rwclough
Proposal for a small robot controller based on RPi Zero
Tue Feb 12, 2019 7:34 pm
The controller is a shield that plugs into a Raspberry Pi Zero. Its purpose is to control a small wheeled robot.
The shield provides the following features:
- 3 headers for I2C devices such as a SRF08 ultrasound rangefinder,
- 3 channels of ADC for devices such a Sharp IR rangefinder,
- 2 headers for servos (eg pan and tilt to point the above mentioned sensors),
- 2 motor drivers accessed via 2 screw-down blocks,
- 2 connectors for a servo battery and a motor battery,
- an OLED graphic display for debugging purposes or for showing what the Python program is doing while it is controlling the robot.
The Raspberry Pi Zero runs a Python program that communicates with micro-controllers on the shield. The commands/responses that the Python program sends/receives are ASCII strings.
This project could be described in MagPi over a couple of issues: parts list, Python program, etc.
mattmiller
Re: Proposal for a small robot controller based on RPi Zero
Tue Feb 12, 2019 8:11 pm
What's the USP over the myriad other pi robot controller shields and HATs?
mikronauts
Tue Feb 12, 2019 9:00 pm
When the pi0 was introduced, I quickly designed (and produced pcb's) for a Pi Zero form factor robotics hat that was FAR more feature full and powerful than what you are suggesting.
I never brought it to market as the RPF is limiting pi0 sales to such an extent that I would lose a lot of money marketing it.
I even tried contacting the RPF about buying qty.100 0's to bundle with my phat, but was basically ignored. Some told me to buy 0's one at a time, but the shipping kills that.
Unless you are Pimoroni, Adafruit etc (ie a Pi0 reseller) making money on phats for the 0 is basically impossible.
Fortunately other Pi models are different.
rwclough
Tue Feb 12, 2019 9:12 pm
Reply to mattmiller,
I have seen hats that provide a single function. For example, multiple USB ports, multiple servo controllers, DACs, ADCs, graphic displays. My contribution provides all the functions, on one hat, to control a small wheeled robot.
Cheers,
Ron
rwclough
Tue Feb 12, 2019 9:15 pm
Reply to mikronauts,
I’m not in the business of selling PCBs. I’m interested in writing an article for MagPi magazine about building a small robot.
Cheers,
Ron
mattmiller
Tue Feb 12, 2019 10:25 pm
I think your coming to the Pi robot party quite late on
Just as one example (out of many I could post) - the 4Tronix PiConZero
https://www.amazon.co.uk/4tronix-Intell ... B01E8MXQWY
mattmiller
Tue Feb 12, 2019 10:28 pm
I'm sure magpi would be happy to publish another robot building/programming article as that sort of thing is its bread and butter but I don't think there's a need for another product in a crowded market unless it literally makes tea as well :)
Gavinmc42
Tue Feb 12, 2019 11:59 pm
This is one of the better motor driver boards I have seen.
https://www.pololu.com/product/2753
But for me it is missing stuff.
An IMU chip - accel/gyro/compass, i2c connector for addon sensors, some servo 3 pin headers....
Ideally the addon board is about the same price as the Zero, that leaves no room for making money ;)
Too bad the Microbit does not have the Zero footprint, it has most of the stuff needed.
Zero based robotics is still pretty expensive and/or downright ugly.
These grabbed my attention, what could you make with a dozen or so of these?
https://www.adafruit.com/product/3871
Drivers only need to be transistor arrays?
Servos cn be expensive and tricky to program , generally needinga PWM chip
https://www.adafruit.com/?q=servo%20driver
I had thought a Lego compatible motor and driver and Lego shaped servo case would allow for more flexiblity.
I'm dancing on Rainbows.
mattmiller
Wed Feb 13, 2019 11:31 am
Its one of the most basic ones out there
You need to get out more :)
Return to “The MagPi”
