shaunakvyas1
Contact: AOL
Bluetooth not working in Raspberry Pi 3B+ with Xubuntu 18.04
Tue Oct 02, 2018 12:39 pm
I am using Raspberry Pi with Xubuntu 18.04 running in it. When I enable the bluetooth using its icon, I am not able to open the bluetooth adaptor for detecting and connecting bluetooth devices.
The
hciconfig -a
command gives following output:
shaunak@Xubuntu-RPi:~$ hciconfig -a
hci0:	Type: Primary  Bus: SDIO
	BD Address: 00:00:00:00:00:00  ACL MTU: 0:0  SCO MTU: 0:0
	DOWN
	RX bytes:0 acl:0 sco:0 events:0 errors:0
	TX bytes:0 acl:0 sco:0 commands:0 errors:0
	Features: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
	Packet type: DM1 DH1 HV1
	Link policy:
	Link mode: SLAVE ACCEPT
The
sudo hciconfig hci0 up
shaunak@Xubuntu-RPi:~$ sudo hciconfig hci0 up
[sudo] password for shaunak:
Can't init device hci0: Input/output error (5)
I referred and applied the solutions given in following links, but there is no result:
1. https://www.raspberrypi.org/forums/view ... p?t=171999
2. https://www.raspberrypi.org/forums/view ... hp?t=96001
Shaunak
A Beautiful Mind
shaunakvyas1
Contact: AOL
Re: Bluetooth not working in Raspberry Pi 3B+
Wed Oct 03, 2018 11:42 am
I also tried few more commands. Here are the results:
shaunak@Xubuntu-RPi:~$ hcitool dev
Devices:  ["Blank Line"]
shaunak@Xubuntu-RPi:~$ bluetoothd
D-Bus setup failed: Connection ":1.59" is not allowed to own the service "org.bluez" due to security policies in the configuration file
[/code]
shaunak@Xubuntu-RPi:~$ bluetoothd -d -n
bluetoothd[2906]: Bluetooth daemon 5.48
bluetoothd[2906]: src/main.c:parse_config() parsing /etc/bluetooth/main.conf
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “DiscoverableTimeout” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “PairableTimeout” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “Privacy” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “Name” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “Class” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “DeviceID” in group “General”
bluetoothd[2906]: src/main.c:parse_config() Key file does not have key “ReverseServiceDiscovery” in group “General”
D-Bus setup failed: Connection ":1.98" is not allowed to own the service "org.bluez" due to security policies in the configuration file
bluetoothd[2906]: Unable to get on D-Bus
shaunak@Xubuntu-RPi:~$ bluetooth -v
bluetooth = on
	DOWN
shaunak@Xubuntu-RPi:~$ hcitool scan
Device is not available: No such device
shaunak@Xubuntu-RPi:~$ sudo hciconfig hci0 reset
shaunak@Xubuntu-RPi:~$ dmesg | grep "Bluetooth"
[   11.188876] Bluetooth: Core ver 2.22
[   11.189007] Bluetooth: HCI device and connection manager initialized
[   11.189033] Bluetooth: HCI socket layer initialized
[   11.189046] Bluetooth: L2CAP socket layer initialized
[   11.189090] Bluetooth: SCO socket layer initialized
[   11.205925] Bluetooth: Generic Bluetooth SDIO driver ver 0.1
[   16.028576] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   16.028586] Bluetooth: BNEP filters: protocol multicast
[   16.028617] Bluetooth: BNEP socket layer initialized
shaunak@Xubuntu-RPi:~$ sudo bluetoothctl
Agent registered
[bluetooth]# scan on
No default controller available
[bluetooth]#
I reinstalled bluez, bluetooth and blueman, but still I am facing the same problem of not being able to detect the on board bluetooth adaptor.
Shaunak
A Beautiful Mind
Douglas6
Wed Oct 03, 2018 1:30 pm
Rather than throwing random Bluetooth commands at it, try this one:
systemctl status hciuart
and post the results.
shaunakvyas1
Contact: AOL
Re: Bluetooth not working in Raspberry Pi 3B+ with Xubuntu 18.04
Thu Oct 04, 2018 4:02 am
@Douglas6
Here is the result:
shaunak@Xubuntu-RPi:~$ systemctl status hciuart
Unit hciuart.service could not be found.
Shaunak
A Beautiful Mind
shaunakvyas1
Contact: AOL
Thu Oct 04, 2018 5:49 am
Voila ! I finally am able to start bluetooth.
Here are the commands:
root@Xubuntu-RPi:/home/shaunak# sudo hciattach /dev/ttyAMA0 bcm43xx 921600
bcm43xx_init
Cannot open directory '/etc/firmware': No such file or directory
Patch not found, continue anyway
Set Controller UART speed to 921600 bit/s
Device setup complete
shaunak@Xubuntu-RPi:~$ sudo systemctl restart bluetooth
Shaunak
A Beautiful Mind
Douglas6
Thu Oct 04, 2018 10:22 am
You might try installing pi-bluetooth.
argo86
Wed Oct 24, 2018 6:29 pm
hello,
this is not my native language
these rows of commands will remove some bluetooth errors and allow you to make a connection with your phone
I hope it will be useful
sudo apt-get update
sudo apt-get upgrade
bluetoothctl -v
sudo apt-get install libusb-dev libdbus-1-dev libbluetooth-dev libglib2.0-dev libudev-dev libical-dev libreadline-dev libsbc-dev libasound2-dev libortp-dev -y
sudo apt-get install pulseaudio-module-bluetooth
sudo apt-get install bluez-obexd
sudo wget www.kernel.org/pub/linux/bluetooth/bluez-5.50.tar.xz
sudo tar xvf bluez-5.50.tar.xz && cd bluez-5.50
sudo ./configure --prefix=/usr --mandir=/usr/share/man --sysconfdir=/etc --localstatedir=/var --enable-experimental
sudo make -j4
sudo make install
sudo nano /etc/systemd/system/dbus-org.bluez.service
ExecStart=/usr/lib/bluetooth/bluetoothd -C
ExecStartPost=/usr/bin/sdptool add SP
sudo nano /etc/bluetooth/main.conf
DisablePlugins = pnat
sudo reboot
bluetoothctl -v
Return to “Other”
