100xyz
Pi 0w usb to LAN failure
Wed Oct 31, 2018 7:00 am
I have a Pi W0 and connected a USB to RJ45 cable, which then connects to LAN. Things were working very well.
Then I created another image. In this one the LAN is not found by the system at all. How would I go about debugging this or narrowing it down.
Thanks.
Cofounder 100-xyz.com
Platform for local information via WiFi
Re: Pi 0w usb to LAN failure
Wed Oct 31, 2018 7:26 am
Did you use the same image file for both cards?
Have you got keyboard and screen access to the Pi? If so, what does lsusb show? (that's lower case LSUSB). It should show if your network device is recognised by Raspbian.
For example, on one of my 0's:
pi@raspi10:~ $ lsusb
Bus 001 Device 004: ID 0fe6:9700 Kontron (Industrial Computer Source / ICS Advent) DM9601 Fast Ethernet Adapter
As you can see, on that Pi I am using a dodgy DM9601 adapter (no hub or keyboard, purely headless).
100xyz
Wed Oct 31, 2018 7:49 am
Used almost the same image. Im changing some dnsmasq configuration, but other than that, its the same.
The wifi comes up, so I am able to ssh into it.
lsusb gives me only one entry:
100xyz
Wed Oct 31, 2018 8:00 am
The image was created in a Raspberry Pi 3 and then used in a Pi 0W. Would that affect it somehow?
100xyz
Wed Oct 31, 2018 8:17 am
Having the following errors in syslog:
Oct 31 02:28:13 100 kernel: [ 1.842957] usb 1-1: device descriptor read/64, error -71
Oct 31 02:28:13 100 kernel: [ 1.963119] Indeed it is in host mode hprt0 = 00001101
Oct 31 02:28:13 100 kernel: [ 2.172999] usb 1-1: new high-speed USB device number 3 using dwc_otg
Oct 31 02:28:13 100 kernel: [ 2.181370] Indeed it is in host mode hprt0 = 00001101
Oct 31 02:28:13 100 kernel: [ 2.402947] usb 1-1: device descriptor read/64, error -71
Oct 31 02:28:13 100 kernel: [ 2.523498] Indeed it is in host mode hprt0 = 00001101
Oct 31 02:28:13 100 kernel: [ 2.732955] usb 1-1: device descriptor read/64, error -71
100xyz
Wed Oct 31, 2018 9:47 pm
Looks like its a hardware failure. The same image works on another Pi0W.
Thanks for looking.
