shafayatnabi
OpenMax and AlsaSound
Mon Nov 05, 2018 1:44 pm
When trying to run OpenMax video capture , encoding alongside with alsaaudio capture, OpenMAX Allocate buffer getiing OMX_HardWareError , is there any solution ?
6by9
Re: OpenMax and AlsaSound
Mon Nov 05, 2018 2:11 pm
Please be precise. I'm assuming you mean OMX_ErrorHardware, not OMX_HardWareError.
Does your application work without the ALSA side? There should be minimal interaction between those two subsystems.
Are you sure you haven't run out of gpu memory? Increase gpu_mem in /boot/config.txt.
shafayatnabi
Tue Nov 06, 2018 4:33 am
Yeah I mean OMX_ErrorHardware, My bad, but my application works fine without alsa , is Alsa used gpu_memory , so OpenMax getting OMX_ErrorHardware error ?
robel.sharma
Tue Nov 06, 2018 6:19 am
Hey people,
I am also getting the same error. The snippet I got from the PI OMX follows -
Event status [OMX.broadcom.camera] - state: 1, disable: 4, enable: 0, flush: 0
Changing state 2 for OMX.broadcom.video_encode
Base EventHandlerCallback>>>
ComponentBase::OnEventCmdComplete>>>
Event status [OMX.broadcom.video_encode] - state: 1, disable: 2, enable: 0, flush: 0Timer thread created at 0x5de4b3d0
Audio RTP received: 172
OMX error: Stop Capture: 0x80001009 OMX_ErrorHardware
OMX error: disable port: 0x80001009 OMX_ErrorHardware
Disabling port 73 for OMX.broadcom.cameraAudio RTP received: 172
WaitForChange TIMEOUT!!! current 4, expected 5
OMX.broadcom.camera port 73 lost disable port event(s)
Disabling port 71 for OMX.broadcom.camera
OMX.broadcom.camera port 71 lost disable port event(s)
Disabling port -1 for OMX.broadcom.video_encode
WaitForChange TIMEOUT!!! current 2, expected 4
OMX.broadcom.video_encode port 4294967295 lost disable port event(s)
OMX error: switch state: 0x80001009 OMX_ErrorHardware
Changing state 2 for OMX.broadcom.camera
WaitForChange TIMEOUT!!! current 1, expected 2
OMX.broadcom.camera lost state changed event
OMX.broadcom.video_encode lost state changed event
It never works for me if I keep my G711U stream and H264 stream at the same time. Have not seen this issue only on H264 OMX. Any lights on this will be appreciated.
Thanks,
Robel
Return to “OpenMAX”
