Jackr
Quectel EC 25 / 21 drivers ?
Fri Apr 05, 2019 12:13 am
What ? I have to make the driver myself (following theyr guide) and recompile the kernel ??? :shock: :?
I read something about linux support (usb/mpcie) and I thought they were included ! ...or easyer to install
Maybe in raspbian it works out of the box ?
The drivers are needed just for the internet or for everything ?
The drivers are needed jus with usb adapter or also when in the mpcie slot ?
Thanks.
lpsw
Re: Quectel EC 25 / 21 drivers ?
Fri Apr 05, 2019 3:23 am
Took a quick read of the EC21 install doc; it clearly indicates that the driver must be compiled by the end user, in order to install the driver(s).
BTW, the Pi does not have a mPCIe port.
EDIT: driver (not kernel) requires recompilation.
Self-education is, I firmly believe, the only kind of education there is - Isaac Asimov
lpsw
Fri Apr 05, 2019 4:02 am
This might shed some light:
https://github.com/raspberrypi/linux/issues/1880
I looked at this modem a while back, but went with another (U620L from Verizon (US)) due to support concerns.
Jackr
Sat Apr 06, 2019 12:26 am
Really ? I've seen a section to make the kernel module but it says its for desktop pc, not sure what they mean...
I want to use a mpcie to usb adapter...
@Ipsw
Thanks, as I understand it should be supported.
I want to use this because its linux based, in theory...
Jackr
Sat Apr 06, 2019 10:49 pm
didnt notice it was the same guy. :D
So You mean the first method or the kernel module chapter ?
Jackr
Wed Apr 10, 2019 10:31 pm
Someone else ?
lpsw
Thu Apr 11, 2019 3:29 am
https://www.quectel.com/UploadImage/Dow ... e_V1.8.pdf
This is what I used in my decision on what I wanted to use in my application.
Sorry I don't have time to google to see if there is more recent info. Maybe you can do that.
PS See 3.3.4 and 3.3.5
Jackr
Mon Apr 22, 2019 8:42 pm
I dont understand what methods do what, which are alternatives and which are optional, and if I can skip all that using raspbian.
DragosIosub
Thu Aug 29, 2019 5:09 pm
Read how to enable USB drivers for EC21/EC25/EG95/EG91/BG96 Quectel modems without kernel/driver compile in my post named "itbrainpower.net modems Raspberry PI howto":
https://itbrainpower.net/a-gsm/itbp-gsm ... -PI-how-to
Dragos
