safisafo
Accuracy of GPS
Mon Jan 14, 2019 12:58 am
Hi. I'm using the SIM7600E module to take my latitude and longitude, but the result given is located like 30km away (very bad accuracy, like 3º), but it doesn't almost change. I'm running it indoors, is this normal?
topguy
Re: Accuracy of GPS
Mon Jan 14, 2019 10:40 am
Can you link us a datasheet for the product you are using, because none of the modules with that name that turn up in Google actually have a GPS, its a 4G modem.
bensimmo
Re: Accuracy of GPS
Mon Jan 14, 2019 3:15 pm
Something is wrong OR theit is the way you are reading the NMEA coordinates*.
It should get you within 10meters without a problem.. normally after a bit of time.
Apparently some models can have GPS.
https://www.waveshare.com/wiki/SIM7600E-H_4G_HAT
*There are different methods of representing coordinates.
But I should be degrees and minutes iirc
DDMM.MMMMM
Try http://www.hiddenvision.co.uk/ez/ to change to a different system and use that in your map.
Also if anything like the UK and you are sat in the meridian line then watch out for - E & W
pfletch101
Re: Accuracy of GPS
Tue Jan 15, 2019 2:55 pm
I would not bet on this GPS accuracy (or even working at all) when run indoors, which the OP notes is his situation.
bensimmo
Re: Accuracy of GPS
Tue Jan 15, 2019 4:24 pm
If it gives coordinates then it has a lock on a few satellite. So it has a a good radius to work with, maybe not 10 meters, but within 100m no problem. NOT 30km's ...
which sound like a unit mix up on the mapping program.
pfletch101
Re: Accuracy of GPS
Tue Jan 15, 2019 4:44 pm
You may be right - if it is a GPS device. However, the OP also hasn't responded to topguy's implied question, noting (correctly) that the device the OP says he is using is a 4G modem with no GPS capabilities. Whatever he is using to get his location may be returning the location of the first router in his transmission path that admits to its location!
drgeoff
Re: Accuracy of GPS
Tue Jan 15, 2019 5:30 pm
The SIM7600E module does have GPS capability
See https://simcom.ee/modules/lte/sim7600e/ . Under General features "GNSS gpsOne Gen 8B;standalone;assisted,XTRA"
See https://simcom.ee/documents/SIM7600E/SI ... 20V1.1.pdf pages 1 and 5 for mention of GNSS antenna
But does whatever the OP is using have a GPS antenna connected to the SIM7600E?
bensimmo
Re: Accuracy of GPS
Tue Jan 15, 2019 5:37 pm
I posted a link to one, it has GNSS, aka GPS.
I doesn't mean it may not, but await to see.
EDIT , to above post, the Waveshare one is that chipset I linked to.
Also as it GNSS it has GLONASS, Beidou etc like my Ublox8. These connect indoors much better than my ublox6 which can fail to get a lock.
Anyway, back to await feedback.
