Sohil.Mehta
RTC time is drifting within one day
Wed Dec 19, 2018 8:58 am
I have built my own Compute Module IO board based on the schematics of CMIO Rev3.0 available online, and added some extra things over it like GPS/GNSS Module, IMU, RTC with a coin cell, etc. The processor that I am using is Compute Module 3 Lite. Since GPS is my only source of getting the actual time, I found this python code online that reads the gps time and writes it to system time:
import os
import sys
import time
from gps import *
print 'Set System Clock to GPS UTC time'
try:
  gpsd = gps(mode=WATCH_ENABLE)
except:
  print 'ERROR: No GPS Present, time not set!!'
  sys.exit()
while True:
  #wait until the next GPSD time tick
  gpsd.next()
  if gpsd.utc != None and gpsd.utc != '':
    #gpsd.utc is formatted like"2015-04-01T17:32:04.000Z"
    #convert it to a form the date -u command will accept: "20140401 17:32:04"
    #use python slice notation [start:end] (where end desired end char + 1)
    #   gpsd.utc[0:4] is "2015"
    #   gpsd.utc[5:7] is "04"
    #   gpsd.utc[8:10] is "01"
    gpsutc = gpsd.utc[0:4] + gpsd.utc[5:7] + gpsd.utc[8:10] + ' ' + gpsd.utc[11:19]
    os.system('sudo date -u --set="%s"' % gpsutc)
    sys.exit()
The RTC I am using is DS1307 and it is backed by a coin cell. The RTC is on I2C-0:
i2cdetect -y 0
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- UU -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Address is 0x68.
Contents of /boot/config.txt (last few lines):
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
dtparam=i2c_vc=on
dtparam=i2c1=on
dtoverlay=uart0,txd0_pin=36,rxd0_pin=37,pin_func=6 #alt2
dtoverlay=uart1,txd1_pin=14,rxd1_pin=15
dtoverlay=i2c0-rtc,ds1307
core_freq=250
enable_uart=1
Contents of /etc/modules:
i2c-bcm2708
i2c-dev
rtc-ds1307
After I got the fix and wrote the correct time to the system clock, this is what I did to disable the fake hardware clock:
sudo apt-get -y remove fake-hwclock
sudo update-rc.d -f fake-hwclock remove
sudo systemctl disable fake-hwclock
And then, ran sudo nano /lib/udev/hwclock-set and comment out these three lines:
#if [ -e /run/systemd/system ] ; then
# exit 0
#fi
And then, I did:
sudo modprobe rtc-ds1307
sudo hwclock -w
to write the correct time to the RTC. Until yesterday, it was all fine. The actual time and the RTC and system time were correct as long as the GPS was on and the fix was present. Today, I disconnected the GPS to see if my RTC and system time is still correct. Turns out, there is a drift of 6 seconds already in a single day compared to the actual time. What should I do to make sure that the RTC and system time is always correct and there is no drift?
Re: RTC time is drifting within one day
Wed Dec 19, 2018 6:11 pm
Is your RTC battery backed? Is the battery dead?
This is a doctor free zone.
drgeoff
Fri Dec 21, 2018 11:18 pm
I'm not 100% understand about what you are saying. If you mean your free-running RTC is off by 6 seconds in 24 hours, that is an error of 70 parts per million. That's not out of the question if you have not calibrated the DS1307 plus crystal combination.
Typically you require a trimmer capacitor to adjust the precise frequency of a crystal oscillator.
You can also periodically (eg once per hour) set the RTC time to the GPS time.
rzusman
Sun Dec 23, 2018 2:20 am
Frankly, the DS1307 accuracy stinks.
Spend the extra money and get the DS3231, which is temperature compensated, and is guaranteed accurate to a a minute or so/year.
http://www.reuk.co.uk/wordpress/accurat ... to-ds1307/
Return to “Compute Module”
