Void Frost
Sed command not working
Sun Apr 07, 2019 5:57 pm
Hello! I'm trying to make an easier way to overclock a Pi, and i'm trying to echo the new arm_freq=1500 to the config.txt on line 78 but for some reason it won't copy over. My command is as follows:
sudo sed -i 78i\arm_freq=1500 /boot/config.txt
Raspberry Pi User. Subscribe to my YouTube channel, if you want :D https://www.youtube.com/c/VoidFrost
tpyo kingg
Re: Sed command not working
Sun Apr 07, 2019 6:17 pm
There are not normally 78 lines in config.txt, at least not by default. So the condition will never be met and the insertion never made. If you would like to append to the file, try something like this to insert or append on the final line:
sudo sed -i.bak '$i\arm_freq=1500' /boot/config.txt
# or
sudo sed -i.bak '$a\arm_freq=1500' /boot/config.txt
The $ stands for the end of the file.
jahboater
Sun Apr 07, 2019 6:29 pm
Or just:
echo "arm_freq=1500" >>/boot/config.txt
Sun Apr 07, 2019 7:59 pm
Or just:
Which will fail because of permissions. The sudo is required.
You'd need to use something like
sudo sh -c "echo 'arm_freq=1500' >>/boot/config.txt"
Signature is on holiday.
Void Frost
Sun Apr 07, 2019 10:33 pm
Is there a way I can easily add lines?
echmain
Mon Apr 08, 2019 12:25 am
Any reason you can't use an editor? Vi or Nano or whatever?
tpyo kingg
Mon Apr 08, 2019 4:56 am
Yes, you can append using either sed or as shell redirection. Both methods are shown above. An advantage of using sed with -i is that it can create a backup file. The advantage of the appending redirection >> is that it is simple.
Can you please say a little about your task? Depending on the context there might be something else important.
jahboater
Mon Apr 08, 2019 2:03 pm
If adding multiple lines from the shell, its common to use something called a "here document":-
cat <<end >>/boot/config.txt
line 1
line 2
line 3
end
As noted above, you need root to write to /boot
