LTolledo
Latest update/upgrade removed DAC audio from Kodi 18.1
Tue Apr 16, 2019 10:59 am
So I've updated and upgraded my RPi3B+ just a few minutes ago and then opened Kodi to watch my daily batch
no sound came from the DAC HAT audio
DAC is PiFi DAC from SainSmart (HiFiberry clone, using dtoverlay=hifiberry-dacplus)
it was working prior to update and upgrade.
exited Kodi and rebooted
upon reboot went directly to Kodi
checked the audio section, but the DAC audio selection was not there.
exited Kodi and checked if dac audio is enabled in Raspbian Desktop
it is selected and enabled.
to test audio output tried watching some Youtube video
true enough the audio passed thru the DAC on to my amp and vu meter setup.
turned off power and did a hard boot.
upon booting went directly to Kodi
same result as before... DAC audio not available.
any way to revert back the update and upgrade?
Some people be like:
LTolledo
Re: Latest update/upgrade removed DAC audio from Kodi 18.1
Tue Apr 16, 2019 2:23 pm
No go even after uninstalling and then re-installing Kodi
Luckily I have some Pimoroni pHAT DAC lying around...
test install temporarily (of course.... after powering down from AC source), removed the PiFi DAC, and in place installed the pHAT DAC.
DAC audio available in Raspbian Stretch with Desktop ( loosing the volume control though, but that is expected)
DAC audio now back in Kodi (well.... temporarily.... )
Hope a fix will be available in the next update/upgrade cycle......
Rascas
Tue Apr 16, 2019 9:13 pm
What packages got updated ? There is no Kodi update since 18.1, more than one month ago.
LTolledo
Tue Apr 16, 2019 11:07 pm
I did not see Kodi in the list of packages that was updated/upgraded
I think I saw something like libsound2 in the list....dont know if its relevant....
cannot reproduce it anymore unless there is a procedure to revert the update/upgrade
Rascas
Tue Apr 16, 2019 11:21 pm
Did the kernel/firmware got updated? Which kernel/firmware version are you running? Also please post a Kodi log with the dacplus connected.
LTolledo
Wed Apr 17, 2019 11:58 am
OK so I plugged in the PiFiDAC back and below are the "stats"
Kernel version
~ $ uname -a
Linux Raspi3BP1 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
below is the audio section of the config.txt file
The Pimoroni pHAT DAC was added yesterday during the test.
prior to the upgrade, both the RPi on-board audio and DAC were active and functional
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
disable_audio_dither=on
# iQAudio DAC+ Settings:
#dtoverlay=iqaudio-dacplus
#HifiBerry DAC Settings: (for SainSmartDAC):
#Pimoroni pHAT DAC Settings:
#dtoverlay=hifiberry-dac
Kodi full log (started Kodi, then closed it)
we all know that Kodi makes 2 sounds when it starts. Mine doesn't.
I also noticed in the logs that the DAC is not listed.
2019-04-17 20:37:09.419 T:1899969808  NOTICE: -----------------------------------------------------------------------
2019-04-17 20:37:09.419 T:1899969808  NOTICE: Starting Kodi (18.1 Git:20190220-5494e5ffac). Platform: Linux ARM 32-bit
2019-04-17 20:37:09.419 T:1899969808  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-04-17 20:37:09.419 T:1899969808  NOTICE: Kodi compiled 2019-02-22 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-04-17 20:37:09.419 T:1899969808  NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7+
2019-04-17 20:37:09.428 T:1899969808  NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-04-17 20:37:09.428 T:1899969808  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-04-17 20:37:09.428 T:1899969808  NOTICE: ARM Features: Neon enabled
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://envhome/ is mapped to: /home/pi
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-04-17 20:37:09.428 T:1899969808  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-04-17 20:37:09.428 T:1899969808  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-04-17 20:37:09.428 T:1899969808  NOTICE: Local hostname: Raspi3BP1
2019-04-17 20:37:09.428 T:1899969808  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-04-17 20:37:09.428 T:1899969808  NOTICE: -----------------------------------------------------------------------
2019-04-17 20:37:09.439 T:1899969808    INFO: loading settings
2019-04-17 20:37:09.440 T:1899969808  NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-04-17 20:37:09.470 T:1899969808   DEBUG: CSkinSettings: no <skinsettings> tag found
2019-04-17 20:37:09.470 T:1899969808  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2019-04-17 20:37:09.474 T:1899969808  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-04-17 20:37:09.475 T:1899969808  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <fanartres>720</fanartres>
                                              <imageres>540</imageres>
                                              <video>
                                                <busydialogdelayms>750</busydialogdelayms>
                                              </video>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <cache>
                                                <memorysize>31457280</memorysize>
                                              </cache>
                                            </advancedsettings>
2019-04-17 20:37:09.475 T:1899969808 WARNING: CSettingsManager: missing version attribute
2019-04-17 20:37:09.476 T:1899969808  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-04-17 20:37:09.476 T:1899969808  NOTICE: Default Video Player: VideoPlayer
2019-04-17 20:37:09.476 T:1899969808  NOTICE: Default Audio Player: paplayer
2019-04-17 20:37:09.477 T:1899969808  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-04-17 20:37:09.477 T:1899969808  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-04-17 20:37:09.589 T:1899969808  NOTICE: Running database version Addons27
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-04-17 20:37:09.680 T:1899969808  NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.local v1.0.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: skin.estouchy v2.0.22 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: skin.estuary v2.0.21 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.addon v18.1.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.json v10.1.2 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-04-17 20:37:09.681 T:1899969808  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-04-17 20:37:09.721 T:1899969808   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-04-17 20:37:09.943 T:1868559072  NOTICE: Found 2 Lists of Devices
2019-04-17 20:37:09.943 T:1868559072  NOTICE: Enumerated ALSA devices:
2019-04-17 20:37:09.943 T:1868559072  NOTICE:     Device 1
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_deviceName      : @
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2019-04-17 20:37:09.944 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-17 20:37:09.944 T:1868559072  NOTICE: Enumerated PI devices:
2019-04-17 20:37:09.944 T:1868559072  NOTICE:     Device 1
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_deviceName      : HDMI
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_displayName     : HDMI
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-04-17 20:37:09.945 T:1868559072  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-04-17 20:37:09.945 T:1868559072  NOTICE:     Device 2
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_deviceName      : Analogue
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_displayName     : Analogue
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_sampleRates     : 48000
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-17 20:37:09.946 T:1868559072  NOTICE:     Device 3
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_deviceName      : Both
2019-04-17 20:37:09.946 T:1868559072  NOTICE:         m_displayName     : HDMI and Analogue
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_sampleRates     : 48000
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-17 20:37:09.947 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-17 20:37:10.114 T:1899969808  NOTICE: Raspberry PI firmware version: Mar 27 2019 15:45:53
                                            Copyright (c) 2012 Broadcom
                                            version 2e98b31d18547962e564bdf88e57b3df7085c29b (clean) (release) (start)
2019-04-17 20:37:10.114 T:1899969808  NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-04-17 20:37:10.114 T:1899969808  NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-04-17 20:37:10.114 T:1899969808  NOTICE: Config:
                                            aphy_params_current=819
                                            arm_freq=1400
                                            audio_pwm_mode=514
                                            config_hdmi_boost=5
                                            core_freq=400
                                            desired_osc_freq=0x331df0
                                            desired_osc_freq_boost=0x3c45b0
                                            disable_commandline_tags=2
                                            disable_l2cache=1
                                            display_hdmi_rotate=-1
                                            display_lcd_rotate=-1
                                            dphy_params_current=547
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_ignore_alpha=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_drive=2
                                            hdmi_force_cec_address=65535
                                            hdmi_force_hotplug=1
                                            init_uart_clock=0x2dc6c00
                                            lcd_framerate=60
                                            over_voltage_avs=62500
                                            over_voltage_avs_boost=0x27ac4
                                            pause_burst_frames=1
                                            program_serial_random=1
                                            sdram_freq=450
                                            device_tree=-
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 75.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940063 Hz
2019-04-17 20:37:10.116 T:1899969808  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940063 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940063 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2019-04-17 20:37:10.117 T:1899969808  NOTICE: Found (1920x1080@60.000000) at 29, setting to RES_DESKTOP at 16
2019-04-17 20:37:10.117 T:1899969808  NOTICE: EGL_VERSION = 1.4
2019-04-17 20:37:10.117 T:1899969808  NOTICE: EGL_VENDOR = Broadcom
2019-04-17 20:37:10.118 T:1899969808  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
2019-04-17 20:37:10.118 T:1899969808  NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-04-17 20:37:10.120 T:1899969808  NOTICE: Checking resolution 16
2019-04-17 20:37:10.308 T:1899969808  NOTICE: GL_VENDOR = Broadcom
2019-04-17 20:37:10.308 T:1899969808  NOTICE: GL_RENDERER = VideoCore IV HW
2019-04-17 20:37:10.308 T:1899969808  NOTICE: GL_VERSION = OpenGL ES 2.0
2019-04-17 20:37:10.308 T:1899969808  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-04-17 20:37:10.308 T:1899969808  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
2019-04-17 20:37:11.507 T:1774600928  NOTICE: Running database version Addons27
2019-04-17 20:37:11.510 T:1774600928  NOTICE: Running database version ViewModes6
2019-04-17 20:37:11.513 T:1774600928  NOTICE: Running database version Textures13
2019-04-17 20:37:11.522 T:1774600928  NOTICE: Running database version MyMusic72
2019-04-17 20:37:11.536 T:1774600928  NOTICE: Running database version MyVideos116
2019-04-17 20:37:11.540 T:1774600928  NOTICE: Running database version TV32
2019-04-17 20:37:11.543 T:1774600928  NOTICE: Running database version Epg12
2019-04-17 20:37:11.545 T:1899969808  NOTICE: start dvd mediatype detection
2019-04-17 20:37:11.623 T:1899969808  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.21)
2019-04-17 20:37:12.281 T:1899969808 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-04-17 20:37:12.368 T:1899969808  NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-04-17 20:37:12.369 T:1899969808  NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-04-17 20:37:12.373 T:1899969808  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-04-17 20:37:12.375 T:1899969808  NOTICE: Loaded playercorefactory configuration
2019-04-17 20:37:12.377 T:1899969808  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-04-17 20:37:12.378 T:1899969808  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-04-17 20:37:12.414 T:1899969808  NOTICE: initialize done
2019-04-17 20:37:12.415 T:1899969808  NOTICE: Running the application...
2019-04-17 20:37:12.426 T:1899969808  NOTICE: starting zeroconf publishing
2019-04-17 20:37:12.427 T:1899969808  NOTICE: CWebServer[8080]: Started
2019-04-17 20:37:12.430 T:1657778912  NOTICE: ES: Starting UDP Event server on port 9777
2019-04-17 20:37:12.431 T:1657778912  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-04-17 20:37:12.439 T:1899969808  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-17 20:37:12.447 T:1899969808  NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2019-04-17 20:37:12.471 T:1622708960  NOTICE: Creating InputStream
2019-04-17 20:37:12.477 T:1622708960   ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2019-04-17 20:37:12.477 T:1622708960  NOTICE: CVideoPlayer::OnExit()
2019-04-17 20:37:12.614 T:1726505696  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2019-04-17 20:37:13.085 T:1899969808  NOTICE: CVideoPlayer::CloseFile()
2019-04-17 20:37:13.086 T:1899969808  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-17 20:37:13.086 T:1899969808  NOTICE: VideoPlayer: finished waiting
2019-04-17 20:37:13.138 T:1899969808 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.25s)
2019-04-17 20:37:22.044 T:1899969808 WARNING: CGUIWindowManager - HandleAction - ignoring action 92, because topmost modal dialog closing animation is running
2019-04-17 20:37:31.901 T:1899969808  NOTICE: stop player
2019-04-17 20:37:31.901 T:1899969808  NOTICE: Storing total System Uptime
2019-04-17 20:37:31.902 T:1899969808  NOTICE: Saving settings
2019-04-17 20:37:31.918 T:1899969808  NOTICE: Saving skin settings
2019-04-17 20:37:31.922 T:1899969808  NOTICE: stop all
2019-04-17 20:37:31.923 T:1899969808  NOTICE: ES: Stopping event server
2019-04-17 20:37:31.923 T:1899969808  NOTICE: stopping zeroconf publishing
2019-04-17 20:37:31.933 T:1899969808  NOTICE: CWebServer[8080]: Stopped
2019-04-17 20:37:32.451 T:1657778912  NOTICE: ES: UDP Event server stopped
2019-04-17 20:37:32.455 T:1899969808  NOTICE: stop dvd detect media
2019-04-17 20:37:32.696 T:1899969808  NOTICE: stopped
2019-04-17 20:37:32.897 T:1899969808  NOTICE: destroy
2019-04-17 20:37:34.364 T:1899969808  NOTICE: unload skin
2019-04-17 20:37:34.438 T:1899969808  NOTICE: unload sections
2019-04-17 20:37:35.017 T:1899969808  NOTICE: application stopped...
Again there is audio from DAC if I watch YouTube videos
but no DAC audio from Kodi
Note: its the same RPi3B+ that has its Kodi logs in the Kodi forum (Re: Delay in returning to menu after watching video)
below is the snippet from that Kodi log
2019-03-02 17:38:59.163 T:1899277584   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-03-02 17:38:59.429 T:1868559088  NOTICE: Found 2 Lists of Devices
2019-03-02 17:38:59.430 T:1868559088  NOTICE: Enumerated ALSA devices:
2019-03-02 17:38:59.430 T:1868559088  NOTICE:     Device 1
2019-03-02 17:38:59.430 T:1868559088  NOTICE:         m_deviceName      : @
2019-03-02 17:38:59.430 T:1868559088  NOTICE:         m_displayName     : Default (snd_rpi_hifiberry_dacplus Analog)
2019-03-02 17:38:59.430 T:1868559088  NOTICE:         m_displayNameExtra:
2019-03-02 17:38:59.430 T:1868559088  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_channels        : FL, FR
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-03-02 17:38:59.431 T:1868559088  NOTICE: Enumerated PI devices:
2019-03-02 17:38:59.431 T:1868559088  NOTICE:     Device 1
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_deviceName      : HDMI
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_displayName     : HDMI
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_displayNameExtra:
2019-03-02 17:38:59.431 T:1868559088  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-03-02 17:38:59.432 T:1868559088  NOTICE:         m_channels        : FL, FR
2019-03-02 17:38:59.432 T:1868559088  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-03-02 17:38:59.432 T:1868559088  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-03-02 17:38:59.432 T:1868559088  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-03-02 17:38:59.432 T:1868559088  NOTICE:     Device 2
2019-03-02 17:38:59.432 T:1868559088  NOTICE:         m_deviceName      : Analogue
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_displayName     : Analogue
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_displayNameExtra:
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_channels        : FL, FR
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_sampleRates     : 48000
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-03-02 17:38:59.433 T:1868559088  NOTICE:     Device 3
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_deviceName      : Both
2019-03-02 17:38:59.433 T:1868559088  NOTICE:         m_displayName     : HDMI and Analogue
2019-03-02 17:38:59.434 T:1868559088  NOTICE:         m_channels        : FL, FR
2019-03-02 17:38:59.434 T:1868559088  NOTICE:         m_sampleRates     : 48000
2019-03-02 17:38:59.434 T:1868559088  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-03-02 17:38:59.434 T:1868559088  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-03-02 17:38:59.646 T:1899277584  NOTICE: Raspberry PI firmware version: Feb 12 2019 19:42:42
                                            version 8eff5e4023657a8b3b59e1f90dc966f62d74908c (clean) (release) (start)
2019-03-02 17:38:59.646 T:1899277584  NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-03-02 17:38:59.646 T:1899277584  NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-03-02 17:38:59.646 T:1899277584  NOTICE: Config:
                                            arm_freq=1400
                                            audio_pwm_mode=514
                                            config_hdmi_boost=5
                                            core_freq=400
                                            disable_l2cache=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_drive=2
                                            lcd_framerate=60
                                            over_voltage_avs=0x19f0a
                                            over_voltage_avs_boost=0x325aa
                                            sdram_freq=450
                                            device_tree=-
LTolledo
Wed Apr 17, 2019 12:29 pm
Some intriguing developments
disabled the RPi on-board audio in config.txt
#dtparam=audio=on
#disable_audio_dither=on
# iQAudio Sound Card Settings:
#HifiBerry DAC Sound Card Settings: (for SainSmartDAC)
#Pimoroni pHAT DAC settings
I do have DAC audio, but the RPi on-board audio is now missing from desktop audio source selection
then I started Kodi, the usual 2-tone audio greeting emanated from the speakers.
below is the full Kodi log from the last attempt (when Kodi sounded)
2019-04-17 21:15:44.800 T:1899289872  NOTICE: -----------------------------------------------------------------------
2019-04-17 21:15:44.800 T:1899289872  NOTICE: Starting Kodi (18.1 Git:20190220-5494e5ffac). Platform: Linux ARM 32-bit
2019-04-17 21:15:44.800 T:1899289872  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-04-17 21:15:44.800 T:1899289872  NOTICE: Kodi compiled 2019-02-22 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-04-17 21:15:44.801 T:1899289872  NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7+
2019-04-17 21:15:44.809 T:1899289872  NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-04-17 21:15:44.809 T:1899289872  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-04-17 21:15:44.809 T:1899289872  NOTICE: ARM Features: Neon enabled
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://envhome/ is mapped to: /home/pi
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-04-17 21:15:44.809 T:1899289872  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-04-17 21:15:44.810 T:1899289872  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-04-17 21:15:44.810 T:1899289872  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-04-17 21:15:44.810 T:1899289872  NOTICE: Local hostname: Raspi3BP1
2019-04-17 21:15:44.810 T:1899289872  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-04-17 21:15:44.810 T:1899289872  NOTICE: -----------------------------------------------------------------------
2019-04-17 21:15:44.821 T:1899289872    INFO: loading settings
2019-04-17 21:15:44.822 T:1899289872  NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-04-17 21:15:44.855 T:1899289872   DEBUG: CSkinSettings: no <skinsettings> tag found
2019-04-17 21:15:44.855 T:1899289872  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2019-04-17 21:15:44.860 T:1899289872  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-04-17 21:15:44.860 T:1899289872  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <samba>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
2019-04-17 21:15:44.860 T:1899289872 WARNING: CSettingsManager: missing version attribute
2019-04-17 21:15:44.862 T:1899289872  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-04-17 21:15:44.862 T:1899289872  NOTICE: Default Video Player: VideoPlayer
2019-04-17 21:15:44.862 T:1899289872  NOTICE: Default Audio Player: paplayer
2019-04-17 21:15:44.862 T:1899289872  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-04-17 21:15:44.862 T:1899289872  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-04-17 21:15:44.985 T:1899289872  NOTICE: Running database version Addons27
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-04-17 21:15:45.131 T:1899289872  NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.local v1.0.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: skin.estouchy v2.0.22 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: skin.estuary v2.0.21 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.addon v18.1.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.json v10.1.2 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-04-17 21:15:45.132 T:1899289872  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-04-17 21:15:45.186 T:1899289872   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-04-17 21:15:45.476 T:1868559072  NOTICE: Found 2 Lists of Devices
2019-04-17 21:15:45.476 T:1868559072  NOTICE: Enumerated ALSA devices:
2019-04-17 21:15:45.476 T:1868559072  NOTICE:     Device 1
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_deviceName      : @
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_displayName     : Default (snd_rpi_hifiberry_dacplus Analog)
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-17 21:15:45.476 T:1868559072  NOTICE: Enumerated PI devices:
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_deviceName      : HDMI
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_displayName     : HDMI
2019-04-17 21:15:45.476 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-04-17 21:15:45.477 T:1868559072  NOTICE:     Device 2
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_deviceName      : Analogue
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_displayName     : Analogue
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_sampleRates     : 48000
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-17 21:15:45.477 T:1868559072  NOTICE:     Device 3
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_deviceName      : Both
2019-04-17 21:15:45.477 T:1868559072  NOTICE:         m_displayName     : HDMI and Analogue
2019-04-17 21:15:45.639 T:1899289872  NOTICE: Raspberry PI firmware version: Mar 27 2019 15:45:53
2019-04-17 21:15:45.640 T:1899289872  NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-04-17 21:15:45.640 T:1899289872  NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-04-17 21:15:45.640 T:1899289872  NOTICE: Config:
                                            arm_freq=1400
                                            audio_pwm_mode=514
                                            config_hdmi_boost=5
                                            core_freq=400
                                            disable_l2cache=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_drive=2
                                            lcd_framerate=60
                                            over_voltage_avs_boost=0x2932e
                                            sdram_freq=450
                                            device_tree=-
2019-04-17 21:15:45.641 T:1899289872  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 75.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940063 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2019-04-17 21:15:45.642 T:1899289872  NOTICE: Found (1920x1080@60.000000) at 29, setting to RES_DESKTOP at 16
2019-04-17 21:15:45.643 T:1899289872  NOTICE: EGL_VERSION = 1.4
2019-04-17 21:15:45.643 T:1899289872  NOTICE: EGL_VENDOR = Broadcom
2019-04-17 21:15:45.643 T:1899289872  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
2019-04-17 21:15:45.643 T:1899289872  NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-04-17 21:15:45.646 T:1899289872  NOTICE: Checking resolution 16
2019-04-17 21:15:45.830 T:1899289872  NOTICE: GL_VENDOR = Broadcom
2019-04-17 21:15:45.830 T:1899289872  NOTICE: GL_RENDERER = VideoCore IV HW
2019-04-17 21:15:45.830 T:1899289872  NOTICE: GL_VERSION = OpenGL ES 2.0
2019-04-17 21:15:45.830 T:1899289872  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-04-17 21:15:45.830 T:1899289872  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
2019-04-17 21:15:47.491 T:1776698080  NOTICE: Running database version Addons27
2019-04-17 21:15:47.494 T:1776698080  NOTICE: Running database version ViewModes6
2019-04-17 21:15:47.497 T:1776698080  NOTICE: Running database version Textures13
2019-04-17 21:15:47.505 T:1776698080  NOTICE: Running database version MyMusic72
2019-04-17 21:15:47.519 T:1776698080  NOTICE: Running database version MyVideos116
2019-04-17 21:15:47.523 T:1776698080  NOTICE: Running database version TV32
2019-04-17 21:15:47.526 T:1776698080  NOTICE: Running database version Epg12
2019-04-17 21:15:47.527 T:1899289872  NOTICE: start dvd mediatype detection
2019-04-17 21:15:47.601 T:1899289872  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.21)
2019-04-17 21:15:48.325 T:1899289872 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-04-17 21:15:48.430 T:1899289872  NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-04-17 21:15:48.432 T:1899289872  NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-04-17 21:15:48.434 T:1899289872  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-04-17 21:15:48.441 T:1899289872  NOTICE: Loaded playercorefactory configuration
2019-04-17 21:15:48.442 T:1899289872  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-04-17 21:15:48.442 T:1899289872  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-04-17 21:15:48.503 T:1899289872  NOTICE: initialize done
2019-04-17 21:15:48.503 T:1899289872  NOTICE: Running the application...
2019-04-17 21:15:48.536 T:1899289872  NOTICE: starting zeroconf publishing
2019-04-17 21:15:48.537 T:1899289872  NOTICE: CWebServer[8080]: Started
2019-04-17 21:15:48.549 T:1656726240  NOTICE: ES: Starting UDP Event server on port 9777
2019-04-17 21:15:48.550 T:1656726240  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-04-17 21:15:48.577 T:1899289872  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-17 21:15:48.600 T:1899289872  NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2019-04-17 21:15:48.612 T:1617756896  NOTICE: Creating InputStream
2019-04-17 21:15:48.612 T:1617756896   ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2019-04-17 21:15:48.612 T:1617756896  NOTICE: CVideoPlayer::OnExit()
2019-04-17 21:15:48.707 T:1726726880  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2019-04-17 21:15:49.156 T:1899289872  NOTICE: CVideoPlayer::CloseFile()
2019-04-17 21:15:49.156 T:1899289872  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-17 21:15:49.156 T:1899289872  NOTICE: VideoPlayer: finished waiting
2019-04-17 21:15:49.206 T:1899289872 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.25s)
2019-04-17 21:16:11.571 T:1899289872  NOTICE: stop player
2019-04-17 21:16:11.571 T:1899289872  NOTICE: Storing total System Uptime
2019-04-17 21:16:11.571 T:1899289872  NOTICE: Saving settings
2019-04-17 21:16:11.587 T:1899289872  NOTICE: Saving skin settings
2019-04-17 21:16:11.591 T:1899289872  NOTICE: stop all
2019-04-17 21:16:11.592 T:1899289872  NOTICE: ES: Stopping event server
2019-04-17 21:16:11.592 T:1899289872  NOTICE: stopping zeroconf publishing
2019-04-17 21:16:11.603 T:1899289872  NOTICE: CWebServer[8080]: Stopped
2019-04-17 21:16:12.575 T:1656726240  NOTICE: ES: UDP Event server stopped
2019-04-17 21:16:12.578 T:1899289872  NOTICE: stop dvd detect media
2019-04-17 21:16:12.815 T:1899289872  NOTICE: stopped
2019-04-17 21:16:13.016 T:1899289872  NOTICE: destroy
2019-04-17 21:16:15.423 T:1899289872  NOTICE: unload skin
2019-04-17 21:16:15.492 T:1899289872  NOTICE: unload sections
2019-04-17 21:16:16.203 T:1899289872  NOTICE: application stopped...
so this means that after the last Raspbian Stretch update/upgrade, whenever I enable RPi on-board audio in config.txt Kodi now disregards DAC settings...... why?
Oh well... might as well enjoy it for now.... until the fix is discovered....and deployed....
Rascas
Wed Apr 17, 2019 1:47 pm
#dtparam=audio=on
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <samba>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
                                            arm_freq=1400
                                            audio_pwm_mode=514
                                            config_hdmi_boost=5
                                            core_freq=400
                                            disable_l2cache=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_drive=2
                                            lcd_framerate=60
                                            sdram_freq=450
                                            device_tree=-
I don't have a Hifiberry or clone anymore to test, but I do recall that I disabled the onboard audio when configuring it, according to this:
https://www.hifiberry.com/build/documen ... ux-3-18-x/
I don't remember if it was really necessary for the board to work in Kodi though. If it worked for you before and now it doesn't, I recommend that you open an issue about that here:
https://github.com/RPi-Distro/repo/issues
Below is the latest kernel/firmware, which is probably where the problem is:
pi@rpi3-pcstudio:~ $ vcgencmd version
Mar 27 2019 15:48:59
version 2e98b31d18547962e564bdf88e57b3df7085c29b (clean) (release) (start_x)
pi@rpi3-pcstudio:~ $ uname -a
Linux rpi3-pcstudio 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
ShiftPlusOne
Wed Apr 17, 2019 1:52 pm
Before filing an issue it would be good to narrow it down to the responsible package, because I won't be able to reproduce it.
LTolledo
Wed Apr 17, 2019 10:00 pm
Some further "confirmation" test
This time I've plugged the Pimoroni pHAT DAC back
dtparam=audio=on
#dtoverlay=hifiberry-dacplus
Raspbian Desktop has Analog, HDMI and snd_rpi_hifiberry_dac in the audio selection menu, with the DAC selected as audio output.
Audio from YouTube played over the DAC audio.. OK
then back to Kodi
the 2-tone greeting when Kodi starts was absent this time. So there is no DAC audio
full Kodi log below:
2019-04-18 06:48:11.932 T:1899343120  NOTICE: -----------------------------------------------------------------------
2019-04-18 06:48:11.932 T:1899343120  NOTICE: Starting Kodi (18.1 Git:20190220-5494e5ffac). Platform: Linux ARM 32-bit
2019-04-18 06:48:11.932 T:1899343120  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-04-18 06:48:11.932 T:1899343120  NOTICE: Kodi compiled 2019-02-22 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-04-18 06:48:11.932 T:1899343120  NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98-v7+
2019-04-18 06:48:11.941 T:1899343120  NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-04-18 06:48:11.941 T:1899343120  NOTICE: Host CPU: ARMv7 Processor rev 4 (v7l), 4 cores available
2019-04-18 06:48:11.941 T:1899343120  NOTICE: ARM Features: Neon enabled
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://envhome/ is mapped to: /home/pi
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-04-18 06:48:11.941 T:1899343120  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-04-18 06:48:11.941 T:1899343120  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi_v7
2019-04-18 06:48:11.941 T:1899343120  NOTICE: Local hostname: Raspi3BP1
2019-04-18 06:48:11.941 T:1899343120  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-04-18 06:48:11.941 T:1899343120  NOTICE: -----------------------------------------------------------------------
2019-04-18 06:48:11.952 T:1899343120    INFO: loading settings
2019-04-18 06:48:11.953 T:1899343120  NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-04-18 06:48:11.982 T:1899343120   DEBUG: CSkinSettings: no <skinsettings> tag found
2019-04-18 06:48:11.983 T:1899343120  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2019-04-18 06:48:11.987 T:1899343120  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-04-18 06:48:11.987 T:1899343120  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <advancedsettings>
                                              <video>
                                              </video>
                                              <samba>
                                              </samba>
                                              <cache>
                                              </cache>
                                            </advancedsettings>
2019-04-18 06:48:11.987 T:1899343120 WARNING: CSettingsManager: missing version attribute
2019-04-18 06:48:11.989 T:1899343120  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-04-18 06:48:11.989 T:1899343120  NOTICE: Default Video Player: VideoPlayer
2019-04-18 06:48:11.989 T:1899343120  NOTICE: Default Audio Player: paplayer
2019-04-18 06:48:11.989 T:1899343120  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-04-18 06:48:11.989 T:1899343120  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-04-18 06:48:12.101 T:1899343120  NOTICE: Running database version Addons27
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-04-18 06:48:12.191 T:1899343120  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.local v1.0.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: skin.estouchy v2.0.22 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: skin.estuary v2.0.21 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: xbmc.addon v18.1.0 installed
2019-04-18 06:48:12.192 T:1899343120  NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-04-18 06:48:12.193 T:1899343120  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-04-18 06:48:12.193 T:1899343120  NOTICE: ADDON: xbmc.json v10.1.2 installed
2019-04-18 06:48:12.193 T:1899343120  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-04-18 06:48:12.193 T:1899343120  NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-04-18 06:48:12.193 T:1899343120  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-04-18 06:48:12.233 T:1899343120   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-04-18 06:48:12.435 T:1868559072  NOTICE: Found 2 Lists of Devices
2019-04-18 06:48:12.436 T:1868559072  NOTICE: Enumerated ALSA devices:
2019-04-18 06:48:12.436 T:1868559072  NOTICE:     Device 1
2019-04-18 06:48:12.436 T:1868559072  NOTICE:         m_deviceName      : @
2019-04-18 06:48:12.436 T:1868559072  NOTICE:         m_displayName     : Default (bcm2835 ALSA bcm2835 ALSA)
2019-04-18 06:48:12.436 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_U8
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-18 06:48:12.437 T:1868559072  NOTICE: Enumerated PI devices:
2019-04-18 06:48:12.437 T:1868559072  NOTICE:     Device 1
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_deviceName      : HDMI
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_displayName     : HDMI
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-18 06:48:12.437 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-04-18 06:48:12.438 T:1868559072  NOTICE:     Device 2
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_deviceName      : Analogue
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_displayName     : Analogue
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_sampleRates     : 48000
2019-04-18 06:48:12.438 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-18 06:48:12.439 T:1868559072  NOTICE:     Device 3
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_deviceName      : Both
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_displayName     : HDMI and Analogue
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_displayNameExtra:
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_channels        : FL, FR
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_sampleRates     : 48000
2019-04-18 06:48:12.439 T:1868559072  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-18 06:48:12.617 T:1899343120  NOTICE: Raspberry PI firmware version: Mar 27 2019 15:45:53
2019-04-18 06:48:12.617 T:1899343120  NOTICE: ARM mem: 832MB GPU mem: 192MB MPG2:0 WVC1:0
2019-04-18 06:48:12.617 T:1899343120  NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-04-18 06:48:12.617 T:1899343120  NOTICE: Config:
                                            arm_freq=1400
                                            audio_pwm_mode=514
                                            config_hdmi_boost=5
                                            core_freq=400
                                            disable_l2cache=1
                                            force_eeprom_read=1
                                            force_pwm_open=1
                                            framebuffer_swap=1
                                            gpu_freq=300
                                            hdmi_drive=2
                                            lcd_framerate=60
                                            sdram_freq=450
                                            device_tree=-
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 75.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1024 x 768 with 1024 x 768 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1280 x 1024 with 1280 x 1024 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 720 x 480 with 720 x 480 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940063 Hz
2019-04-18 06:48:12.619 T:1899343120  NOTICE: Found resolution 720 x 576 with 720 x 576 @ 50.000000 Hz
2019-04-18 06:48:12.620 T:1899343120  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 50.000000 Hz
2019-04-18 06:48:12.620 T:1899343120  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 50.000000 Hz
2019-04-18 06:48:12.620 T:1899343120  NOTICE: Found (1920x1080@60.000000) at 29, setting to RES_DESKTOP at 16
2019-04-18 06:48:12.620 T:1899343120  NOTICE: EGL_VERSION = 1.4
2019-04-18 06:48:12.620 T:1899343120  NOTICE: EGL_VENDOR = Broadcom
2019-04-18 06:48:12.620 T:1899343120  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
2019-04-18 06:48:12.620 T:1899343120  NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-04-18 06:48:12.623 T:1899343120  NOTICE: Checking resolution 16
2019-04-18 06:48:12.796 T:1899343120  NOTICE: GL_VENDOR = Broadcom
2019-04-18 06:48:12.796 T:1899343120  NOTICE: GL_RENDERER = VideoCore IV HW
2019-04-18 06:48:12.796 T:1899343120  NOTICE: GL_VERSION = OpenGL ES 2.0
2019-04-18 06:48:12.796 T:1899343120  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-04-18 06:48:12.796 T:1899343120  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
2019-04-18 06:48:14.013 T:1774600928  NOTICE: Running database version Addons27
2019-04-18 06:48:14.016 T:1774600928  NOTICE: Running database version ViewModes6
2019-04-18 06:48:14.019 T:1774600928  NOTICE: Running database version Textures13
2019-04-18 06:48:14.028 T:1774600928  NOTICE: Running database version MyMusic72
2019-04-18 06:48:14.042 T:1774600928  NOTICE: Running database version MyVideos116
2019-04-18 06:48:14.046 T:1774600928  NOTICE: Running database version TV32
2019-04-18 06:48:14.050 T:1774600928  NOTICE: Running database version Epg12
2019-04-18 06:48:14.051 T:1899343120  NOTICE: start dvd mediatype detection
2019-04-18 06:48:14.127 T:1899343120  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.21)
2019-04-18 06:48:14.795 T:1899343120 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-04-18 06:48:14.933 T:1899343120  NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-04-18 06:48:14.935 T:1899343120  NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-04-18 06:48:14.940 T:1899343120  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-04-18 06:48:14.941 T:1899343120  NOTICE: Loaded playercorefactory configuration
2019-04-18 06:48:14.942 T:1899343120  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-04-18 06:48:14.942 T:1899343120  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-04-18 06:48:14.978 T:1899343120  NOTICE: initialize done
2019-04-18 06:48:14.978 T:1899343120  NOTICE: Running the application...
2019-04-18 06:48:14.987 T:1899343120  NOTICE: starting zeroconf publishing
2019-04-18 06:48:14.988 T:1899343120  NOTICE: CWebServer[8080]: Started
2019-04-18 06:48:14.989 T:1656726240  NOTICE: ES: Starting UDP Event server on port 9777
2019-04-18 06:48:14.992 T:1656726240  NOTICE: UDP: Listening on port 9777 (ipv6 : false)
2019-04-18 06:48:15.006 T:1899343120  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-18 06:48:15.015 T:1899343120  NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2019-04-18 06:48:15.026 T:1621918432  NOTICE: Creating InputStream
2019-04-18 06:48:15.027 T:1621918432   ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2019-04-18 06:48:15.027 T:1621918432  NOTICE: CVideoPlayer::OnExit()
2019-04-18 06:48:15.176 T:1725776608  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2019-04-18 06:48:15.618 T:1899343120  NOTICE: CVideoPlayer::CloseFile()
2019-04-18 06:48:15.618 T:1899343120  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-18 06:48:15.619 T:1899343120  NOTICE: VideoPlayer: finished waiting
2019-04-18 06:48:15.671 T:1899343120 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.25s)
2019-04-18 06:48:39.772 T:1899343120  NOTICE: stop player
2019-04-18 06:48:39.772 T:1899343120  NOTICE: Storing total System Uptime
2019-04-18 06:48:39.773 T:1899343120  NOTICE: Saving settings
2019-04-18 06:48:39.790 T:1899343120  NOTICE: Saving skin settings
2019-04-18 06:48:39.794 T:1899343120  NOTICE: stop all
2019-04-18 06:48:39.796 T:1899343120  NOTICE: ES: Stopping event server
2019-04-18 06:48:39.796 T:1899343120  NOTICE: stopping zeroconf publishing
2019-04-18 06:48:39.806 T:1899343120  NOTICE: CWebServer[8080]: Stopped
2019-04-18 06:48:40.019 T:1656726240  NOTICE: ES: UDP Event server stopped
2019-04-18 06:48:40.020 T:1899343120  NOTICE: stop dvd detect media
2019-04-18 06:48:40.239 T:1899343120  NOTICE: stopped
2019-04-18 06:48:40.440 T:1899343120  NOTICE: destroy
2019-04-18 06:48:42.925 T:1899343120  NOTICE: unload skin
2019-04-18 06:48:43.023 T:1899343120  NOTICE: unload sections
2019-04-18 06:48:43.648 T:1899343120  NOTICE: application stopped...
Can this be a confirmation that on the latest update/upgrade of Raspbian:
If RPi on-board audio and any DAC are both enabled in config.txt, DAC audio in Kodi 18.1 is "removed"
If RPi on-board audio is disabled, DAC only enabled in config.txt, DAC audio in Kodi 18.1 is retained.
I may not be able to pinpoint the responsible package that caused this anomaly, as I don't have a clue how to pinpoint it....
Some people be like:
LTolledo
Re: Latest update/upgrade removed DAC audio from Kodi 18.1
Sat Apr 20, 2019 11:47 pm
Just upgraded Raspbian Stretch on my Raspberry Pi 1B (c.2011, the SD type, not microSD type) to the latest version last night.
Its auto boot to Kodi 18.1. It has a 26-pin I2S DAC (hifiberry clone)
RPi's on-board audio (Analog, HDMI) is enabled at config.txt
DAC also enabled at config.txt
Upon booting to Kodi 18.1 the usual 2-tone greeting was heard.
checked the audio selection section, the on-board audio (analog and HDMI) as well as the DAC audio was present.
played some videos, and sure enough there was audio coming out from the DAC.
Full kodi log below
2019-04-21 08:02:19.007 T:2973890096  NOTICE: -----------------------------------------------------------------------
2019-04-21 08:02:19.007 T:2973890096  NOTICE: Starting Kodi (18.1 Git:20190220-5494e5ffac). Platform: Linux ARM 32-bit
2019-04-21 08:02:19.007 T:2973890096  NOTICE: Using Release Kodi x32 build (version for Raspberry Pi)
2019-04-21 08:02:19.008 T:2973890096  NOTICE: Kodi compiled 2019-02-22 by GCC 6.3.0 for Linux ARM 32-bit version 4.9.82 (264530)
2019-04-21 08:02:19.008 T:2973890096  NOTICE: Running on Raspbian GNU/Linux 9 (stretch), kernel: Linux ARM 32-bit version 4.14.98+
2019-04-21 08:02:19.034 T:2973890096  NOTICE: FFmpeg version/source: 4.0.3-Kodi
2019-04-21 08:02:19.034 T:2973890096  NOTICE: Host CPU: ARMv6-compatible processor rev 7 (v6l), 1 core available
2019-04-21 08:02:19.034 T:2973890096  NOTICE: ARM Features: Neon disabled
2019-04-21 08:02:19.034 T:2973890096  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
2019-04-21 08:02:19.034 T:2973890096  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi
2019-04-21 08:02:19.034 T:2973890096  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/arm-linux-gnueabihf/kodi/addons
2019-04-21 08:02:19.035 T:2973890096  NOTICE: special://masterprofile/ is mapped to: /home/pi/.kodi/userdata
2019-04-21 08:02:19.035 T:2973890096  NOTICE: special://envhome/ is mapped to: /home/pi
2019-04-21 08:02:19.035 T:2973890096  NOTICE: special://home/ is mapped to: /home/pi/.kodi
2019-04-21 08:02:19.035 T:2973890096  NOTICE: special://temp/ is mapped to: /home/pi/.kodi/temp
2019-04-21 08:02:19.035 T:2973890096  NOTICE: special://logpath/ is mapped to: /home/pi/.kodi/temp
2019-04-21 08:02:19.036 T:2973890096  NOTICE: The executable running is: /usr/lib/arm-linux-gnueabihf/kodi/kodi-rbpi
2019-04-21 08:02:19.036 T:2973890096  NOTICE: Local hostname: RasPi1B
2019-04-21 08:02:19.036 T:2973890096  NOTICE: Log File is located: /home/pi/.kodi/temp/kodi.log
2019-04-21 08:02:19.036 T:2973890096  NOTICE: -----------------------------------------------------------------------
2019-04-21 08:02:19.068 T:2973890096    INFO: loading settings
2019-04-21 08:02:19.080 T:2973890096  NOTICE: special://profile/ is mapped to: special://masterprofile/
2019-04-21 08:02:19.188 T:2973890096   DEBUG: CSkinSettings: no <skinsettings> tag found
2019-04-21 08:02:19.189 T:2973890096  NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
2019-04-21 08:02:19.195 T:2973890096   DEBUG: CMediaSourceSettings: <games> tag is missing or sources.xml is malformed
2019-04-21 08:02:19.201 T:2973890096  NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
2019-04-21 08:02:19.202 T:2973890096  NOTICE: Contents of special://xbmc/system/advancedsettings.xml are...
                                            <?xml version="1.0" encoding="UTF-8" ?>
                                            <advancedsettings>
                                              <fanartres>720</fanartres>
                                              <imageres>540</imageres>
                                              <video>
                                                <busydialogdelayms>750</busydialogdelayms>
                                              </video>
                                              <samba>
                                                <clienttimeout>30</clienttimeout>
                                              </samba>
                                              <cache>
                                                <memorysize>31457280</memorysize>
                                              </cache>
                                            </advancedsettings>
2019-04-21 08:02:19.203 T:2973890096 WARNING: CSettingsManager: missing version attribute
2019-04-21 08:02:19.207 T:2973890096  NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
2019-04-21 08:02:19.207 T:2973890096  NOTICE: Default Video Player: VideoPlayer
2019-04-21 08:02:19.208 T:2973890096  NOTICE: Default Audio Player: paplayer
2019-04-21 08:02:19.208 T:2973890096  NOTICE: Disabled debug logging due to GUI setting. Level 0.
2019-04-21 08:02:19.208 T:2973890096  NOTICE: Log level changed to "LOG_LEVEL_NORMAL"
2019-04-21 08:02:19.782 T:2973890096  NOTICE: Running database version Addons27
2019-04-21 08:02:20.066 T:2973890096  NOTICE: ADDON: audioencoder.kodi.builtin.aac v1.0.0 installed
2019-04-21 08:02:20.066 T:2973890096  NOTICE: ADDON: audioencoder.kodi.builtin.wma v1.0.0 installed
2019-04-21 08:02:20.066 T:2973890096  NOTICE: ADDON: game.controller.default v1.0.8 installed
2019-04-21 08:02:20.066 T:2973890096  NOTICE: ADDON: game.controller.snes v1.0.8 installed
2019-04-21 08:02:20.066 T:2973890096  NOTICE: ADDON: kodi.binary.global.audioengine v1.0.1 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.global.filesystem v1.0.2 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.global.general v1.0.3 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.global.gui v5.12.0 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.global.main v1.0.14 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.global.network v1.0.0 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.instance.audiodecoder v2.0.0 installed
2019-04-21 08:02:20.067 T:2973890096  NOTICE: ADDON: kodi.binary.instance.audioencoder v2.0.0 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.game v1.1.0 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.imagedecoder v2.0.0 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.inputstream v2.0.8 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.peripheral v1.3.7 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.pvr v5.10.3 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.screensaver v2.0.0 installed
2019-04-21 08:02:20.068 T:2973890096  NOTICE: ADDON: kodi.binary.instance.vfs v2.0.0 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: kodi.binary.instance.videocodec v1.0.1 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: kodi.binary.instance.visualization v2.0.1 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: kodi.resource v1.0.0 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: metadata.album.universal v3.1.1 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: metadata.artists.universal v4.3.0 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: metadata.common.allmusic.com v3.2.0 installed
2019-04-21 08:02:20.069 T:2973890096  NOTICE: ADDON: metadata.common.fanart.tv v3.6.1 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.common.imdb.com v3.1.4 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.common.musicbrainz.org v2.2.1 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.common.theaudiodb.com v2.0.2 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.common.themoviedb.org v3.1.9 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.local v1.0.0 installed
2019-04-21 08:02:20.070 T:2973890096  NOTICE: ADDON: metadata.themoviedb.org v5.1.7 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: metadata.tvdb.com v3.0.14 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: metadata.tvshows.themoviedb.org v3.1.0 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: repository.xbmc.org v3.1.5 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: resource.images.weathericons.default v1.1.8 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: resource.language.en_gb v2.0.1 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: resource.uisounds.kodi v1.0.0 installed
2019-04-21 08:02:20.071 T:2973890096  NOTICE: ADDON: screensaver.xbmc.builtin.black v1.0.32 installed
2019-04-21 08:02:20.072 T:2973890096  NOTICE: ADDON: screensaver.xbmc.builtin.dim v1.0.53 installed
2019-04-21 08:02:20.072 T:2973890096  NOTICE: ADDON: script.module.pil v1.1.7 installed
2019-04-21 08:02:20.072 T:2973890096  NOTICE: ADDON: script.module.pycryptodome v3.4.3 installed
2019-04-21 08:02:20.072 T:2973890096  NOTICE: ADDON: service.xbmc.versioncheck v0.4.6 installed
2019-04-21 08:02:20.072 T:2973890096  NOTICE: ADDON: skin.estouchy v2.0.22 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: skin.estuary v2.0.21 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: webinterface.default v18.x-2.4.6 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: xbmc.addon v18.1.0 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: xbmc.core v0.1.0 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: xbmc.gui v5.14.0 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: xbmc.json v10.1.2 installed
2019-04-21 08:02:20.073 T:2973890096  NOTICE: ADDON: xbmc.metadata v2.1.0 installed
2019-04-21 08:02:20.074 T:2973890096  NOTICE: ADDON: xbmc.python v2.26.0 installed
2019-04-21 08:02:20.074 T:2973890096  NOTICE: ADDON: xbmc.webinterface v1.0.0 installed
2019-04-21 08:02:21.533 T:2973890096   ERROR: DBus error: org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
2019-04-21 08:02:21.731 T:2945446624  NOTICE: Found 2 Lists of Devices
2019-04-21 08:02:21.731 T:2945446624  NOTICE: Enumerated ALSA devices:
2019-04-21 08:02:21.731 T:2945446624  NOTICE:     Device 1
2019-04-21 08:02:21.732 T:2945446624  NOTICE:         m_deviceName      : @
2019-04-21 08:02:21.732 T:2945446624  NOTICE:         m_displayName     : Default (snd_rpi_hifiberry_dac Analog)
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_displayNameExtra:
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_channels        : FL, FR
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_dataFormats     : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2019-04-21 08:02:21.733 T:2945446624  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-21 08:02:21.733 T:2945446624  NOTICE: Enumerated PI devices:
2019-04-21 08:02:21.734 T:2945446624  NOTICE:     Device 1
2019-04-21 08:02:21.734 T:2945446624  NOTICE:         m_deviceName      : HDMI
2019-04-21 08:02:21.734 T:2945446624  NOTICE:         m_displayName     : HDMI
2019-04-21 08:02:21.734 T:2945446624  NOTICE:         m_displayNameExtra:
2019-04-21 08:02:21.734 T:2945446624  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
2019-04-21 08:02:21.734 T:2945446624  NOTICE:         m_channels        : FL, FR
2019-04-21 08:02:21.735 T:2945446624  NOTICE:         m_sampleRates     : 8000,11025,16000,22050,24000,32000,44100,48000,88200,96000,176400,192000
2019-04-21 08:02:21.735 T:2945446624  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP,AE_FMT_RAW
2019-04-21 08:02:21.735 T:2945446624  NOTICE:         m_streamTypes     : STREAM_TYPE_AC3,STREAM_TYPE_EAC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_512
2019-04-21 08:02:21.735 T:2945446624  NOTICE:     Device 2
2019-04-21 08:02:21.735 T:2945446624  NOTICE:         m_deviceName      : Analogue
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_displayName     : Analogue
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_displayNameExtra:
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_channels        : FL, FR
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_sampleRates     : 48000
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-21 08:02:21.736 T:2945446624  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-21 08:02:21.737 T:2945446624  NOTICE:     Device 3
2019-04-21 08:02:21.737 T:2945446624  NOTICE:         m_deviceName      : Both
2019-04-21 08:02:21.737 T:2945446624  NOTICE:         m_displayName     : HDMI and Analogue
2019-04-21 08:02:21.737 T:2945446624  NOTICE:         m_displayNameExtra:
2019-04-21 08:02:21.737 T:2945446624  NOTICE:         m_deviceType      : AE_DEVTYPE_PCM
2019-04-21 08:02:21.738 T:2945446624  NOTICE:         m_channels        : FL, FR
2019-04-21 08:02:21.738 T:2945446624  NOTICE:         m_sampleRates     : 48000
2019-04-21 08:02:21.738 T:2945446624  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_S32LE,AE_FMT_S16LE,AE_FMT_FLOATP,AE_FMT_S32NEP,AE_FMT_S16NEP
2019-04-21 08:02:21.738 T:2945446624  NOTICE:         m_streamTypes     : No passthrough capabilities
2019-04-21 08:02:29.762 T:2973890096  NOTICE: Raspberry PI firmware version: Mar 27 2019 15:45:53
                                            Copyright (c) 2012 Broadcom
                                            version 2e98b31d18547962e564bdf88e57b3df7085c29b (clean) (release) (start)
2019-04-21 08:02:29.762 T:2973890096  NOTICE: ARM mem: 320MB GPU mem: 192MB MPG2:0 WVC1:0
2019-04-21 08:02:29.763 T:2973890096  NOTICE: cache.memorysize: 30MB libass.cache: 21MB
2019-04-21 08:02:29.763 T:2973890096  NOTICE: Config:
                                            aphy_params_current=547
                                            arm_freq=1000
                                            audio_pwm_mode=514
                                            config_hdmi_boost=2
                                            core_freq=500
                                            disable_auto_turbo=1
                                            disable_commandline_tags=2
                                            disable_splash=1
                                            display_hdmi_rotate=-1
                                            display_lcd_rotate=-1
                                            dphy_params_current=547
                                            force_pwm_open=1
                                            framebuffer_ignore_alpha=1
                                            framebuffer_swap=1
                                            hdmi_force_cec_address=65535
                                            hdmi_force_hotplug=1
                                            hdmi_group=2
                                            hdmi_mode=8
                                            ignore_lcd=1
                                            init_uart_clock=0x2dc6c00
                                            over_voltage=6
                                            pause_burst_frames=1
                                            program_serial_random=1
                                            sdram_freq=600
                                            second_boot=1
2019-04-21 08:02:29.764 T:2973890096  NOTICE: Config:
                                            device_tree=-
2019-04-21 08:02:29.766 T:2973890096  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 60.000000 Hz
2019-04-21 08:02:29.767 T:2973890096  NOTICE: Found resolution 640 x 480 with 640 x 480 @ 59.940063 Hz
2019-04-21 08:02:29.767 T:2973890096  NOTICE: Found resolution 800 x 600 with 800 x 600 @ 56.000000 Hz
2019-04-21 08:02:29.767 T:2973890096  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 60.000000 Hz
2019-04-21 08:02:29.767 T:2973890096  NOTICE: Found resolution 1280 x 720 with 1280 x 720 @ 59.940063 Hz
2019-04-21 08:02:29.767 T:2973890096  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 60.000000 Hz
2019-04-21 08:02:29.768 T:2973890096  NOTICE: Found resolution 1920 x 1080 with 1920 x 1080 @ 59.940063 Hz
2019-04-21 08:02:29.768 T:2973890096  NOTICE: Found (800x600@56.000000) at 18, setting to RES_DESKTOP at 16
2019-04-21 08:02:29.770 T:2973890096  NOTICE: EGL_VERSION = 1.4
2019-04-21 08:02:29.770 T:2973890096  NOTICE: EGL_VENDOR = Broadcom
2019-04-21 08:02:29.770 T:2973890096  NOTICE: EGL_EXTENSIONS = EGL_KHR_image EGL_KHR_image_base EGL_KHR_image_pixmap EGL_KHR_vg_parent_image EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_lock_surface
2019-04-21 08:02:29.770 T:2973890096  NOTICE: EGL_CLIENT_EXTENSIONS = NULL
2019-04-21 08:02:29.777 T:2973890096  NOTICE: Checking resolution 16
2019-04-21 08:02:29.974 T:2973890096  NOTICE: GL_VENDOR = Broadcom
2019-04-21 08:02:29.974 T:2973890096  NOTICE: GL_RENDERER = VideoCore IV HW
2019-04-21 08:02:29.974 T:2973890096  NOTICE: GL_VERSION = OpenGL ES 2.0
2019-04-21 08:02:29.974 T:2973890096  NOTICE: GL_SHADING_LANGUAGE_VERSION = OpenGL ES GLSL ES 1.00
2019-04-21 08:02:29.975 T:2973890096  NOTICE: GL_EXTENSIONS = GL_OES_compressed_ETC1_RGB8_texture GL_OES_compressed_paletted_texture GL_OES_texture_npot GL_OES_depth24 GL_OES_vertex_half_float GL_OES_EGL_image GL_OES_EGL_image_external GL_EXT_discard_framebuffer GL_OES_rgb8_rgba8 GL_OES_depth32 GL_OES_mapbuffer GL_EXT_texture_format_BGRA8888 GL_APPLE_rgb_422 GL_EXT_debug_marker
2019-04-21 08:02:32.290 T:2858779360  NOTICE: Running database version Addons27
2019-04-21 08:02:32.307 T:2858779360  NOTICE: Running database version ViewModes6
2019-04-21 08:02:32.315 T:2858779360  NOTICE: Running database version Textures13
2019-04-21 08:02:32.341 T:2858779360  NOTICE: Running database version MyMusic72
2019-04-21 08:02:32.390 T:2858779360  NOTICE: Running database version MyVideos116
2019-04-21 08:02:32.401 T:2858779360  NOTICE: Running database version TV32
2019-04-21 08:02:32.410 T:2858779360  NOTICE: Running database version Epg12
2019-04-21 08:02:32.413 T:2973890096  NOTICE: start dvd mediatype detection
2019-04-21 08:02:32.677 T:2973890096  NOTICE:   load skin from: /usr/share/kodi/addons/skin.estuary (version: 2.0.21)
2019-04-21 08:02:36.907 T:2973890096 WARNING: JSONRPC: Could not parse type "Setting.Details.SettingList"
2019-04-21 08:02:37.452 T:2973890096  NOTICE: Register - new keyboard device registered on application->keyboard: Keyboard (0000:0000)
2019-04-21 08:02:37.903 T:2973890096  NOTICE: Register - new mouse device registered on application->mouse: Mouse (0000:0000)
2019-04-21 08:02:37.954 T:2973890096  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
2019-04-21 08:02:37.961 T:2973890096  NOTICE: Loaded playercorefactory configuration
2019-04-21 08:02:37.961 T:2973890096  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
2019-04-21 08:02:37.971 T:2973890096  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
2019-04-21 08:02:38.172 T:2973890096  NOTICE: initialize done
2019-04-21 08:02:38.172 T:2973890096  NOTICE: Running the application...
2019-04-21 08:02:38.216 T:2973890096  NOTICE: starting zeroconf publishing
2019-04-21 08:02:38.217 T:2973890096  NOTICE: CWebServer[8080]: Started
2019-04-21 08:02:38.238 T:2737804000  NOTICE: ES: Starting UDP Event server on port 9777
2019-04-21 08:02:38.238 T:2737804000  NOTICE: UDP: Listening on port 9777 (ipv6 : true)
2019-04-21 08:02:38.416 T:2973890096   ERROR: JSONRPC Server: Failed to connect to sdpd
2019-04-21 08:02:38.476 T:2973890096  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:02:38.538 T:2973890096  NOTICE: VideoPlayer::OpenFile: /var/run/lirc/lircd
2019-04-21 08:02:38.568 T:2704233184  NOTICE: Creating InputStream
2019-04-21 08:02:38.569 T:2704233184   ERROR: CVideoPlayer::OpenInputStream - error opening [/var/run/lirc/lircd]
2019-04-21 08:02:38.569 T:2704233184  NOTICE: CVideoPlayer::OnExit()
2019-04-21 08:02:38.684 T:2807345888  NOTICE: Register - new cec device registered on cec->RPI: CEC Adapter (2708:1001)
2019-04-21 08:02:39.671 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:02:39.672 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:02:39.672 T:2973890096  NOTICE: VideoPlayer: finished waiting
2019-04-21 08:02:39.764 T:2973890096 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (0.62s)
2019-04-21 08:02:52.883 T:2834227936   ERROR: GetDirectory - Error getting
2019-04-21 08:04:37.008 T:2973890096   ERROR: Previous line repeats 6 times.
2019-04-21 08:04:37.008 T:2973890096  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:04:37.018 T:2973890096  NOTICE: VideoPlayer::OpenFile: smb://NAS/movies/DeadFish Conspiracy.mp4
2019-04-21 08:04:37.024 T:2712625888  NOTICE: Creating InputStream
2019-04-21 08:04:48.305 T:2712625888  NOTICE: Creating Demuxer
2019-04-21 08:04:49.754 T:2712625888  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:04:49.756 T:2712625888  NOTICE: Opening stream: 0 source: 256
2019-04-21 08:04:49.757 T:2712625888  NOTICE: Creating video codec with codec id: 27
2019-04-21 08:04:49.788 T:2712625888  NOTICE: Creating video thread
2019-04-21 08:04:49.791 T:2712625888  NOTICE: Opening stream: 1 source: 256
2019-04-21 08:04:49.792 T:2712625888  NOTICE: Finding audio codec for: 86018
2019-04-21 08:04:49.794 T:2771374816  NOTICE: running thread: video_thread
2019-04-21 08:04:49.796 T:2712625888  NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2019-04-21 08:04:49.796 T:2712625888  NOTICE: Creating audio thread
2019-04-21 08:04:49.812 T:2638947040  NOTICE: running thread: CVideoPlayerAudio::Process()
2019-04-21 08:04:49.834 T:2638947040  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
2019-04-21 08:04:50.926 T:2973890096 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (13.75s)
2019-04-21 08:05:05.597 T:2771374816 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
2019-04-21 08:05:10.542 T:2973890096 WARNING: Previous line repeats 93 times.
2019-04-21 08:05:10.551 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:05:10.553 T:2712625888  NOTICE: CVideoPlayer::OnExit()
2019-04-21 08:05:10.554 T:2712625888  NOTICE: Closing stream player 1
2019-04-21 08:05:10.554 T:2712625888  NOTICE: Waiting for audio thread to exit
2019-04-21 08:05:10.557 T:2638947040  NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-04-21 08:05:10.558 T:2712625888  NOTICE: Closing audio device
2019-04-21 08:05:10.575 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:05:10.590 T:2771374816 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
2019-04-21 08:05:11.171 T:2712625888  NOTICE: Deleting audio codec
2019-04-21 08:05:11.171 T:2712625888  NOTICE: Closing stream player 2
2019-04-21 08:05:11.172 T:2712625888  NOTICE: waiting for video thread to exit
2019-04-21 08:05:11.187 T:2771374816  NOTICE: thread end: video_thread
2019-04-21 08:05:11.194 T:2712625888  NOTICE: deleting video codec
2019-04-21 08:05:11.219 T:2973890096  NOTICE: VideoPlayer: finished waiting
2019-04-21 08:05:11.219 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:05:11.220 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:05:11.220 T:2973890096  NOTICE: VideoPlayer: finished waiting
2019-04-21 08:05:32.118 T:2973890096  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:05:32.129 T:2973890096  NOTICE: VideoPlayer::OpenFile: smb://NAS/movies/Battle Cry of the Mute.mkv
2019-04-21 08:05:32.141 T:2656781024  NOTICE: Creating InputStream
2019-04-21 08:05:43.589 T:2656781024  NOTICE: Creating Demuxer
2019-04-21 08:05:45.601 T:2656781024  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:05:45.601 T:2656781024  NOTICE: Opening stream: 0 source: 256
2019-04-21 08:05:45.602 T:2656781024  NOTICE: Creating video codec with codec id: 27
2019-04-21 08:05:45.632 T:2656781024  NOTICE: Creating video thread
2019-04-21 08:05:45.639 T:2601513696  NOTICE: running thread: video_thread
2019-04-21 08:05:45.643 T:2656781024  NOTICE: Opening stream: 1 source: 256
2019-04-21 08:05:45.643 T:2656781024  NOTICE: Finding audio codec for: 86018
2019-04-21 08:05:45.651 T:2656781024  NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac
2019-04-21 08:05:45.651 T:2656781024  NOTICE: Creating audio thread
2019-04-21 08:05:45.655 T:2656781024  NOTICE: Opening stream: 2 source: 256
2019-04-21 08:05:45.656 T:2593120992  NOTICE: running thread: CVideoPlayerAudio::Process()
2019-04-21 08:05:46.056 T:2593120992  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
2019-04-21 08:05:46.729 T:2973890096 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (14.45s)
2019-04-21 08:05:55.556 T:2601513696 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
2019-04-21 08:06:00.562 T:2973890096 WARNING: Previous line repeats 94 times.
2019-04-21 08:06:00.571 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:06:00.579 T:2656781024  NOTICE: CVideoPlayer::OnExit()
2019-04-21 08:06:00.580 T:2656781024  NOTICE: Closing stream player 1
2019-04-21 08:06:00.580 T:2656781024  NOTICE: Waiting for audio thread to exit
2019-04-21 08:06:00.598 T:2601513696 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
2019-04-21 08:06:00.601 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:06:00.604 T:2593120992  NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-04-21 08:06:00.605 T:2656781024  NOTICE: Closing audio device
2019-04-21 08:06:01.159 T:2656781024  NOTICE: Deleting audio codec
2019-04-21 08:06:01.160 T:2656781024  NOTICE: Closing stream player 2
2019-04-21 08:06:01.160 T:2656781024  NOTICE: waiting for video thread to exit
2019-04-21 08:06:01.168 T:2601513696  NOTICE: thread end: video_thread
2019-04-21 08:06:01.170 T:2656781024  NOTICE: deleting video codec
2019-04-21 08:06:01.177 T:2656781024  NOTICE: Closing stream player 3
2019-04-21 08:06:01.255 T:2973890096  NOTICE: VideoPlayer: finished waiting
2019-04-21 08:06:01.255 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:06:01.255 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:06:08.880 T:2973890096  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:06:08.890 T:2973890096  NOTICE: VideoPlayer::OpenFile: smb://NAS/movies/Games-of-Chairs.mkv
2019-04-21 08:06:08.929 T:2647339744  NOTICE: Creating InputStream
2019-04-21 08:06:20.141 T:2647339744  NOTICE: Creating Demuxer
2019-04-21 08:06:21.106 T:2647339744  NOTICE: OMXPlayerUnsuitable OMXPlayer unsuitable due to audio sink
2019-04-21 08:06:21.106 T:2647339744  NOTICE: Opening stream: 0 source: 256
2019-04-21 08:06:21.107 T:2647339744  NOTICE: Creating video codec with codec id: 27
2019-04-21 08:06:21.123 T:2647339744  NOTICE: Creating video thread
2019-04-21 08:06:21.127 T:2647339744  NOTICE: Opening stream: 1 source: 256
2019-04-21 08:06:21.127 T:2647339744  NOTICE: Finding audio codec for: 86056
2019-04-21 08:06:21.130 T:2647339744  NOTICE: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder eac3
2019-04-21 08:06:21.130 T:2647339744  NOTICE: Creating audio thread
2019-04-21 08:06:21.131 T:2647339744  NOTICE: Opening stream: 2 source: 256
2019-04-21 08:06:21.132 T:2564780768  NOTICE: running thread: video_thread
2019-04-21 08:06:21.132 T:2623533792  NOTICE: running thread: CVideoPlayerAudio::Process()
2019-04-21 08:06:21.384 T:2623533792  NOTICE: Creating audio stream (codec id: 86056, channels: 2, sample rate: 48000, no pass-through)
2019-04-21 08:06:22.927 T:2973890096 WARNING: OnMessage: Suspiciously long time to handle GUI_MSG_PLAYBACK_STARTED (13.88s)
2019-04-21 08:06:39.265 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:06:39.278 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:06:39.300 T:2647339744  NOTICE: CVideoPlayer::OnExit()
2019-04-21 08:06:39.300 T:2647339744  NOTICE: Closing stream player 1
2019-04-21 08:06:39.301 T:2647339744  NOTICE: Waiting for audio thread to exit
2019-04-21 08:06:39.344 T:2623533792  NOTICE: thread end: CVideoPlayerAudio::OnExit()
2019-04-21 08:06:39.344 T:2647339744  NOTICE: Closing audio device
2019-04-21 08:06:39.957 T:2647339744  NOTICE: Deleting audio codec
2019-04-21 08:06:39.958 T:2647339744  NOTICE: Closing stream player 2
2019-04-21 08:06:39.959 T:2564780768   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
2019-04-21 08:06:39.959 T:2564780768  NOTICE: thread end: video_thread
2019-04-21 08:06:39.959 T:2647339744  NOTICE: waiting for video thread to exit
2019-04-21 08:06:39.959 T:2647339744  NOTICE: deleting video codec
2019-04-21 08:06:39.967 T:2647339744  NOTICE: Closing stream player 3
2019-04-21 08:06:40.013 T:2973890096  NOTICE: VideoPlayer: finished waiting
2019-04-21 08:06:40.013 T:2973890096  NOTICE: CVideoPlayer::CloseFile()
2019-04-21 08:06:40.013 T:2973890096  NOTICE: VideoPlayer: waiting for threads to exit
2019-04-21 08:08:36.411 T:2973890096  NOTICE: Samba is idle. Closing the remaining connections
2019-04-21 08:28:12.797 T:2973890096  NOTICE: stop player
2019-04-21 08:28:12.799 T:2973890096  NOTICE: Storing total System Uptime
2019-04-21 08:28:12.800 T:2973890096  NOTICE: Saving settings
2019-04-21 08:28:12.839 T:2973890096  NOTICE: Saving skin settings
2019-04-21 08:28:12.849 T:2973890096  NOTICE: stop all
2019-04-21 08:28:12.849 T:2973890096  NOTICE: ES: Stopping event server
2019-04-21 08:28:12.850 T:2973890096  NOTICE: stopping zeroconf publishing
2019-04-21 08:28:12.885 T:2973890096  NOTICE: CWebServer[8080]: Stopped
2019-04-21 08:28:13.786 T:2737804000  NOTICE: ES: UDP Event server stopped
2019-04-21 08:28:13.787 T:2973890096  NOTICE: stop dvd detect media
2019-04-21 08:28:14.041 T:2973890096  NOTICE: stopped
2019-04-21 08:28:14.242 T:2973890096  NOTICE: destroy
2019-04-21 08:28:15.666 T:2973890096  NOTICE: unload skin
2019-04-21 08:28:15.859 T:2973890096  NOTICE: unload sections
2019-04-21 08:28:16.100 T:2973890096  NOTICE: application stopped...
To confirm if there is a fix to the original problem I had (as posted in the first post), I updated and upgraded the RPi3B+ as well
in the config.txt, enabled the on-board audio on the RPI3B+, DAC also enabled
ran Kodi.... but no DAC audio
So why there is DAC audio on RPi1B but none in RPi3B+?
Seem quite a mystery to me....
