alnaseh
cover options for Pi 3A+ case
Tue Feb 12, 2019 2:48 pm
Pi 3A+ is very nice one and i hope if we can have a cover for the official case to fix the camera on it, in the same way the case for Pi zero. this will include a small cable as well
alnaseh
Re: cover options for Pi 3A+ / Pi4 case
Sat Jul 13, 2019 2:22 pm
I'm raising my voice again here on this request, but now for Pi4. it makes sense to have a custom cover for the official case to support the camera out of the box with custom cable.
Adding PoE hat inside the case (with suitable design for its fan) with the camera makes it more convenient as a home camera.
I believe it is a small addition with a big value
W. H. Heydt
Re: cover options for Pi 3A+ case
Sat Jul 13, 2019 7:15 pm
Actually...given the thermal issues with the Pi4B, what I'd like to see would be aPi4 case top with ventilation holes. Until such a thing appears (and I'm not holding my breath), an electric drill and probably about a 3/16" drill bit should do the job in a few minutes per case.
DavidS
Sat Jul 13, 2019 7:45 pm
For both the RPi 3 series and RPi 4 series I would say just use a stand, that holds the board in a vertical orientation and only contacts at one edge, giving enough space between the board and bottom of the RPi and the bottom of the stand to allow for good air flow. It is easy to throw a design together in OpenScad, slice it and 3D-Print it.
Cooling being an issue in both boards.
That is just my personal view (and what I already do with the RPi 3B and 3B+).
alphanumeric
Sat Jul 13, 2019 8:57 pm
This is what I did, https://1drv.ms/f/s!AjOYwiwlwDtpgtIa6dhTBqnE9W-LcA
Pi 3A+, Pibow Coupe case, Camera mounted to the back side of a cut down difusser mounted on long bolts.
They all run Motion Eye OS, headless over my WIFI. I can do portrait or landscape just by turning the case on its side. Good cooling too.
I bought some camera mounts for the nuts and bolts and just cutout my difusser with a dremel tool until the camera fit in the holes I made for it.
W. H. Heydt
Sat Jul 13, 2019 10:21 pm
Not necessarily a practical approach for all use cases. Plus, not everyone has or has access to, a 3D printer. I've considered getting one, but I don't know where I'd put it and She Who Must Be Obeyed would object.
alnaseh
Sun Jul 14, 2019 4:21 pm
thanks for the suggestion, but it needs tools and not practical as highlighted by Heydt. there are some cases out there (mainly by oneninedesign) but yet not as polish as the official one and not updated with the latest Pi4 (no clue if they have a plan to redesign it raspberrypiplastics.com)
Return to “Off topic discussion”
