waayne
[VNC] Cannot currently show the dekstop
Mon Jun 25, 2018 9:46 pm
Hey,
I have a problem with my Pi 3+. I activated the VNC server and tried to connect to it on my tablet via the VNCViewer app.
But when I am connected to it there is an error (see attachment).
What can I do to fix that?
klricks
Re: [VNC] Cannot currently show the dekstop
Tue Jun 26, 2018 1:23 am
Hey,
The RPi must be set to boot to desktop (service mode).
If a HDMI monitor is not attached then you need to specify a screen resolution in config.txt
Use GUI config tool or sudo raspi-config to do that.
If not booting to desktop then you need to use virtual mode. (Run vncserver from the command line).
coldsprite
Thu Jul 05, 2018 9:27 pm
I have same problem.
I enabled service mode desktop auto login, and default resolution.
Still see same "Cannot currently show the desktop" error on VNC.
coldsprite
Thu Jul 05, 2018 9:29 pm
I have the same problem.
Already tried the recommendation, still same error.
klricks
Thu Jul 05, 2018 9:38 pm
Do not use default resolution. Choose something else.
jkellogg11
Sun Jul 08, 2018 11:34 pm
You need to install a window manager.
Check out this post.
viewtopic.php?f=66&t=133691
My .xsession-errors file showed this. After installing LXDE I could login.
root@raspberrypi:~# cat .xsession-errors
Xsession: X session started for root at Wed 18 Apr 13:50:07 UTC 2018
Xsession: unable to start X session --- no "/root/.xsession" file, no
"/root/.Xsession" file, no session managers, no window managers, and no
terminal emulators found; aborting.
olafvandekuijt
Mon Jul 09, 2018 6:49 am
I had the same problem.
After changing the resolution to the highest it was solved (sudo raspi-config)
Olaf
pk_rulz
Fri Aug 31, 2018 9:54 am
If everything was working fine and it stopped suddenly then there is possibility that you might have run out of space on the SD card.
I am listing it down to help someone who have such a problem
The following thread should help you to fix that issue
https://www.raspberrypi.org/forums/view ... hp?t=71520
In a nutshell
If you can connect over ssh, this should show you if your /dev/root is full
df -h
If it is, this should help you locate the culprit folder/file. Remove it and vnc should work fine.
sudo du -xh / | grep -P "G\t"
For more advanced options the thread link at the stop should help
demian
Thu Oct 04, 2018 7:09 am
In my case...
I installed lxsession(sudo apt-get install lxsession)
, then work OK.
nikitakaps
Fri May 24, 2019 3:47 pm
I tried everything mentioned in this thread, but nothing worked. What helped me was deleting the /home/pi/.profile using sudo rm .profile
After rebooting I was automatically logged in and everything worked as before. Hope this helps!
Anantasak
Sun Jun 09, 2019 7:37 am
For some case:
Found that problem cause by lxsession file damage. Try PD by running lxsession and find out which package broken then reinstall specific package.
pi@raspberrypi:~ $ lxsession
lxsession: error while loading shared libraries: /usr/lib/arm-linux-gnueabihf/libgtk-x11-2.0.so.0: nonzero padding in e_ident
Fixed by checking md5 libgtk-x11-2.0.so.0 a.k.a libgtk-x11-2.0.so.0.2400.31
pi@raspberrypi:/usr/lib/arm-linux-gnueabihf $ md5sum libgtk-x11-2.0.so.0.2400.31
845a355f212cfb3ac3e9cb6926002615 libgtk-x11-2.0.so.0.2400.31
then rerun install package
sudo apt-get install --reinstall libgtk2.0-0
to resolved lxsession
pi@raspberrypi:/usr/lib/arm-linux-gnueabihf $ lxsession
** Message: main.vala:102: Session is (null)
** Message: main.vala:103: DE is (null)
** Message: main.vala:107: No session set, fallback to LXDE session
** Message: main.vala:113: No desktop environnement set, fallback to LXDE
RottenRonnie
Fri Jun 14, 2019 4:45 pm
I used these steps to get the RealVNC server to work after reading the posts above:
(Note that resetting the max resolution in raspi-config had no effect and I was still seeing the error message.)
ron@raspberrypi:~ $ cat .xsession-errors
The error that I saw:
/usr/bin/x-session-manager: 33: exec: /usr/bin/lxsession: not found
ron@raspberrypi:~ $ ls /usr/share/xsessions
lightdm-xsession.desktop  openbox.desktop
ron@raspberrypi:~ $ cat /usr/share/xsessions/lightdm-xsession.desktop
[Desktop Entry]
Version=1.0
Name=Default Xsession
Exec=default
Icon=
Type=Application
ron@raspberrypi:~ $ sudo apt-get install --reinstall lxsession
Success!!! I'm currently logged into the regular pixel desktop. :mrgreen:
macd2point0
Wed Jun 26, 2019 2:35 am
Changing the resolution worked for me. That's all i got.
Andyroo
Wed Jun 26, 2019 2:19 pm
N Buster it seems that you need to set the resolution before using VNC either by the GUI or command line raspi-config.
SimUK
Wed Jun 26, 2019 2:23 pm
seandex
Thu Jun 27, 2019 7:46 am
Hey,
Where is the example for the config.txt?
Man in a van
Thu Jun 27, 2019 10:51 am
Hey,
sudo raspi-config
Select 7 Advanced Operations
Select 5 Resolution
Andyroo
Thu Jun 27, 2019 11:27 am
The entries in config.txt are three lines
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=35
But the values differ depending on the mode and are set by lines 1539 onwards of raspi-config (as of the time of this posting).
BUT it is getting more complex with additions for the Pi 4 (HDMI vs Composite) so I would just follow Man in a vans process above
I cannot remember if the GUI version of the configuration tool has resolution controls and the Pi computers I can get to at the mo are running Lite.
Shad0w1and
Fri Jul 05, 2019 12:09 am
sudo raspi-config
Select 5 Resolution
Thanks, this worked for me!
tom408881465
Thu Jul 25, 2019 3:06 am
Hi
I changed Boot Options, set boot into a desktop ,it was solved.
gufronra
Thu Aug 29, 2019 1:10 am
I had the same problem. just reboot your raspberry (don't close vnc session that show black screen "Cannot currently show the desktop") and wait a minute till raspberry full loaded the desktop :D
The German
Sun Sep 08, 2019 11:35 pm
I could not switch away from GNOME to KDE or another desktop, the automatic logon did not work anymore and VNC never worked after the initial installation and updates. I like to tinker, but "Buster" is a piece of crap that should not have been released with all the bugs and incompatibilities. The PI 4 is pretty much useless to me as there is no real compatible and stable OS. Disappointing.
