whitetiger
By moving a window, it is dragged to the screen
Mon Jan 14, 2019 11:32 am
In my network I have several PCs Windows, linux and one Raspberry Pi 3B +.
I connect remotely with TeamViewer.
When I move a window on the desktop, this always happens without problems.
When I do it with the Raspberry the very annoying effect is that in the attached image.
I tried to change the resolution and other screen parameters, but the problem remains.
How can I solve it?
Thanks in advance.
Moving in Pi.jpg (83.5 KiB) Viewed 913 times
topguy
Re: By moving a window, it is dragged to the screen
Tue Jan 15, 2019 9:40 am
You should probably ask the Teamviewer people about it...
whitetiger
Tue Jan 15, 2019 9:42 am
But TeamViewer is active on thirty machines (WIN + Linux) all in the same LAN and the problem is only with RaspBerry.
mahjongg
Tue Jan 15, 2019 12:53 pm
Must be a bug in the teamviewer client running on the RPI, a bug not present on the other clients.
DarkPlatinum
Tue Jan 15, 2019 2:05 pm
Use VNC viewer for best results.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
topguy
Tue Jan 15, 2019 3:10 pm
But where did you get/install the TeamViewer service running on the Pi ?
And how did you configure it ?
Tue Jan 15, 2019 3:23 pm
TeamViewer Host is available here:
https://www.teamviewer.com/en/download/linux/
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
topguy
Tue Jan 15, 2019 3:30 pm
You are not whitetiger, but if he got his version from the same place, I feel my suggestion of asking TeamViewer for help still is valid.
Tue Jan 15, 2019 6:51 pm
Of course the OP should ask TeamViewer !
adieu
whitetiger
Fri Jan 18, 2019 10:52 am
I also asked TeamViewer and I'm waiting for an answer from them too.
I downloaded the Host version from their website and installed it in standard mode, without variations.
