gumbi
Using H.264 Intra Refresh Modes
Wed Dec 05, 2018 11:54 pm
I've been trying to get the intra refresh options to work, without much success. Was wondering if anyone else was able to get them to work. Here's the command I'm using:
raspivid -l -o tcp://0.0.0.0:3333 -n -t 0 -md 4 -fps 10 -if cyclic
and on the receiving PC to render the macroblock types:
ffplay -debug vis_mb_type tcp://<RPi IP address>:3333
(Note that FFmpeg older than 4.0 is required, because in 4.0 they removed the vis_mb_type option)
Firmware version:
pi@raspberrypi:~ $ vcgencmd version
Nov  4 2018 16:35:17
Copyright (c) 2012 Broadcom
version ed5baf9520a3c4ca82ba38594b898f0c0446da66 (clean) (release)
The P frame looks like this:
While the I frame looks like this:
(Legend for the colors: https://trac.ffmpeg.org/wiki/Debug/Macr ... blockTypes)
So I guess if cyclic was working, I would expect to see a row or column of red macroblocks sweeping across the frame as the video is playing.
I'm hoping that I could get it to work, since the connection I'm using is lossy and packets could be lost, and unless there's motion in the video, that part of the frame won't be "refreshed" so to speak
Thanks in advance
6by9
Re: Using H.264 Intra Refresh Modes
Thu Dec 06, 2018 12:13 pm
Cyclic refresh mode requires more configuration, and raspivid isn't doing that (there's a commented out line related).
In the MMAL_PARAMETER_VIDEO_INTRA_REFRESH_T structure is cir_mbs. It maps directly to the OMX IL structure OMX_VIDEO_PARAM_INTRAREFRESHTYPE nCirMBs. From the spec: "nCirMBs is the number of consecutive macroblocks to be coded as intra when
cyclic intra-refresh (CIR) is enabled.".
Default I suspect is 0 which will do next to nothing.
The requirement within the codec is ((nCirMBS % mbwidth) == 0) && (nCirMBs > mbwidth). So the commented out line in raspivid.c
         //if (state->intra_refresh_type == MMAL_VIDEO_INTRA_REFRESH_CYCLIC_MROWS)
         //   param.cir_mbs = 10;
probably wants to be
         if (state->intra_refresh_type == MMAL_VIDEO_INTRA_REFRESH_CYCLIC_MROWS || state->intra_refresh_type == MMAL_VIDEO_INTRA_REFRESH_CYCLIC)
            param.cir_mbs = VCOS_ALIGN_UP(state->width, 16) >> 4;
to make it a macroblock row.
6by9
Thu Dec 06, 2018 12:25 pm
Trying that and it works, although not quite in the way I expected. I do see a horizontal bar scrolling down the frame. Drop the frame rate and it becomes more obvious.
What I wasn't expecting was that it still encodes a full I-frame every intra-period. You can set the intra-period to 0 so that it only send a full I-frame at the beginning of the stream and never again. The cyclic refresh will provide an update to all pixels, however no subsequent frame will ever be an IDR frame, so there is no option for seeking in the stream.
Reverting my changes it still seems to work correctly, so perhaps it does take some sensible defaults, but you need to disable the full I-frame.
Return to “Camera board”
