patriksedin
IR light
Sun Dec 09, 2018 9:18 pm
Hi All!
I am new to this.....
Trying to build a survailance camera with night vision
How can I connect the IR lamp to the PI?
I have a Raspberry PI 3 B+, IR light and a PI NoIR camera
Below are the specifications of the IR piece.
Operating voltage: 3,3 V DC.
Power consumption: 350 mA.
Can I use the on board 3.3V (GPIO) or do I need to do something else?
Regards
Patrik
pcmanbob
Re: IR light
Mon Dec 10, 2018 2:21 pm
Hi.
You cant power the IR lamp directly from a gpio pin ( max 16mA ) and I would not connect it to the 3.3v gpio header power pin either.
Assuming its an IR LED you could power it from the gpio header 5v power pin using a 5.6Ω 1W current limiting resistor in series with the LED, if you want to be able to switch the LED on and off you will need a transistor to do the current switching controlled by a gpio pin
Return to “Camera board”
