ElectrodeYT
DOOM 3 on the Pi (with OpenGL Drivers)
Fri Apr 12, 2019 5:53 pm
Ive found a Doom 3 engine called dhewm3, and it runs on SDL. Ive tried compiling it and it does boot the menu, but opening a save game/starting a new game is a bit of a problem:
It just goes blank. It doesnt matter if its windowed, or full screen, the entire screen goes black (sometimes with a cursor in the center).
Looking at the command line response it gives me a large amount of Shader compilation errors. Id look at it, but i dont know ARB Shaders and i have not looked at the source for the game yet. The DOOM 3 pk4 files md5 hashes are completly correct, so i have no idea why this isnt working.
While garbage FPS is one thing, The game not starting is another and if it turns out to be a OpenGL driver bug, which seems possible, might be a good idea to fix. I havent looked at the stack trace and things like that yet and there are no similar issues on the github page of dhewm3. I havent tried not running it with OpenGL Drivers, but as this engine lacks ES support it would make it a chore to even try.
Compiling:
Normal cmake stuff. Works instantly, no patches required.
Reproduction:
Start the game (with doom 3 pk4s in /usr/local/share/dhewm/base/...) and either load a save game or start a new game. The loading bar loads, the loading bar fills and a few seconds later pitch blank dark.
Log:
dhewm3 1.5.1pre.1304 linux-armv7l Apr 12 2019 17:24:52 using SDL v2.0.5
terminal support enabled ( use +set in_tty 0 to disable )
pid: 923
928 MB System Memory
found interface lo - loopback
found interface wlan0 - 10.0.0.66/255.255.255.0
----- Initializing File System -----
Loaded pk4 /usr/local/share/dhewm3/base/pak000.pk4 with checksum 0x28d208f1
Loaded pk4 /usr/local/share/dhewm3/base/pak001.pk4 with checksum 0x40244be0
Loaded pk4 /usr/local/share/dhewm3/base/pak002.pk4 with checksum 0xc51ecdcd
Loaded pk4 /usr/local/share/dhewm3/base/pak003.pk4 with checksum 0xcd79d028
Loaded pk4 /usr/local/share/dhewm3/base/pak004.pk4 with checksum 0x765e4f8b
Loaded pk4 /usr/local/share/dhewm3/base/pak005.pk4 with checksum 0x8ffc3621
Loaded pk4 /usr/local/share/dhewm3/base/pak006.pk4 with checksum 0x95b65ab
Loaded pk4 /usr/local/share/dhewm3/base/pak007.pk4 with checksum 0x666bdb3c
Loaded pk4 /usr/local/share/dhewm3/base/pak008.pk4 with checksum 0x23ae5993
Current search path:
/home/pi/.config/dhewm3/base
/home/pi/.local/share/dhewm3/base
/usr/local/share/dhewm3/base/pak008.pk4 (3 files)
/usr/local/share/dhewm3/base/pak007.pk4 (38 files)
/usr/local/share/dhewm3/base/pak006.pk4 (48 files)
/usr/local/share/dhewm3/base/pak005.pk4 (63 files)
/usr/local/share/dhewm3/base/pak004.pk4 (5137 files)
/usr/local/share/dhewm3/base/pak003.pk4 (4676 files)
/usr/local/share/dhewm3/base/pak002.pk4 (6120 files)
/usr/local/share/dhewm3/base/pak001.pk4 (8972 files)
/usr/local/share/dhewm3/base/pak000.pk4 (2698 files)
Addon pk4s:
----- Initializing Decls -----
5206 strings read from strings/english.lang
Couldn't open journal files
execing editor.cfg
execing default.cfg
execing dhewm.cfg
couldn't exec autoexec.cfg
----- Initializing OpenAL -----
Setup OpenAL device and context
OpenAL: found device 'ALSA Default'
OpenAL: found device 'bcm2835 ALSA, bcm2835 ALSA (CARD=ALSA,DEV=0)'
OpenAL: found device 'bcm2835 ALSA, bcm2835 IEC958/HDMI (CARD=ALSA,DEV=1)'
OpenAL: found device 'vc4-hdmi, (CARD=vc4hdmi,DEV=0)'
OpenAL vendor: OpenAL Community
OpenAL renderer: OpenAL Soft
OpenAL version: 1.1 ALSOFT 1.17.2
OpenAL: found EFX extension
OpenAL: found 256 hardware voices
----- Initializing OpenGL -----
Initializing OpenGL subsystem
Using 8 color bits, 24 depth, 8 stencil display
OpenGL vendor: Broadcom
OpenGL renderer: Gallium 0.4 on VC4 V3D 2.1
OpenGL version: 2.1 Mesa 13.0.6
...using GL_ARB_multitexture
...using GL_ARB_texture_env_combine
...using GL_ARB_texture_cube_map
...using GL_ARB_texture_env_dot3
...using GL_ARB_texture_env_add
...using GL_ARB_texture_non_power_of_two
...using GL_ARB_texture_compression
X..GL_EXT_texture_compression_s3tc not found
X..GL_EXT_texture_filter_anisotropic not found
...using GL_1.4_texture_lod_bias
X..GL_EXT_shared_texture_palette not found
...using GL_EXT_texture3D
...using GL_EXT_stencil_wrap
...using GL_EXT_stencil_two_side
...using GL_ARB_vertex_buffer_object
...using GL_ARB_vertex_program
...using GL_ARB_fragment_program
X..EXT_depth_bounds_test not found
ARB2 renderer: Available.
----- R_ReloadARBPrograms -----
glprogs/test.vfp
GL_PROGRAM_ERROR_STRING_ARB: line 47, char 42: error: invalid vertex attribute reference
error at 1156:
rtex.attrib[10], R0;
DP3 result.texcoord[0].z, vertex.attrib[11], R0;
# textures 1 takes the base coordinates by the texture matrix
MOV result.texcoord[1], defaultTexCoord;
DP4 result.texcoord[1].x, vertex.attrib[8], program.env[10];
DP4 result.texcoord[1].y, vertex.attrib[8], program.env[11];
# texture 2 has one texgen
MOV result.texcoord[2], defaultTexCoord;
DP4 result.texcoord[2].x, vertex.position, program.env[9];
# texture 3 has three texgens
DP4 result.texcoord[3].x, vertex.position, program.env[6];
DP4 result.texcoord[3].y, vertex.position, program.env[7];
DP4 result.texcoord[3].w, vertex.position, program.env[8];
# textures 4 takes the base coordinates by the texture matrix
MOV result.texcoord[4], defaultTexCoord;
DP4 result.texcoord[4].x, vertex.attrib[8], program.env[12];
DP4 result.texcoord[4].y, vertex.attrib[8], program.env[13];
# textures 5 takes the base coordinates by the texture matrix
MOV result.texcoord[5], defaultTexCoord;
DP4 result.texcoord[5].x, vertex.attrib[8], program.env[14];
DP4 result.texcoord[5].y, vertex.attrib[8], program.env[15];
# calculate vector to viewer in R0
SUB R0, program.env[5], vertex.position;
# put into texture space for TEX6
DP3 result.texcoord[6].x, vertex.attrib[9], R0;
DP3 result.texcoord[6].y, vertex.attrib[10], R0;
DP3 result.texcoord[6].z, vertex.attrib[11], R0;
# generate the vertex color, which can be 1.0, color, or 1.0 - color
# for 1.0 : env[16] = 0, env[17] = 1
# for color : env[16] = 1, env[17] = 0
# for 1.0-color : env[16] = -1, env[17] = 1
MAD result.color, vertex.color, program.env[16], program.env[17];
#SWZ result.color, R0, 1, 1, 1, 1;
ENDglprogs/test.vfp
glprogs/interaction.vfp
error at 1156:
# texture 6's texcoords will be the halfangle in texture space
# calculate normalized vector to light in R0
SUB R0, program.env[4], vertex.position;
DP3 R1, R0, R0;
RSQ R1, R1.x;
MUL R0, R0, R1.x;
# calculate normalized vector to viewer in R1
SUB R1, program.env[5], vertex.position;
DP3 R2, R1, R1;
RSQ R2, R2.x;
MUL R1, R1, R2.x;
# add together to become the half angle vector in object space (non-normalized)
ADD R0, R0, R1;
ENDglprogs/interaction.vfp
glprogs/bumpyEnvironment.vfp
GL_PROGRAM_ERROR_STRING_ARB: line 38, char 42: error: invalid vertex attribute reference
error at 1127:
ult.texcoord[3].x, vertex.attrib[9], program.env[7];
DP3 result.texcoord[4].x, vertex.attrib[9], program.env[8];
# texture 3 gets the transformed tangent
DP3 result.texcoord[2].y, vertex.attrib[10], program.env[6];
DP3 result.texcoord[3].y, vertex.attrib[10], program.env[7];
DP3 result.texcoord[4].y, vertex.attrib[10], program.env[8];
# texture 4 gets the transformed tangent
DP3 result.texcoord[2].z, vertex.normal, program.env[6];
DP3 result.texcoord[3].z, vertex.normal, program.env[7];
DP3 result.texcoord[4].z, vertex.normal,program.env[8];
MOV result.color, vertex.color;
ENDglprogs/bumpyEnvironment.vfp
glprogs/ambientLight.vfp
GL_PROGRAM_ERROR_STRING_ARB: line 56, char 42: error: invalid vertex attribute reference
error at 1640:
DP4 result.texcoord[1].x, vertex.attrib[8], program.env[12];
DP4 result.texcoord[1].y, vertex.attrib[8], program.env[13];
DP3 result.texcoord[4].x, vertex.attrib[9], program.env[20];
DP3 result.texcoord[4].y, vertex.attrib[10], program.env[20];
DP3 result.texcoord[4].z, vertex.attrib[11], program.env[20];
DP3 result.texcoord[5].x, vertex.attrib[9], program.env[21];
DP3 result.texcoord[5].y, vertex.attrib[10], program.env[21];
DP3 result.texcoord[5].z, vertex.attrib[11], program.env[21];
DP3 result.texcoord[6].x, vertex.attrib[9], program.env[22];
DP3 result.texcoord[6].y, vertex.attrib[10], program.env[22];
DP3 result.texcoord[6].z, vertex.attrib[11], program.env[22];
ENDglprogs/ambientLight.vfp
glprogs/shadow.vp
glprogs/environment.vfp
glprogs/arbVP_glasswarp.txt: File not found
glprogs/arbFP_glasswarp.txt: File not found
using ARB_vertex_buffer_object memory
using ARB2 renderSystem
loaded game library '/home/pi/doom3/dhewm3/neo/build/base.so'.
----- Initializing Game -----
gamename: baseDOOM-1
gamedate: Apr 12 2019
Initializing event system
...473 event definitions
Initializing class hierarchy
...142 classes, 382184 bytes for event callbacks
Initializing scripts
Compiled 'removeInitialSplineAngles': 2966 ms
----- Compile stats -----
Memory usage:
Strings: 79, 12592 bytes
Statements: 67875, 1357500 bytes
Functions: 2109, 250532 bytes
Variables: 147376 bytes
Mem used: 2579384 bytes
Static data: 2477552 bytes
Allocated: 3484640 bytes
Thread size: 13212 bytes
...6 aas types
----- Initializing Session -----
----- Game Map Shutdown -----
reloading guis/mainmenu.gui.
reloading guis/restart.gui.
reloading guis/gameover.gui.
reloading guis/msg.gui.
reloading guis/takeNotes.gui.
reloading guis/intro.gui.
----- Map Initialization -----
Map: game/mars_city1
glprogs/heatHaze.vfp
glprogs/heatHazeWithMask.vfp
----- Game Map Init -----
collision data:
421 models
30823 vertices (722 KB)
54551 edges (1917 KB)
22257 polygons (1564 KB)
4068 brushes (556 KB)
12449 nodes (340 KB)
43444 polygon refs (339 KB)
14219 brush refs (111 KB)
18352 internal edges
1461 sharp edges
0 contained polygons removed
0 polygons merged
5551 KB total memory used
562 msec to load collision data.
map bounds are (19640.0, 22168.0, 29496.0)
max clip sector is (1227.5, 1385.5, 1843.5)
2 KB passage memory used to build PVS
9 msec to calculate PVS
56 areas
110 portals
9 areas visible on average
448 bytes PVS data
[Load AAS]
loading maps/game/mars_city1.aas48
done.
[Load AAS]
loading maps/game/mars_city1.aas96
[Load AAS]
loading maps/game/mars_city1.aas_guardian
[Load AAS]
loading maps/game/mars_city1.aas_mancubus
[Load AAS]
loading maps/game/mars_city1.aas_sabaoth
[Load AAS]
loading maps/game/mars_city1.aas_cyberdemon
Entering doom_main()
Exiting doom_main()
Spawning entities
loaded collision model models/mapobjects/com/platguistand/mc_platguistand.lwo
WARNING: marscity_cinematic_sarge_1 has no AAS file
WARNING: marscity_cinematic_sarge2_1 has no AAS file
loaded collision model models/mapobjects/filler/burgerboxopen.lwo
glprogs/heatHazeWithMaskAndVertex.vfp
loaded collision model models/mapobjects/lab/diamondbox/diamondbox_sm.lwo
loaded collision model models/mapobjects/com/modconsole1.lwo
loaded collision model models/mapobjects/filler/burgereat.lwo
loaded collision model models/mapobjects/filler/burgerboxclose.lwo
loaded collision model models/mapobjects/filler/mkeyboard.lwo
loaded collision model models/mapobjects/lights/florescent_bulbflare.ASE
loaded collision model models/mapobjects/base/misc/emerlight.ase
loaded collision model models/mapobjects/monitors/controlmonitor.lwo
loaded collision model models/mapobjects/doors/mcitydoor2l.lwo
loaded collision model models/mapobjects/doors/mcitydoor2r.lwo
loaded collision model models/mapobjects/doors/mcdoor2frame.lwo
loaded collision model models/mapobjects/tables/conf_table/conf_table.lwo
loaded collision model models/mapobjects/filler/cola1.lwo
loaded collision model models/mapobjects/filler/foamcup.lwo
loaded collision model models/mapobjects/signs/marquee/marquee.lwo
loaded collision model models/mapobjects/doors/mcitydoorframe.lwo
loaded collision model models/mapobjects/doors/mcitydoorframegui.lwo
loaded collision model models/items/keycard/keycard3.lwo
loaded collision model models/mapobjects/doors/mcitydoor.lwo
loaded collision model models/mapobjects/cpu/pullhandle.lwo
loaded collision model models/mapobjects/doors/delelev/delelevlf.lwo
loaded collision model models/mapobjects/guiobjects/techdrpanel1/techdrpanel1.lwo
loaded collision model models/mapobjects/doors/delelev/delelevrt.lwo
loaded collision model models/mapobjects/filler/ktable.lwo
loaded collision model models/mapobjects/cpu/heater.lwo
loaded collision model models/mapobjects/cpu/heater2.lwo
loaded collision model models/mapobjects/cpu/comrack2.lwo
loaded collision model models/mapobjects/lab/sink2/sink2.lwo
loaded collision model models/mapobjects/filler/sodamachine.lwo
loaded collision model models/mapobjects/filler/binder1.ase
loaded collision model models/mapobjects/lab/bubbler2/bubbler2.lwo
loaded collision model models/mapobjects/filler/tbox7.ase
loaded collision model models/mapobjects/filler/binder3.ase
loaded collision model models/mapobjects/chairs/modchair/modtable.lwo
loaded collision model models/mapobjects/chairs/modchair/modseat.lwo
loaded collision model models/mapobjects/chairs/modchair/modarm.lwo
removed 2 degenerate triangles
loaded collision model models/mapobjects/lab/newfridge/newfridge.lwo
loaded collision model models/mapobjects/filler/paper1.ase
loaded collision model models/mapobjects/filler/tbox6.ase
loaded collision model models/mapobjects/filler/tbox_open.ase
loaded collision model models/mapobjects/filler/toolchest.lwo
loaded collision model models/mapobjects/doors/deldoor1/deldoor1frm.lwo
loaded collision model models/mapobjects/doors/deldoor1/deldoor1.lwo
loaded collision model models/mapobjects/com/modconsole2.lwo
loaded collision model models/mapobjects/com/modconsole5.lwo
loaded collision model models/mapobjects/cpu/cpumaze1.lwo
loaded collision model models/mapobjects/doors/deldoor1/deldoor1win.lwo
loaded collision model models/mapobjects/com/modconsole4.lwo
loaded collision model models/mapobjects/lab/gizmo2/gizmo2.lwo
loaded collision model models/mapobjects/lab/autable/autable.lwo
loaded collision model models/mapobjects/lab/roboarm1/roboarm1.lwo
loaded collision model models/mapobjects/utility/tecknob2/tecknob2.lwo
loaded collision model models/mapobjects/cpu/comrack.lwo
loaded collision model models/mapobjects/tables/gendesk/gendesk2.lwo
loaded collision model models/mapobjects/filler/tbox2.ase
loaded collision model models/mapobjects/cpu/serverplate.lwo
loaded collision model models/mapobjects/filler/snackmachine.lwo
loaded collision model models/mapobjects/filler/tbox1.ase
loaded collision model models/mapobjects/washroom/clamp.ase
loaded collision model models/mapobjects/washroom/urinal2.ase
loaded collision model models/mapobjects/washroom/dryer.ase
loaded collision model models/mapobjects/washroom/bsink.ase
loaded collision model models/mapobjects/washroom/soap.ase
loaded collision model models/mapobjects/washroom/toilet.ase
loaded collision model models/mapobjects/washroom/tp.ase
loaded collision model models/mapobjects/arcade_machine/arcade_machine.lwo
loaded collision model models/mapobjects/mcity/deskcomp/deskcomp.lwo
loaded collision model models/mapobjects/skmachines/skoverhang.lwo
loaded collision model models/mapobjects/shipping_crates/shipping_crates.lwo
loaded collision model models/mapobjects/skmachines/skcube.lwo
loaded collision model models/mapobjects/doors/accesshatch/accesshatch.lwo
loaded collision model models/mapobjects/doors/accesshatch/accesshatchdoor.lwo
loaded collision model models/mapobjects/elevators/elevator.lwo
loaded collision model models/mapobjects/swinglights/swinglight1b.lwo
loaded collision model models/mapobjects/swinglights/swinglight_long_wbulbs_bulb_broken.ase
loaded collision model models/mapobjects/filler/keyboard1.ase
loaded collision model models/mapobjects/storagecab/gunrack/gunrackcomp.lwo
loaded collision model models/mapobjects/chairs/modchair/modcorner.lwo
loaded collision model models/mapobjects/shutter/shutter_small.lwo
loaded collision model models/mapobjects/mcity/outside/mc_outside.lwo
loaded collision model models/mapobjects/turrets/ceilingturret1b.lwo
loaded collision model models/mapobjects/mcity/outside/mc_outside2.lwo
loaded collision model models/mapobjects/kiosk/infokiosk2.lwo
loaded collision model models/mapobjects/lab/loadingplatform/loadingplatform.lwo
loaded collision model models/mapobjects/deltakiosk/deltakiosk.lwo
WARNING: marscity_cinematic_player_sarge has no AAS file
loaded collision model models/mapobjects/hangar/hangar1b.lwo
loaded collision model models/mapobjects/doors/jumbodoor/jumbodoorfrm.lwo
loaded collision model models/mapobjects/hangar/hangar1tower.lwo
loaded collision model models/mapobjects/hangar/rails3.lwo
loaded collision model models/mapobjects/hangar/rails2.lwo
loaded collision model models/mapobjects/hangar/rails1.lwo
loaded collision model models/mapobjects/hangar/rails4.lwo
loaded collision model models/mapobjects/hangar/rails5.lwo
loaded collision model models/mapobjects/hangar/pillar1.lwo
loaded collision model models/mapobjects/hangar/rails6.lwo
loaded collision model models/mapobjects/hangar/marquee.lwo
loaded collision model models/mapobjects/hangar/hangarlamp1.lwo
loaded collision model models/mapobjects/mcity/bioscanner/bioscannereye.lwo
loaded collision model models/mapobjects/tables/gendesk/gendesk1.lwo
loaded collision model models/mapobjects/hangar/hangar2tower.lwo
loaded collision model models/mapobjects/monitors/hangingmonitor.lwo
loaded collision model models/mapobjects/signs/ceilingsign/ceilingsign.lwo
loaded collision model models/mapobjects/elevators/elevator_door.lwo
loaded collision model models/mapobjects/com/platguistand/platguistand.lwo
loaded collision model models/mapobjects/guiobjects/flatmonitor/flatmonitor.lwo
loaded collision model models/mapobjects/mcity/bioscanner/bioscanbeam.lwo
loaded collision model models/mapobjects/mcity/bioscanner/bioscanner.lwo
loaded collision model models/mapobjects/doors/mcitydoor_glass.lwo
loaded collision model models/mapobjects/lab/fridge1/fridge1_delta2b.lwo
WARNING: Couldn't load sound 'guisounds.wav' using default
loaded collision model models/mapobjects/turrets/ceilingturret1a.lwo
...1969 entities spawned, 0 inhibited
==== Processing events ====
SpawnPlayer: 0
loaded collision model models/weapons/shell1/mshell_lo.lwo
loaded collision model models/weapons/shell1/sshell_bigger.lwo
----- idRenderModelManagerLocal::EndLevelLoad -----
1 models purged from previous level, 1022 models kept.
----- idImageManager::EndLevelLoad -----
0 purged from previous
154 kept from previous
2073 new loaded
all images loaded in 24.3 seconds
----- idSoundCache::EndLevelLoad -----
13517k referenced
939k purged
sound: found efxs/mars_city1.efx
42328 msec to load game/mars_city1
idRenderWorld::GenerateAllInteractions, msec = 62, staticAllocCount = 0.
interactionTable size: 2822240 bytes
29877 interaction take 3346224 bytes
----- Warnings -----
during game/mars_city1...
1 warnings
Looks like dhewm3 1.5.1pre crashed with signal SIGSEGV (11) - sorry!
Backtrace:
./dhewm3() [0x1dead8]
/lib/arm-linux-gnueabihf/libc.so.6(__default_sa_restorer+0) [0x7694a6b0]
Sorry if this is in the wrong place
ElectrodeYT
Re: DOOM 3 on the Pi (with OpenGL Drivers)
Fri Apr 12, 2019 6:29 pm
So i changed the repos to buster from strech and it loaded! The initial cut scene ran great, then... well not much. The screen was black for 95% of the next cutscene but audio was there, and the UI and HUD loaded but not the game itself. I know this will probably not work and corrupt my raspbian but im running apt dist-upgrade to buster. Wish me luck and prepare to press f for my sd card
Sumie
Mon Apr 15, 2019 8:18 pm
Definitely interested on the outcome of your testing here.
Return to “Gaming”
