Frederk
Problems with lightdm test mode
Mon Aug 13, 2018 1:31 pm
If I run
sudo lightdm --test-mode
I get a small black window and I can't do anything.
DirkS
Re: Lightdm test mode not working.
Mon Aug 13, 2018 1:37 pm
Please give more information about your setup...
Such as OS + version, model Pi, how did you install lightdm, etc
Are you sure you need to use sudo?
Frederk
Mon Aug 13, 2018 6:23 pm
I found this post on the Internet and the first method worked for me:
http://ubuntuhandbook.org/index.php/201 ... ntu-14-04/
Frederk
Re: Problems with lightdm test mode
Mon Aug 13, 2018 7:38 pm
It doesn't work most of the time for some reason. I had luck that it worked on my second try. If you know how to make it work every time please tell me.
You also have to give permissions to lightdm to edit the contents of var/lib/lightdm. I just logged into root and did it manually.
Frederk
Mon Aug 13, 2018 7:48 pm
And there is also a problem that the mouse and keyboard don't work.
Frederk
Mon Aug 13, 2018 7:58 pm
This is part of the Debug output when lightdm test mode doesn't work:
[+0.13s] DEBUG: DisplayServer x-1: Waiting for ready signal from X server :1
[+0.13s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.13s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.58s] DEBUG: Process 6797 terminated with signal 11
[+0.58s] DEBUG: DisplayServer x-1: X server stopped
and this is when it works:
[+0.14s] DEBUG: DisplayServer x-1: Waiting for ready signal from X server :1
[+0.14s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.15s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.66s] DEBUG: Got signal 10 from process 6827
[+0.66s] DEBUG: DisplayServer x-1: Got signal from X server :1
Ps: Command for debug mode:
lightdm --test-mode -d
