KlSchlitzohr
Ubuntu Mate booting problem
Tue Apr 03, 2018 8:41 am
I'm tried to install Ubuntu mate to my Raspberry Pi 3b+.
I put the SD Crad into the raspberry Pi if I'm booting I'm get an rainbow screen.
I search a long time but I didn't found an fix.
Sry for my bad englich
Thanks for Helping
Using Raspberry pi 3b+
Crazyhead
Re: Ubuntu Mate booting problem
Tue Apr 03, 2018 9:39 am
viewtopic.php?f=63&t=208538
I guess you didnt search long enough
Tue Apr 03, 2018 5:48 pm
Thanks for Helping
5 pages......
adieu
HP Envy 4500 Wireless Printer supported by HPLIP software in Raspbian Buster.
Raspberry Pi Model 2B v1.1
KlSchlitzohr
Tue Apr 03, 2018 5:53 pm
Thats really great 5 pages
And I'm not really good in englich.
I'll will try to understand it.
It should be nice if somebody can wirite a short easy summery
B.Goode
Tue Apr 03, 2018 5:57 pm
The version of Ubuntu Mate that can be downloaded from https://ubuntu-mate.org/raspberry-pi/ is not compatible with your RPi Model 3B+.
MaxVMH
Tue Apr 03, 2018 6:21 pm
If you can't figure out how to do it, I made images of Ubuntu Mate ready for Raspberry Pi 3B+
Here are the torrents:
Webserver stack: 2x Pi 3B | 1x Pi 3B+ ||| Pi Zero W for fooling around
Working on a soccer prediction web app:
https://github.com/MaxVMH/mijnscore
Attempt at writing up-to-date tutorials on making a Raspberry Pi webserver:
http://blog.mijnscore.be/
KlSchlitzohr
Tue Apr 03, 2018 6:59 pm
I have no torrent client
KlSchlitzohr
Fri Apr 06, 2018 8:11 am
Let me know if you don't have a torrent client, then I'll send you the direct download links in a personal message.
It worked
Ausberry
Tue Aug 21, 2018 12:30 pm
@MaxVMH Thank you for posting your Ubuntu disc image. Can I ask why it's so large? Over 7 GB? Just curious what I would be installing. I too want Ubuntu on a Pi 3 B+. Cheers!
MaxVMH
Mon Sep 03, 2018 10:14 pm
That's the size of the flash drive I used to make the image, I didn't shrink the image afterwards - so it's basically 4GB 'space' on top of Ubuntu Mate, nothing to be worried about ;)
Consider dropping a note on the Ubuntu MATE forums for official support - that way they know there's demand 8-)
dodoms
Thu Sep 06, 2018 11:39 am
Hey mate, can you send a direct download link?
Thu Sep 06, 2018 12:17 pm
You what ? just click on the text highlighted in red :roll:
adieu
Koia
Sun Sep 09, 2018 3:22 pm
I downloaded your SD care file for 3B+ from the torrent link above. It loads fine on a 3B card but not on my 3B+.
Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000004 ... on first line.
Later:Hardware name BCM2708
Any help?
KlSchlitzohr
Wed Sep 19, 2018 4:49 pm
Hello
I had no problems With this download.
All worked
I have No Idear
soe ye htet
Tue Nov 06, 2018 4:45 am
Hello So sorry. I cannot download from utorrent file. If it is possible, i want to get direct link from personal message.
MaxVMH
Fri Nov 09, 2018 6:08 pm
The torrent should still work but I stopped hosting the files. Ubuntu Mate 18.04 and 18.10 were released and I feel it would be of more use to the overall community if people asked for images on their forums or contributed to an official release instead of relying on old hacked together images of a distro that is over 2 years old.
https://ubuntu-mate.community
Alternatively, you can try making your own image based on Ubuntu Mate 16.04:
Copy the following files from Raspbian to Ubuntu Mate:
For Booting: copy bootcode.bin, fixup.dat, fixup_x.dat , start.elf, start_x.elf, bcm2710-rpi-3-b-plus.dtb and kernel7.img
For keyboard/mouse: copy /lib/modules/4.9.80-v7+ (root partition)
For network: copy the contents of /lib/firmware/brcm/ (root partition)
If you want to boot from USB:
edit cmdline.txt, change root=/dev/mmcblk0p2 to root=/dev/sda2 (boot partition)
edit etc/fstab, change/dev/mmcblk0p2 to sda2 and /dev/mmcblk0p1 to sda1 (root partition)
Bonus
After your first boot, enable wifi:
sudo rfkill unblock wifi
And then reboot:
sudo reboot
More information: viewtopic.php?f=56&t=208538
Upgrade Ubuntu Mate 16.04 to Ubuntu Mate 18.04: viewtopic.php?f=56&t=223749&p=1371614
code_exec
Sun Nov 11, 2018 10:06 am
I found this guide on the Ubuntu MATE forums:
https://ubuntu-mate.community/t/adaptin ... model-b-3b
Ubuntu 18.04 LTS desktop images for the Raspberry Pi 3.
https://github.com/CodeExecution/Ubuntu-ARM64-RPi
Return to “Other”
