Student_AJ
School Project Help
Thu Apr 04, 2019 12:47 am
I am a high school student and it is the first time I had ever worked with Raspberry Pi. My team and I were planning on using a MIDI Keyboard to unlock a PC, and we have no clue on to where to start. We did some research and figured out using the Raspberry Pi will be a plausible method for accomplishing this. Here's what we system engineered so far...
1. Use Akai LPK25 Keyboard to send midi messages (or binary) to the Raspberry Pi
2. Raspberry Pi will run a program in Python (the best programming language for us I believe) to convert these midi messages to text
3. Either text will be printed on to the logon screen or the PC automatically unlocks itself
Or we have the RPi check to see if the musical notes are correct no matter the velocity and RPi will run a program unlocking the PC immediately.
We initially came up with this idea of innovation to help people with memory loss of distinct passwords. Music is easier to remember and hard to forget so we incorporated that as our project for the semester.
All help will be greatly appreciated! Please ask any questions that will clear up any information that does not seem clear.
Andyroo
Re: School Project Help
Thu Apr 04, 2019 2:49 am
How about using the Pi zero in USB mode to create a HID (human interface device) that unlocks the PC?
mattmiller
Thu Apr 04, 2019 6:22 am
I played with midi a while ago - this thread might give you some pointers to getting started
viewtopic.php?p=1275176
Thu Apr 04, 2019 6:41 am
Then how would you connect the (USB) MIDI keyboard to the Pi?
It could be done with two Pi zeroes, back to back, connected via wireless, bluetooth, serial or even just a simple GPIO signal to say "Unlock".
One would handle the MIDI keyboard, the other could act as the HID.
incognitum
Thu Apr 04, 2019 10:36 am
Or use a single Pi, let it communicate with the Akai using USB, and with PC through Bluetooth.
There has been prior success letting a Pi pretend it is a Bluetooth keyboard: https://github.com/mlabviet/BL_keyboard_RPI
ejolson
Fri Apr 12, 2019 1:58 am
I thought midi was a fairly simple low speed serial connection. Could the keyboard be connected through appropriate level converters to the serial UART on the GPIO connector?
Fri Apr 12, 2019 4:04 am
Not directly. You would need an interface circuit. Fortunately it wouldn't be that complicated to make one. MIDI is based on a current loop running from 5V via a 220 Ohm resistor. The input should be used to drive an opto-isolator so that the Pi is completely isolated from the keyboard's power circuits. The output (probably not needed in this case) would need a buffer to drive the 5V signal through the resistor. The speed could be an issue as it is an unusual 31250 bps.
B.Goode
Fri Apr 12, 2019 11:23 am
There is a recent blog post on the Raspberry Pi Foundation website that might provide some inspiration: https://www.raspberrypi.org/blog/midi-c ... pberry-pi/
(If you can get the RPi to respond to a midi input and turn on a light, it can't be that different to operate a lock instead... ?)
Student_AJ
Thu Apr 18, 2019 7:57 pm
hi mattmiller,
the project you did is similar to ours. however, I am running into trouble in code where it states: "print pygame.midi.get_device_info(x)."
the terminal highlights "pygame" and says it is invalid syntax.
thanks for the help,
AJ
gordon77
Thu Apr 18, 2019 8:34 pm
If using python3 do you just need some brackets...
print (pygame.midi.get_device_info(x))
mattmiller
Thu Apr 18, 2019 8:52 pm
As @gordon77 points out - I used Python 2 - hopefully it's just the print's that need translating
hippy
Thu Apr 18, 2019 9:08 pm
When a MIDI keyboard has a 5-pin DIN MIDI Out then it is usually trivial to connect that direct to a digital input even if that input won't be compliant with the MIDI specification.
If it's an active output, giving 0V and 5V, just a current limiting resistor will usually work with most micros but for the Pi a resistor ladder to drop 5V to 3V3 would be required. If it's an open collector output then a pull-up tot 3V3 will be required.
As you note, a specification compliant interface would simply be an opto-isolator so not difficult or costly to design or add.
Unfortunately the Akai LPK25 doesn't appear to have a 5-PIN DIN MIDI Out so would require a MIDI USB to 5-Pin DIN adapter, or be connected via USB.
Student_AJ
thanks @gordon77, it works. But another error shows up at the operation "<>". I'm having difficulty finding what that means online.
mattmiller
Thu Apr 18, 2019 9:10 pm
<> means not equal to
I don't program in Python 3 but try replacing with != and see if that works
Student_AJ
Thu Apr 18, 2019 9:11 pm
currently im using usb to connect my akai lpk25 to the rpi3b+, will that be an issue? or do i need the 5-pin din adapter?
Student_AJ
Thu Apr 18, 2019 9:15 pm
thanks so much @mattmiller, the code works great and recognizes my midi keyboard.
I appreciate everyone's efforts in helping my group finish our projects!
AJ
hippy
Thu Apr 18, 2019 9:27 pm
No that's absolutely fine.
The 3B+ cannot connect to the PC as a USB device/gadget so you might as well use the USB to connect to the keyboard as you are doing.
Student_AJ
Thu Apr 18, 2019 9:30 pm
so i attempted the code, it works, thanks to you all especially @mattmiller. but, i don't know where to go one from here. how is the raspberry pi supposed to unlock my laptop once it says "password accepted".
appreciate all help!
sushant_ocv
Fri May 31, 2019 5:26 am
Yes, this suggestion could could be useful here.
sushant_ocv
I like this idea to create Pi zero in USB mode.
