Nathalia21
Window too big in 3.5 inch display
Mon Jul 23, 2018 4:20 am
I have 3.5 inch touch display in Raspberry Raspbian.
Only problem i have is that some windows like Terminal preferences is too big so i cannot click buttons in bottom of window.
Is there any fix for this?
Imperf3kt
Re: Window too big in 3.5 inch display
Mon Jul 23, 2018 5:04 am
You need to adjust your framebuffer dimensions.
Try adding this to config.txt
framebuffer_width = 320
framebuffer_height = 240
55:55:44:44:4C
52:4C:52:42:41
Nathalia21
Mon Jul 23, 2018 5:56 pm
Thanks. I did that but Terminal preferences window is still too big.
DirkS
Mon Jul 23, 2018 6:01 pm
Try increasing the values. E.g. x1.5 (480 x 360)
Imperf3kt
Mon Jul 23, 2018 9:49 pm
That shouldn't help.
The issue is these small screens are 320*240 and Raspbian is trying to output a resolution designed for 1280*720 or larger- you cannot cram all that data into an area a quarter its size, so you need to tell Raspbian to go even smaller at the framebuffer.
If 320*240 is still too large, then you may not be able to shrink it any more than it already is.
Just checking, but you did save the file and reboot, right?
55:55:44:44:4C
52:4C:52:42:41
DirkS
Tue Jul 24, 2018 1:18 am
320x240 is the normal size of pretty much every 3.5" I have seen so far.
In order to fit larger, fixed sized windows you will have to make the framebuffer larger than that size.
TBH I think that these small screens are useless for displaying standard GUI desktops.
Good for a custom touch interface, though
Imperf3kt
Tue Jul 24, 2018 2:23 am
Oh, my mistake, you are correct, I had it backwards.
More info
viewtopic.php?t=136850#p909750
55:55:44:44:4C
52:4C:52:42:41
Nathalia21
Tue Jul 24, 2018 3:13 am
Yes i saved and rebooted. Screen size is 480x320.
tmw921
Thu May 23, 2019 4:41 am
I want to change the size of windows I have open like the command prompt for instance. I open the command prompt on my 3.5 incher and have to drag it around the shrink it to fit the screen. My desktop is the perfect size I just want the windows I have open to default smaller. Is this how?
tmw921
Thu May 23, 2019 4:45 am
I want to change the size of windows I have open like the command prompt for instance. I open the command prompt on my 3.5 incher and have to drag it around the shrink it to fit the screen. My desktop is the perfect size I just want the windows I have open to default smaller. Is this how? Internet browser and command prompt are to big so far.
W. H. Heydt
Thu May 23, 2019 5:17 am
It won't really help...but the same problems occur with the RPF 7" screen.
klricks
Thu May 23, 2019 1:00 pm
For lxterminal:
[Edit] --> [Preferences] --> [Display]
Change Default Window Size then exit and restart lxterminal
For Browser:
chromium-browser --window-size=600,400
Adjust size to fit your screen
