scotty101
Re: Fortnite
Wed Feb 20, 2019 9:57 am
Imperf3kt wrote:
Wed Feb 20, 2019 7:51 am
The Pi, cannot be compared to it because it is ARM based, with 1GB of RAM and no dedicated GPU.
Is that true? I'm pretty sure that the Pi's SOC is mainly GPU with a ARM CPU bolted on.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Re: Fortnite
Wed Feb 20, 2019 12:00 pm
VideoCore is a low-power mobile multimedia processor
https://en.wikipedia.org/wiki/VideoCore
adieu
My other Computer is an Asus CS10 ChromeBit
https://www.asus.com/uk/Mini-PCs/Chromebit-CS10
calvinsteel95
Re: Fortnite
Fri Feb 22, 2019 7:31 am
jamesh wrote:
Mon May 21, 2018 9:49 am
No, I don't believe so. Even if it could be run, it would struggle to run fast enough, the GPU is probably not good enough.
You're right, performance issue will raise.
frank_richard
Re: Fortnite
Thu Mar 28, 2019 7:21 am
RPI is not capable to play game like fortnite, because it requires a lot of GPU, so PC or console are capable of playing them.
DonaldS
Contact: Twitter
Re: Fortnite
Thu Mar 28, 2019 12:01 pm
It won't work. Why technically it will but you won't be able to play. You need a lot of GPU. Internet speed if we consider optimal still it won't help you at all.
quartzexpress
Re: Fortnite
Mon Apr 15, 2019 1:54 pm
use steam link on raspbian
Return to “Gaming”
