efeick
Re: Can't Remove SETTINGS File from Desktop
Wed Apr 17, 2019 2:22 pm
procount wrote:
Wed Apr 17, 2019 1:01 pm
Still not quite sure why you need access to the settings partition. It's mostly internal stuff for NOOBS. I don't think there is anything there you need to alter, edit, or even view outside of NOOBS.
Ah, okay. I was thinking it might need to be somewhat accessible which was why the icon was located on the desktop, but maybe that was just a side effect of making mounted partitions visible on the desktop. If nothing in there ever needs to be accessed by the user then your initial post worked great:
/dev/mmcblk0p5 /mnt/Settings ext4 defaults,noatime,noauto 0 0
That definitely got the icon off the desktop on my NOOBS/Raspbian system.
Wed Apr 17, 2019 2:54 pm
I think you can disable showing it on the desktop from the main menu: Preferences->Appearance Settings->Desktop and untick External Disks. This will prevent any USB storage devices showing up as well.
Signature is on holiday.
