TerryC65
Cannot open nano in boot shell
Sun Mar 10, 2019 12:20 pm
Earlier this week I downloaded and installed the latest Raspbian image from the Downloads page (2018-11-13-raspbian-stretch-full.img) and installed it onto an SD Card for use in a new project. The target device is a Pi Zero but I used my Pi 3 to perform all the updates before plugging the card into the Zero.
As far as my project is concerned, everything is working fine, but when I try to open nano in the initial boot shell, I get:
error opening terminal: unknown
If I open a shell and type nano within the desktop, everything works.
What is going on here? I've always used nano on earlier projects and had no issues as far as I can recall.
scruss
Re: Cannot open nano in boot shell
Sun Mar 10, 2019 1:26 pm
You get that if there's no pseudo-terminal set. nano needs to know the terminal type and size to make up its screen layout, and without that it'll give up.
I don't recall how you're logging in, but if it's through ssh, you'll need ssh -t.
TerryC65
Sun Mar 10, 2019 1:27 pm
This is just a standard login with a monitor and keyboard. (I have set the Pi to boot into a shell.)
TerryC65
Sun Mar 10, 2019 5:42 pm
My local Linux user group answered this.
I set the TERM variable to 'vt220' in env.
I don't know why it's suddenly stopped working though.
scruss
Sun Mar 10, 2019 8:30 pm
Yeah, I'm trying to find where TERM is set. Over serial, it's the getty service. On the console - no idea. It's supposed to have the value linux for the framebuffer console.
TerryC65
Sun Mar 10, 2019 9:02 pm
I initially did it as a shell command, eg:
TERM='vt220'
but that isn't persistent.
Eventually, I added that command to .bashrc, but that clearly isn't the only way.
imaginaryeast
Tue May 14, 2019 4:57 pm
This is completely happening to me as well. What do I type into .bashrc in order to make this change persistent? I tried just adding the language to the bottom of the file and it made my system flicker and was unresponsive.
Thanks,
TerryC65
Thu May 16, 2019 6:48 am
How long ago did you download your copy of Raspbian? I've downloaded it several times since I posted this and not had the problem again. (In fact, I'd forgotten all about it.)
AFAICR, I simply added the command to the bottom of .bashrc, which I assume is what you have done.
imaginaryeast
Fri May 17, 2019 2:39 pm
A few days ago. I did 3 seperate images. About to do a third of "lite" version of stretch and hopefully it works without your fix.
imaginaryeast
Fri May 17, 2019 5:01 pm
The new install I did of stretch lite worked fine. But the 3 installs of the full package with extra stuff had that same issue.
xtal256
Sat Jun 08, 2019 4:00 am
I've got the same issue with a fresh install of Raspbian.
Adding the TERM env var worked, but as others have pointed out it's not persistent.
I doubt adding it to .bashrc is the best way, as .bashrc itself checks for '$TERM', implying that it should be set elsewhere.
