Enaud
How to shutdown Pi from Visual Basic 2017 Code
Tue Feb 05, 2019 4:03 am
Hi, I've been searching for how to shutdown my Pi from Visual Basic 2017 code without success.
I have an app I have developed that will run when the Pi boots up and when a specific GPIO pin detects a switch closure I want to shut down the Pi.
I'm reading/writing GPIO pins just fine from VB. My issue is the coding to invoke shutdown.
Does anyone have any experience getting the Pi to shutdown/reboot from a Visual Basic app?
Cheers.
scotty101
Re: How to shutdown Pi from Visual Basic 2017 Code
Tue Feb 05, 2019 1:44 pm
Does this help you?
https://marcominerva.wordpress.com/2016 ... a-uwp-app/
There should be a VB equivalent.
Enaud
Re: How to shutdown Pi from Visual Basic 2017 Code - Solved
Thu Feb 07, 2019 6:36 am
Hi Scotty,
Thanks for the link. I had a little trouble navigating through the Visual Studio 2017 environment. (Haven't been doing VB since version 2008, so I had a bit of a learning curve to tackle.)
Anyway, I got it working!
Here's what I had to do:
Add reference:
Windows IoT Extensions for the UWP
At top of MainPage.xaml.vb:
Imports Windows.System
In my btnShutDown_Click event
ShutdownManager.BeginShutdown(ShutdownKind.Shutdown, TimeSpan.FromSeconds(0))
In my timer event
If activeShutDownpinIn.Read = GpioPinValue.Low Then
'ShutDown the device.
End If
In Package.manifest
xmlns:iot="http://schemas.microsoft.com/appx/manif ... /windows10" (This is in the Package section.)
<iot:Capability Name="systemManagement" /> (This is in the Capabilities section.)
The environment complained about invalid child object but I saw another post that said to ignore it. I did and it worked.!
Thanks for the link! Cheers
