riverajl
How to disable video scaling
Mon Dec 17, 2018 11:58 pm
Hi guys. I am trying to develop a low resolution game in PI 3 B but the image always seems blurry because it is scaled to monitor height.
I have changed the config.txt including:
hdmi_group=1
hdmi_mode=1
but the image continues being scaled.
Is there any way to disable this feature?
José Luiz
Memotech Bill
Re: How to disable video scaling
Wed Dec 19, 2018 7:17 pm
Yes, it can be done. For some options see https://github.com/raspberrypi/firmware/issues/104.
For my own application I did it with code (slightly abreviated):
#include <bcm_host.h>
#include <interface/vmcs_host/vc_vchi_gencmd.h>
static char sSclKer[1024];				//	Remember previous scaling kernel
void no_scaling (void)
static const char sNoInt[] = "scaling_kernel 0 0 0 0 0 0 0 0 1 1 1 1 255 255 255 255 255 255 255 255 1 1 1 1 0 0 0 0 0 0 0 0   1";
VCHI_INSTANCE_T vchi_instance;
VCHI_CONNECTION_T *vchi_connection = NULL;
char buffer[1024];
vcos_init ();
if ( vchi_initialise (&vchi_instance) != 0 )
        fatal ("VCHI initialization failed");
//create a vchi connection
if ( vchi_connect (NULL, 0, vchi_instance) != 0 )
        fatal ("VCHI connection failed");
vc_vchi_gencmd_init (vchi_instance, &vchi_connection, 1);
//	Get previous scaling kernel
if ( vc_gencmd (sSclKer, sizeof (sSclKer), "scaling_kernel") != 0 )
	fatal ("Failed to fetch old scaling kernel");
if ( vc_gencmd (buffer, sizeof (buffer), sNoInt) != 0 )
	fatal ("Failed to set non-interpolation scaling kernel");
    vc_gencmd_stop ();
    //close the vchi connection
    if ( vchi_disconnect (vchi_instance) != 0 )
        fatal ("VCHI disconnect failed");
void restore_scaling (void)
char buffer[1024];
if ( vc_gencmd (buffer, sizeof (buffer), sSclKer) != 0 )
	fatal ("Failed to restore scaling kernel");
    vc_gencmd_stop ();
riverajl
Wed Dec 19, 2018 11:24 pm
Thanks for your answer. It seems that your code is for Linux environment.
I am building my game as a bare metal one.
Is your solution possible for a bare metal one?
José Luiz
Memotech Bill
Thu Dec 20, 2018 10:49 am
From the link I posted:
popcornmix wrote: Not tested, but I've added a config.txt parameter:
scaling_kernel=
Where n is:
SCALERLIB_KERNELS_TYPES_SINC=1,
SCALERLIB_KERNELS_TYPES_SINC_BLACKMAN=2,
SCALERLIB_KERNELS_TYPES_SINC_NO_SIDE_LOBES=3,
SCALERLIB_KERNELS_TYPES_SINC_HALF_FIRST_SIDE_LOBE=4,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING=5,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING_3PI=6,
SCALERLIB_KERNELS_TYPES_SINC_HAMMING_2_5PI=7,
SCALERLIB_KERNELS_TYPES_NEAREST_NEIGHBOUR=8,
(we normally use 6). 8 might be what you want.
I believe the mailbox interface already allows you to force integral scale factors.
riverajl
Thu Dec 20, 2018 11:05 pm
Thank you. It worked with scaling_kernel=8.
Is there some documentation about it or only in the Linux code?
Thanks.
José Luiz
Memotech Bill
Fri Dec 21, 2018 12:55 pm
The documentation is on the GitHub Issue Tracker for the RPi firmware, not in the Linux code. I think it is also documented in the Forums somewhere, although I failed to find it in a quick search when I first saw your question.
Unfortunately, it seems to be missing from the documentation at https://www.raspberrypi.org/documentati ... /README.md. I think not the only command not documented there.
