Fatespinner
Sense Hat Resources
Sun Dec 16, 2018 1:51 am
So I have a Sense hate I'm looking to get heading pith and roll info and have it scroll across the screen. I want to do it based off the joy stick move. up heading, left and right roll, and down pitch ( or something like that)
I can do each thing on it's own but i can't tie them together. wondering if someone can point me in the right direction for some resources to help me.
neilgl
Re: Sense Had Resources
Sun Dec 16, 2018 7:26 pm
Fatespinner
Sun Dec 16, 2018 9:26 pm
I have, i've gotten the stats to display on the computer interface, i'm struggling to figure out how to bind that command to the joystick button
bensimmo
Mon Dec 17, 2018 8:17 am
The joystick documents
https://pythonhosted.org/sense-hat/api/#joystick
Strart up the SenseHAT emulator.
In the examples you will have the menu selection.
Then try and figure out how they are doing it.
They can also be found
https://github.com/RPi-Distro/python-se ... u/examples
Also more examples
https://github.com/RPi-Distro/python-se ... r/examples
Buy this part of the getting started shows you joystick selection.
https://projects.raspberrypi.org/en/pro ... nse-hat/10 did you get that far?
Fatespinner
Wed Dec 19, 2018 2:51 am
So I'm going to start over, i actually ordered a new pi for this and i'm going to take it one step at a time following those links. The python script would show me the info but i couldn't get it to display on the screen or bind it to the button. going to start over and i'll keep you posted.
Fatespinner
Sat Dec 29, 2018 8:06 pm
Finally got everything to work in the emulator.
from sense_hat import SenseHat
sense = SenseHat()
while True:
    orientation = sense.get_orientation()
    pitch = orientation['pitch']
    roll = orientation['roll']
    yaw = orientation['yaw']
    for event in sense.stick.get_events():
    # Check if the joystick was pressed
      if event.action == "pressed":
    # Check which direction
        if event.direction == "up":
          sense.show_message("%.2f " % yaw, scroll_speed=0.10, text_colour=[0, 255, 0])
        if event.direction == "down":
          sense.show_message("%.2f " % pitch, scroll_speed=0.10, text_colour=[0, 255, 0])
        if event.direction == "left":
          sense.show_message("%.2f " % roll, scroll_speed=0.10, text_colour=[0, 255, 0])
        if event.direction == "right":
        if event.direction == "middle":
Now i just need to get it on the pi to see if it will work there.
alphanumeric
Re: Sense Hat Resources
Wed Jan 16, 2019 2:16 pm
I'm struggling a bit to understand what your doing and why your doing it? Curiosity killed the cat, lol.
Anyway doesn't
get the orientation from the IMU?
But then your doing something with the joystick? Displaying the different values depending on which way you move the joystick?
bensimmo
Wed Jan 16, 2019 4:26 pm
alphanumeric, run the program above on your Pi in IDLE3 or Thonny and you'll find out.*
The idea is to select which measurement to display, the pitch, the roll or the orientation. yes all from that sense.get_orientation(), it return a list of all three measurements.
or even Trinket
https://trinket.io/python/b7278e7b57
on trinket use the keyboard arrow keys as the joystick (which are what the joystick on the sensehat actually emulates iirc)
Return to “Astro Pi”
