jultur
Raspbian stuck on screen with cursor+black screen+yellow lightning during boot
Sun Jan 13, 2019 2:45 pm
I have an issue with my raspberry pi 3 B+ running on Raspbian. Indeed just after trying to set up a 4 inch HDMI LCD screen in the following way :
-Adding these lines in the config.txt
Hdmi_group = 2
Hdmi_mode = 87
Hdmi_cvt 480 800 60 6 0 0 0
Dtoverlay = ads7846 , cs = 1 , penirq = 25 , penirq_pull = 2 , speed = 50000 , keep_vref_on = 0 , swapxy = 0 , pmax = 255 , xohms = 150 , xmin = 200 , xmax = 3900 , ymin = 200 , ymax = 3900
Display_rotate = 3
-git clone https : //github.com/waveshare/LCD-show.git
-and running the file LCD4 - 800x480 - show
At this point the board reboot and since then my problems started :
The boot start correctly until the last line on screen :
Starting Terminate Plymouth Boot Screnn...
After that I'm stuck with that screen :
And the red and green LEDs are blinking.
It's a problem really simillar to this one :
viewtopic.php?t=128307
But no answers are working for me.
Personnaly I think it's a problem with the memory during the installation of the LCD driver but I have no idea how to solve it. I really need to get it working without wiping all the memory, beacause I have really important files for a project inside.
Thank you for the help!
Re: Raspbian stuck on screen with cursor+black screen+yellow lightning during boot
Sun Jan 13, 2019 4:25 pm
Hdmi_group = 2
Hdmi_mode = 87
Display_rotate = 3
The Yellow Warning is under-voltage:
https://www.raspberrypi.org/documentati ... g-icons.md
Use the Official and recommended Power Supply:
https://www.raspberrypi.org/products/ra ... er-supply/
The Waveshare instructions support Raspbian Stretch ?? if it is a genuine Waveshare product then what model ??
https://www.waveshare.com/product/mini- ... splays.htm
adieu
My other Computer is an Asus CS10 ChromeBit running Chrome Operating System.
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Stretch.
jultur
Sun Jan 13, 2019 6:22 pm
Thanks for the answer !
I have also read that this lightning logo can appear due to boot problems. The board is powered by my PC and I used the same configuration with an other board and it was working, that why i'm not sure if it's a supply problem.
And for the screen I'm using this one :
https://www.waveshare.com/product/mini- ... mi-lcd.htm
davidcoton
Sun Jan 13, 2019 9:40 pm
Your PC's USB may be limited to 500mA. The Pi3B+ can draw over twice that.
Get a proper 5V-5V2 2A5 PSU (not a repurposed charger), preferably the "official" 5V1 2A5 PSU which is known to be of good quality.
Make sure the cable, if separate, is adequate -- at least 22AWG and preferanbly 18AWG wires (smaller number is thicker).
Signature retired
