EasyComp Zeeland
Some official RPI 7" touchscreen resolution issues with lineage
Thu Jul 05, 2018 2:01 pm
Hi there,
First of all im completely new to this.. I bought a pi 3 b + with a 7 inch touchscreen to create a car pc.
I found the kodi one but had no luck due to te fact that it's not updated for the model 3
Q1: Is there an update? if yes please provide me an img.
So I flashed linage and wanted to go from there, I't works fine on my computer monitor using hdmi. But when I connect the pi to the touch screen, the screen is of set to the left
Q2: how can I set te correct resolution?
<a href="https://ibb.co/d8bZxJ"><img src="https://preview.ibb.co/iXg1cJ/IMG_1495.jpg" alt="IMG_1495" border="0"></a>
https://preview.ibb.co/iXg1cJ/IMG_1495.jpg ( sorry for the glossy mirror)
Thank you
DirkS
Re: Some official RPI 7" touchscreen resolution issues with linage
Wed Jul 11, 2018 1:13 pm
The kodi what? Kodi is a multimedia application, not an OS or distro.
Whether it works on a pi3 depends on the OS on which it is installed.
So what OS + version do you use?
Q
As mentioned: no update needed. Install e.g. OSMC or LibreElec
What is linage? A distro for the Pi?
procount
Wed Jul 11, 2018 2:14 pm
Lineage is a version of Android.
PINN can install Lineage and there is an option to configure it for the RPF 7" touchscreen.
So have a look in https://sourceforge.net/projects/pinn/files/os/lineage/ at the files:
lineage_-_touchscreen_boot_lin.txt
lineage_-_touchscreen_system_lin.txt
To see what configuration is needed to use LineageOS on the RPF 7" touchscreen.
EasyComp Zeeland
Thu Jul 12, 2018 11:36 am
So what OS + version do you use? NVM im not new to XBMC or Kodi as we call it today! it works fine on Raspbian ;)
Q
What is linage? A distro for the Pi? LINAGE IS ANDROID
EasyComp Zeeland
Thu Jul 12, 2018 11:37 am
Thanks I found an img from someone who created another version of android for the RPI which works well but, I decided to use Raspbian with Kodi
DirkS
Thu Jul 12, 2018 2:50 pm
Well, it would make it a bit easier for potential helpers if you get the spelling right...
And you don't have to shout; my hearing is not that bad.
De Groeten
mahjongg
Thu Jul 12, 2018 5:28 pm
Moved thread to android, and repaired the spelling mistake in the original subject line, linage to lineage.
If I may say so, don't use Android on a PI, use Raspbian, the version of KODI for raspbian (OSMC or LIBRELEC) works fine on a PI.
Also ask just one question per thread.
EasyComp Zeeland
Sun Jul 29, 2018 9:12 am
Thanks im using Raspbian now. how can I close this topic?
gordon77
Re: Some official RPI 7" touchscreen resolution issues with lineage
Sun Jul 29, 2018 9:57 am
Just edit the title to say [SOLVED]
Return to “Android”
