and no doubt accounts for the undefs.
Perhaps it should look more like:
  if n <= 1 THEN
    fiboNoMemo = n
  else
    k = n \ 2
    a = fiboNoMemo(k)
    b = fiboNoMemo(k + 1)
    if even(n) then
    else
    endif
  end if
end function
That's probably not correct syntax but you get the idea.
I suggest to start testing with simple cases:
fiboNoMemo(0)
fiboNoMemo(1)
fiboNoMemo(2)
fiboNoMemo(3)
Edit: You should of course be calling fiboNoMemo inside fiboNoMemo, not fibo as you posted. And don't foget the other suggestions I made previously.
hippy
Fri Jun 14, 2019 5:45 pm
I'm not sure what is 'Heater's Python code'. I translated his GMP using C code example into Python, wrote my own library for using the same GMP wrapper using uint castings, and that worked for me.
That code came from viewtopic.php?f=31&t=240287&start=350#p1479349
My conversion to ScriptBasic is as follows -
import bigint.bas
function bigintFibo(n)
  if (n <= 2) then
    bigintFibo = bigint::ix_let(bigint::ix_asString(bigintFibos[n]))
  else
    k = (n / 2)
    bigintFk = bigintFibo(k)
    bigintFk1 = bigintFibo(k + 1)
    if (n % 2) = 0 then
      bigintA = bigint::ix_add(bigintFk1, bigintFk1)
      bigintB = bigint::ix_sub(bigintA, bigintFk)
      bigintR = bigint::ix_mul(bigintFk, bigintB)
    else
      bigintA = bigint::ix_mul(bigintFk, bigintFk)
      bigintB = bigint::ix_mul(bigintFk1, bigintFk1)
      bigintR = bigint::ix_add(bigintA, bigintB)
    end if
    bigint::ix_free(bigintA)
    bigint::ix_free(bigintB)
    bigint::ix_free(bigintFk)
    bigint::ix_free(bigintFk1)
  end if
  bigintFibo = bigintR
end function
sub main(n)
  bigint::ix_init()
  bigintFibos[0] = bigint::ix_let("0")
  bigintFibos[1] = bigint::ix_let("1")
  bigintFibos[2] = bigint::ix_let("1")
  bigintF = bigintFibo(n)
  bigintF10 = bigint::ix_base(bigintF, 10)
  print bigint::ix_asString(bigintF10)
  bigint::ix_free(bigintF10)
  bigint::ix_free(bigintF)
  bigint::ix_free(bigintFibos[0])
  bigint::ix_free(bigintFibos[1])
  bigint::ix_free(bigintFibos[2])
  bigint::ix_clear()
end sub
main(2)
But, after frustrating battles with unhelpful error messages in doing that, I just get -
pi@Pi3B:~/extensions $ scriba bigintfibo.sb
(0): error &H35:Mandatory argument is missing
You're welcome to debug that but I just don't have the time or inclination.
If you tell me what needs to change I'll make that edit and run it again, but I suspect, for things over bigintFibo(2) it's going to give the double freeing issue as your translation did.
John_Spikowski
Fri Jun 14, 2019 5:50 pm
More than likely you're passing a UNDEF variable to GMP.
Simple BIGINT math seems to be working using the extension module I posted. If the fibo is going to look that ugly, I don't think anyone will use it.
Last edited by John_Spikowski on Fri Jun 14, 2019 5:59 pm, edited 1 time in total.
hippy
Fri Jun 14, 2019 5:57 pm
I don't see where but, as said, if you want to debug it and determine where the issue is; I'll fix it and try again.
John_Spikowski
Fri Jun 14, 2019 6:00 pm
Can you post your extension module code?
My version of the GMP extension module uses strings to store BIGINT values. The GMP library ADD, SUB and MJL does math on these numeric strings.
Your LET is confusing to me.
Last edited by John_Spikowski on Fri Jun 14, 2019 6:11 pm, edited 1 time in total.
Fri Jun 14, 2019 6:09 pm
This is getting messy.
Posting code snippets back and forth, in different languages, is confusing.
It would go easier if ScriptBasic including the current big integer extension module were in a Github repo that we could clone and play with. Or perhaps BitBucket or whatever.
At the end of the day the fibo equations we have been using are very simple.
I'd start testing with some simple x * y stuff.
hippy
Fri Jun 14, 2019 6:15 pm
That's all here - viewtopic.php?f=31&t=240287&start=350#p1479573
The only change was to add a "-lgmp" into interface.c so it would link with the gmp library.
John_Spikowski
Fri Jun 14, 2019 6:16 pm
The current SB GMP extension module code is on RaspberryBASIC.org forum. I'll push it to the ScriptBasic Extensions Sandbox today. it's the same code I have been posting here.
Fri Jun 14, 2019 6:29 pm
Yeah, yeah but a linking us to a git repo would be better.
You know:
$ git clone https://github.com/ScriptBasic/ScriptBasic.git
$ cd ScriptBasic
$ ./configure
$ make
$ sudo make install
Then:
$ cd
$ scriba fibo.bas
hippy
Fri Jun 14, 2019 6:41 pm
This one ... ?
::ix_let expects a string as a parameter, ::ix_asString converts the bigintFibo[n] to that string.
Because bigintFibos[n] isn't a string, it's a pointer, which happens to be a integer/long in the case of Python/ScriptBasic. One cannot pass a pointer/integer/long into my library when it is expecting a string.
ejolson
Fri Jun 14, 2019 7:01 pm
jahboater wrote:
Fri Jun 14, 2019 7:06 am
The problem is, as always, mixing two languages where one language has a richer choice of data types than the other.
Rather than converting the big numbers back and forth between strings, it would be more efficient (and probably less error prone) to pass back a handle in the form of an integer and let the C code keep track of the GMP big numbers to which each handle corresponds.
John_Spikowski
Fri Jun 14, 2019 7:12 pm
I would like to keep BIGINT in base 10 numeric strings. This will allow me to scale down a BIGINT environment by dividing it and using standard math functions for further processing. GMP is a BIGINT transport library in a sense.
Last edited by John_Spikowski on Fri Jun 14, 2019 7:17 pm, edited 1 time in total.
Fri Jun 14, 2019 7:15 pm
Of course that integer "handle" could just be a pointer :)
But, my demo in C shows that it can be done with the "user space" program only ever seeing stings. Performance was up there with some other languages. Given that most of the work is in the big arithmetic ScriptBasic should be up there with them.
John_Spikowski
Fri Jun 14, 2019 8:36 pm
Here is my latest attempt.
function hfibo(n)
  if n <= 2 THEN
    hfibo = n
  else
    k = n / 2
    fk = hfibo(k)
    fk1 = hfibo(BI_ADD(k, 1))
    if n % 2 = 0 then
      a = BI_ADD(fk1, fk1)
      b = BI_SUB(a, fk)
      r = BI_MUL(fk, b)
    else
      a = BI_MUL(fk, fk)
      b = BI_MUL(fk1, fk1)
      r = BI_ADD(a, b)
    end if
  end if
  hfibo = r
end function
SPLIT "0,0,0,0,0,0" BY "," TO k, a, b, r, fk, fk1
PRINT hfibo(78),"\n"
It returns zero. :o
John_Spikowski
Fri Jun 14, 2019 8:54 pm
This non-GMP version also prints zero. Lets try to get this non-BIGINT version going first.
function hfibo(n)
  if n <= 2 THEN
    hfibo = n
  else
    k = n / 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
ejolson
Fri Jun 14, 2019 9:02 pm
function hfibo(n)
  if n <= 2 THEN
    hfibo = n
  else
    k = n / 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
Try changing
k = n / 2
to
k = int(n / 2)
and see if that helps.
hippy
Fri Jun 14, 2019 9:04 pm
It is.
John_Spikowski
Fri Jun 14, 2019 9:07 pm
I changed it to
k = n \ 2
Integer divide and still returns zero.
ejolson
Fri Jun 14, 2019 9:23 pm
It is. The casting has to be done within the library because it cannot be done in Python.
The advantage of using integer handles that are not pointers is that one can get by with a much smaller number of bits. This enables sensible range checking to avoid segmentation faults and increases compatibility with languages that don't support integers the size of pointers. Luckily lci has not implemented the semantics for
I CAN HAS GMP?
in a way that would allow dynamic linking to external subroutine libraries.
When a programming language lacks the expressive power necessary to convey an algorithm as complicated as Karatsuba efficiently to the processor, it is liberating to be able to call subroutines written in other languages. At the same time, the requirement to master multiple languages makes it more difficult to avoid the digital apocalypse.
ejolson
Fri Jun 14, 2019 9:25 pm
I changed it to
k = n \ 2
What happens if you change the line
hfibo = n
to
r = n
near the beginning of the hfibo function?
John_Spikowski
Fri Jun 14, 2019 9:33 pm
It's printing a negative value.
function hfibo(n)
  if n <= 2 THEN
    r = n
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
PRINT FORMAT("%.f",hfibo(78)),"\n"
jrs@jrs-laptop:~/sb/GMP$ scriba nfibo.sb
-45717905866441093021696
ejolson
Fri Jun 14, 2019 9:35 pm
function hfibo(n)
  if n <= 2 THEN
    r = n
  else
    k = n \ 2
    fk = hfibo(k)
    fk1 = hfibo(k + 1)
    if n % 2 = 0 then
      a = fk1 + fk1
      b = a - fk
      r = fk * b
    else
      a = fk * fk
      b = fk1 * fk1
      r = a + b
    end if
  end if
  hfibo = r
end function
Does F(31) work?
