mrboog13
Need someone to code up a python script for my bluetooth joystick to some servos over pi3
Thu Oct 11, 2018 5:12 am
So I cannot for the life of me figure how to do it myself (i've tried)
I am using the following stuff:
For bluetooth joystick: https://github.com/UbiquityRobotics/bt_joystick
for servos: https://github.com/FRC4564/Maestro
Servo 0 - up/down panning (up down on joystick)
Servo 1 - side to side panning (side to side on joystick)
Servo 2 - A button (pushes servo a direction and holds at 75% of direction until released)
Can anyone help out?
topguy
Re: Need someone to code up a python script for my bluetooth joystick to some servos over pi3
Thu Oct 11, 2018 11:33 am
Its a bit unlikely someone here has exactly that joystick and use Python to program for it.
It would be helpful if you be more specific about what trouble you have with each of the parts of the project:
- 1a: Using the "bt_joystick" github code you linked to.
- 1b : Reading values from the joystick.
- 2a: Using the "maestro" code you linked to.
- 2b: controilling the servos.
- 3: Using values read from the joystick to control servos.
troyw
Thu Oct 11, 2018 12:28 pm
Hello There,
I might be able to help you. please mail me at: troy.cis20@gmail.com and Skype me: cis.troy to discuss more.
Looking forward!
Regards
Troy
NicoleF
Mon Oct 15, 2018 3:11 pm
Greetings!
I am having the skill-set and experience required. Please get in touch.
Waiting for your reply
mahjongg
Mon Oct 15, 2018 3:40 pm
Greetings!
This forum does not allow direct communication between members...!!!
so you won't get a reply this way....
Return to “Wanted”
