usernamechanel
log in not starting raspberry pi with prynth?
Wed Apr 17, 2019 8:31 pm
I am currently using prynth image. documentation here: https://prynth.github.io/doc/
A start up window beings when i turn the pi on, but asks for my username and pw. however, when i do put these in correctly it then just displays:
pi@raspberrypi:~ $
what command do i do so i can get onto the desktop GUI? I have a laptop and monitor connected to the pi. i am a complete beginner with pi but want to use prynth for sound stuff.
Andyroo
Re: log in not starting raspberry pi with prynth?
Wed Apr 17, 2019 8:58 pm
Two ways you can sort your issue:
Try startx as the command to get a GUI
Also you can run
sudo raspi-config
and then select boot options and set GUI start up.
Note this assumes you have a version of Raspbian and it’s not the Lite version (that does not have the GUI by default).
Need Pi spray - these things are breeding in my house...
B.Goode
Wed Apr 17, 2019 9:17 pm
pi@raspberrypi:~ $
See the documentation you have cited, under the heading Starting Prynth for the First Time
It seems the expectation is that you will access the Prynth system via a web browser, not directly via a desktop.
gkaiseril
Wed Apr 17, 2019 9:19 pm
When the Pi is set to boot into the command line, one can use the command:
startx
to start the provided desktop.
The command line command:
man startx
will provide more information about this command.
