raspenger
Case for a pinhole camera on the side
Thu Apr 11, 2019 12:01 pm
Hi everyone,
I search for a case, which has an opening for the pinhole camera on the side, not on the top. It would be even better, if it would be a case for a Zero W. Can you recommend a model?
Best regards
Andyroo
Re: Case for a pinhole camera on the side
Thu Apr 11, 2019 1:19 pm
I do not have an answer but also interested as I’ve used dustbins, Pringles tubes, sweet tins and a 120 Holga as pin hole cameras so I’ve put a notify on here :lol:
raspenger
Thu Apr 11, 2019 3:06 pm
Actually I am surprised that it is not so easy to find suitable cases with pinhole openings on the side.
PhatFil
Thu Apr 11, 2019 5:34 pm
whats your budget? have you priced a 3d printed custom or lifted of thingiverse design?
scruss
Thu Apr 11, 2019 7:38 pm
raspenger, do you mean pinhole as in "no optics but a tiny hole", or pinhole as in the more recent "any small covert digital camera" meaning?
As a dedicated Zero Image owner who has a couple of clone camera modules on the way for modding with a copper foil pinhole, I kinda hope the former.
Andyroo
Thu Apr 11, 2019 9:07 pm
In my case that’s what I mean by pinhole.
Those zeros are nice but the website does not make it easy to see the camera or work out the cost!
scruss
Fri Apr 12, 2019 3:54 am
They're kind of a "don't ask" pricing item. I got mine from a pro travel photographer who was given it and couldn't handle the workflow. They're also only made intermittently, in short runs that sell out quickly
Gavinmc42
Fri Apr 12, 2019 6:34 am
Wow, love those cameras.
I have a Pi camera V2 with a broken lens, now I know what to do with it :D
Hmm 1/100 focal distance = 0.03mm or smaller?
Brass shim I have , 0.03mm drill not so much ;)
I'm dancing on Rainbows.
PiGraham
Fri Apr 12, 2019 7:05 am
I doubt you can get useful images from a Pi camera and a pinhole. A pinhole doesn't let in much light which means you need long exposures with film and a CMOS cameraphone sensor will have too much noise and too short exposure times. Also, the small sixe of pixels on a small sensor will be beyond the resolution the pinhole can achieve to the image will be blurry.
Which is not to say it can't be done, just that the results will be poor.
Here is an example os a pinhole camera built with a Pi camera V2 and a Pi Zero.
https://opensource.com/article/18/3/how ... spberry-pi
And an example image:
Andyroo
Fri Apr 12, 2019 11:00 am
That’s not too bad compared to my sweet tin :lol:
Thank you for the link.
gordon77
Fri Apr 12, 2019 11:18 am
Hi everyone,
Best regards
Does the OP really mean a pin hole camera or the pi camera, as l've never seen a case with a pin hole on the top?
scruss
Fri Apr 12, 2019 6:29 pm
A needle and a scanner to measure it with will do just fine.
PiGraham
Fri Apr 12, 2019 6:57 pm
It hadn't occurred to me that you could buy such a minute drill. A pricey item though.
https://www.grainger.com/category/machi ... ters=attrs
Andyroo
Fri Apr 12, 2019 7:09 pm
You can manage with a needle and part of the fun is trying to get a good hole! At least with digital you do not ‘waste’ paper and developer / fix :lol: key thing I found was to gently push and polish the foil on the back to close the hole slightly. I’ve not tried the sandpaper option from here as I use normal cooking foil.
If you start now you may be able to put up some pictures for World Pinhole day on the 28th April
If anyone fancies the more classic way to do this or wants to try with a DSLR then head to http://pinholesolutions.co.uk for equipment.
Gavinmc42
Sat Apr 13, 2019 1:16 am
Wow, I have about 10KGs of broken PCB drills, I'm sitting on a gold mine if I can figure out how to grind them that small :D
Diamond wheel and air bearing spindle?
What the smallest hole a YAG laser can make?
3-5um :D
raspenger
Sat Apr 13, 2019 1:39 pm
Perhaps the term pinhole was misleading. But indeed I meant a case with an opening for the camera one the side, not on top.
About the 3D printers: I have no experience in that area. And I do not know if there could be health issues. I mean, who guarantees me that that material won''t lead to illnesses or something like that. May sound stupid, but most products, which I would buy have some label/certificate according to EC law and therefore guarantee their safety.
Gavinmc42
Sun Apr 14, 2019 12:02 am
3D prints from PLA should be ok, that's made from Corn I think.
Wooden cases are getting popular, even seen bamboo keyboard.
But that case looks interesting.
Would still need one of those USB to Sata cables.
scruss
Tue Apr 16, 2019 1:28 pm
Pretty much every filament comes with an MSDS data sheet. While there are some with concerns that FDM printers produce ultra-fine particulates, the strongest proponents of this theory also seem to be involved in the supply of incredibly expensive HEPA-filtered enclosures for school 3d printers. Hmm ...
Most plastic Raspberry Pi cases you'll buy are made of ABS: a mixture of three different plastic stocks that combine strength, toughness and low cost. There's probably a lot of filler (chalk) and optical brightener (titanium dioxide) in there too. It's generally considered safe unless you start burning it. ABS is still a fairly popular 3D printing material, but it stinks of burning car tyres while printing.
PLA is the standard 3d printing filament these days: cheap, accurate, pretty, biodegradable but usually quite brittle. Some PLA will smell somewhere between waffles and maple syrup when printing. Although it's made from food stock, please don't eat it.
PETG (the plastic bottle material, with Glycol added (I think) to assist with extrusion) is pretty common. Though it prints hotter than PLA and ABS, it appears to have no (or trace) VOC emissions when printing. The biggest issue you might hit when printing with higher-temperature materials is PTFE fumes if your printer uses it near the hot end. PTFE fumes are no joke (ask any dead canary) but PETG just sneaks in under that temperature.
Once printed, most 3d printed materials are generally considered safe.
Andyroo
Tue Apr 16, 2019 2:59 pm
Scruss - you forgot chocolate :lol:
raspenger
Tue Apr 16, 2019 4:44 pm
gordon77 wrote:
Sat Apr 13, 2019 4:10 pm
Something like this...?
https://uk.rs-online.com/mobile/p/produ ... -_-1360232
Yeah, that looks really great. I will search if they also have something like that for the zero.
scruss
Tue Apr 16, 2019 7:32 pm
Since I'm allergic to chocolate, I wouldn't have mentioned it under “generally considered safe”. Also the last chocolate printer I saw (a failed local startup) used laser sintering and ended up making inedible (even by your standards) burnt things.
I did see a concrete printer at MRRF the other weekend. Also, the person in the stall behind me was 3d printing in PEEK which has a melting point of basically “eek!”
Return to “Camera board”
