willywillywily0
Wii video capture/streaming driver issue
Sat Jun 09, 2018 9:24 pm
I am trying to make a device that i could just turn on, press a button and live stream to twitch from the raspberry pi
the idea for this build came from this youtube video from someone who made a similar project: https://www.youtube.com/watch?v=ob-V1xI7c8I and this video about how he made it: https://www.youtube.com/watch?v=FF4ToiF ... dex=2&t=0s
essentially i want to make that or something like that only using composite input instead of hdmi so i can stream from my wii or gamecube or other older systems.
I have a usb composite capture card but i cant get it to work. This is what the output is when i use lsusb in terminal:
pi@raspberrypi:~ $ lsusb
Bus 001 Device 063: ID 1c88:0007 Somagic, Inc. SMI Grabber (EasyCAP DC60+ clone) (no firmware) [SMI-2021CBE]
Bus 001 Device 062: ID 05ac:021d Apple, Inc. Aluminum Mini Keyboard (ANSI)
Bus 001 Device 061: ID 05ac:1005 Apple, Inc.
Bus 001 Device 053: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 052: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
pi@raspberrypi:~ $
I've been searching for hours trying to figure out how to make it work and this is probably the most promising thing that I found: viewtopic.php?t=64077 but i have no idea what to actually do with any of it, im a toal beginner with linux stuff so any help at all would be greatly appreciated
Rodney_Rhodes
Re: Wii video capture/streaming driver issue
Tue Jul 03, 2018 9:08 am
Is it really work friend?
byneheh
Sat Sep 08, 2018 11:33 am
essentially i want to make that or something like that only using composite input instead of hdmi so i can stream from my wii or gamecube or other older systems. Maybe I have to use some patcher
pi@raspberrypi:~ $
I've been searching for hours trying to figure out how to make it work and this is probably the most promising thing that I found: https://www.raspberrypi.org/forums/view ... hp?t=64077 but i have no idea what to actually do with any of it, im a toal beginner with linux stuff so any help at all would be greatly appreciated
Is this really working? can We develop something similar but for nintendo switch?
rahulyyadav
Fri Sep 28, 2018 12:34 pm
Someone please give an update whether it is working.
sherylbrock7
Fri Jan 11, 2019 8:15 pm
Is this only for Steam? Is there a way to configure emulators to stream to my Retropie box? So if I want to play N64, Saturn, Wii, Wii U, PS3, etc that my PC can run but the Pi can't
aptoide ios
rossgellen00
Wed Apr 03, 2019 10:35 am
avensis wrote:
Sat Oct 27, 2018 12:25 am
Does it really work? I really wanna try it :roll:
________________________________________________________________________________________________
ShowBox Tutuapp nox
Already it and working great for me.
Return to “Gaming”
