janos1
wifi connect
Wed Sep 19, 2018 3:39 pm
Hi to all.Would like to ask some help,installed raspbian light everything is working (i think) with putty i can log in to pi 192.168.1.3 installed reef-pi and from here i can not see my reef-pi on web browser.Tiped in the address in browser 192.168.1.3 and can not connect. Always connection refuse.That is my second Raspberry the first is working and connected to 192.168.1.2 and i can see on web browser.But my age?i forget how i did at the first time.Any help with that please.Thank you.
DirkS
Re: wifi connect
Wed Sep 19, 2018 4:18 pm
Quick web search shows that reef-pi uses port 8080, so it would be http://192.168.1.3:8080
janos1
Re: wifi connect
Wed Sep 19, 2018 4:28 pm
thank you i try right now
janos1
Re: wifi connect
Wed Sep 19, 2018 4:30 pm
This is what i got.:This site can’t be reached
192.168.1.3 refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
DirkS
Re: wifi connect
Wed Sep 19, 2018 4:31 pm
Are you sure the reef-pi software is running and that web access is activated?
janos1
Re: wifi connect
Wed Sep 19, 2018 4:38 pm
Yes it is running: i did sudo systemctl status reef-pi.service and it is running.And the ip address is 192.168.1.3
janos1
Re: wifi connect
Wed Sep 19, 2018 4:44 pm
My Raspberrypi and reef-pi is running headless,if it is any help.The funny thing is my another pi is running perfect no problem at all.That address is 192.168.1.2 just do not remember how did i install that one.Sorry my age?
DirkS
Re: wifi connect
Wed Sep 19, 2018 6:16 pm
Just saw that reef-pi actually uses port 80 so you should be able to connect with http://192.168.1.3
Maybe you can contact the developer on the reef2reef forum (https://www.reef2reef.com/threads/reef- ... pi.289256/)
janos1
Re: wifi connect
Wed Sep 19, 2018 6:39 pm
Thank you for your replay am in the reef-pi forum just do not understand i can connect Raspberry pi on 192.168.1.3 and can not connect reef-pi on the same address.Now i check reef-pi and there is no http server.What that it means?
DirkS
Re: wifi connect
Wed Sep 19, 2018 6:49 pm
Sorry, no idea. It could be some setting, but I would not know which one
That's why I pointed you to the other forum. Probably best chance if it's related to the application itself.
janos1
Re: wifi connect
Wed Sep 19, 2018 8:28 pm
Thank you for your replay,try to remove and reinstall reef-pi again.
janos1
Re: wifi connect
Thu Sep 20, 2018 9:04 pm
Hi to all.We try lot of thig in the reef-pi forum and the developer find out Raspberry for some reason not open the port 80.I can see IP address,192.168.1.2 but when i try to go there connection error what i got.when i try to connect from Raspberry 0.0.0.0:80 i can connect.But not from outsite from diferent Browser.Anybody could help me with that,how to open the port on Raspberry.Thank you :oops:
