antiriad
Contact: Twitter
Can't manually enable experimental OpenGL driver on "clean" installation
Thu Aug 23, 2018 3:30 pm
I'm trying to get a clean installation of Raspian Stretch with hardware acceleration.
Starting from latest release of Raspbian LITE, I updated everything (apt-get update, dist-upgrade etc.).
I installed Xorg Display Server and Xinit
sudo apt-get install --no-install-recommends xserver-xorg xinit
...then Raspbian Desktop (RPD)
sudo apt-get install raspberrypi-ui-mods
... the experimental OpenGL driver
sudo apt-get install xcompmgr libgl1-mesa-dri
...but when I activate OpenGL driver in raspi-config, I get very low performance on glxgears, as if driver it's not activated (or however as if it's much much slower than default Raspbian image available for download).
So it's seems that something is missing... any help?
THANKS
MORE DETAILS:
- memory split is set to 128Mb
- firmware is updated via rpi-update
- I launched apt-get update / upgrade also after the OpenGL driver activation
- color (or "shading") of glxgears is strangely different than that in the default Raspbian (non-Lite) ISO publicly available
- after compiling chocolate-doom (V3 with SDL2-dev etc.) in both contexts, I get 60fps on default Raspbian (non-Lite) ISO and 1 (one!) FPS on custom Raspbian Lite + RPD + OpenGL driver.
Imperf3kt
Re: Can't manually enable experimental OpenGL driver on "clean" installation
Thu Aug 23, 2018 10:01 pm
Which model Pi are you using?
55:55:44:44:4C
52:4C:52:42:41
antiriad
Contact: Twitter
Fri Aug 24, 2018 5:05 am
Hello, I'm using a Raspberry Pi 3.
antiriad
Contact: Twitter
Fri Aug 24, 2018 11:27 am
Found this old comment by Simon Long...
https://www.raspberrypi.org/blog/anothe ... nt-1252967
Perhaps the reason why the driver is not activated depends on one of these factors...
PeterO
Fri Aug 24, 2018 11:33 am
Maybe , but that is over 2 years ago and many things have changed in that time...... I don't know anything more I'm afraid.
PeterO
antiriad
Contact: Twitter
Fri Aug 24, 2018 12:10 pm
Thank you for your feedback.
Maybe there is a way to forward this to someone of the Staff (or Simon Long himself) without "stalking"? It would be extremely useful to put on a "clean" Raspbian installation with hardware acceleration.
antiriad
Contact: Twitter
Mon Sep 03, 2018 11:50 am
I've done it! 8-)
After enabling the experimental OpenGL driver in raspi-config, manually delete /usr/share/X11/xorg.conf.d/99-fbturbo.conf and reboot.
Return to “Advanced users”
