Faruk
Rasbberry pi hang on reboot
Sat Jan 05, 2019 11:11 am
Hello guys. When I reboot my raspberry pi, sometimes my raspberry pi hang. And screen this:
[ OK ] Stopped Login Service.
[ OK ] Started Show Plymouth Reboot Screen.
[ OK ] Stopped Permit User Session.
[ OK ] Deactivated swap /var/swap.
[ OK ] Stopped LSB: Autogenerate and use a swap file.
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped target Remote File Systems (Pre).
[ OK ] Stopped target NFS client services.
What is wrong in here? How fix this error?
vinaypundith
Location: Lexington Park, MD, USA, North America, Earth
Re: Rasbberry pi hang on reboot
Mon Jan 07, 2019 12:25 pm
Please give more detail, like what had been done just before shutdown.
I'm setting up a webpage and email server on a Pi 3B+ running Ubuntu Mate 18.10.
Please read the Unanswered topics section and help with whatever you can!
Faruk
Tue Jan 08, 2019 5:58 am
I tried again now. ı started raspberry pi. Usb flash, wireless dongle and keyboard dongle attached to my Rpi. Also I used vnc server and kitty. Kitty connected with ssh to my Rpi. Usually I use vnc server. I used python idle 3, I did some try codes run. When I saw your post, I tried again and Raspberry show to me this:
 [ OK ] Started Show Plymouth Power Off Screen
Just I did these.
vinaypundith
Tue Jan 08, 2019 10:26 am
That seems normal. Try booting it now. Does it hang on every reboot or just sometimes?
HawaiianPi
Tue Jan 08, 2019 10:37 am
Which model Pi?
What operating system (and version)?
What are you using for a power supply?
Are you booting from SD card or USB?
Faruk
Tue Jan 08, 2019 11:09 am
Just sometimes
Faruk
Tue Jan 08, 2019 11:30 am
Which model Pi?
rpi compute module 3 2015 version 1.0
Operating system is stretch version 4.14.90-v7+
Power supply is 5V 1,5A
I booting from SD card
HawaiianPi
Tue Jan 08, 2019 1:40 pm
1.5A could be a bit low, depending on what else you have attached to the CM3.
Run the system for a while, then before rebooting try the command:
vcgencmd get_throttled
If you get a non-zero result, post it here.
Have you run sudo rpi-update on the system? Because that installs the possibly buggy and unstable testing branch kernel and firmware.
dominic03
Tue Jan 08, 2019 1:53 pm
Which model Pi?
Power supply should be 5V 2.5A for best results. Try running a cpu-itensive app and see if it gives an undervoltage warning. (Get your CPU to 100%. Even if it seems ok at a moderate level, 100% will often kill it if it is undervolted.)
My setup:
Raspberry Pi 3b+ running Raspbian Buster, firmware date July 9 2019 (via PINN)
Kingston 32 GB class 10 (U1) SDHC card
Lexar 16GB flash drive for backups
pi-top 3 with drivers and pi-topHUB 2.0
Faruk
Tue Jan 08, 2019 2:19 pm
result is 0x0. Yes I did rpi-update. Can I fix this or should I use new system?
Tue Jan 08, 2019 2:23 pm
Power supply should be 5V 2.5 A
Not necessarily for a CM3. It depends what it is being used for.
