bro55ther
XASH-3D 2019
Thu Mar 21, 2019 3:25 pm
How can I install xash3d in 2019 old tutorials dont work. Thanks!
Gess1t
Re: XASH-3D 2019
Sat Mar 23, 2019 12:03 am
Moonmarch
Re: XASH-3D 2019
Fri May 17, 2019 2:54 pm
There is no available .deb file you can install for RPI, you need to build the program yourself, you can find guides on how to compile xash3d on the RPI in the Raspberry Pi forums or Reddit. To run xash3d, you will need the "valve" folder from a installation of "half-life," which can only be installed on a x86/x64 computer.
Here is what I can tell you about compiling xash3d, you need to compile "half-life sdk" to receive the "hl.so" and "client.so" files, if these files are not compiled, then you can't run xash3d even after compiling the xash3d program, the xash3d program cannot read the "hl.so" file or the "client.so" file that is included in the valve folder.
Return to “Gaming”
