PhilE wrote: ↑Mon Apr 16, 2018 8:11 am
Thank you to everybody who is running such exhaustive tests. Our priority is to increase our stock of failing boards beyond the one that we have (there are three more inbound).
If anyone has a board that fails "sudo MEMTESTER_TEST_MASK=0x1000 memtester 128M" in a few minutes
with the default settings (no sdram_freq, arm_freq, over_voltage* etc.) who hasn't already PMd or emailed me (
phil@raspberrypi.org), especially if you are in the UK, then please get in touch.
For everybody else, I suggest you fall back to "arm_freq=1200" and "sdram_freq=450" and wait for an update. With these settings your 3B+ should still be quicker under a sustained heavy workload than a 3B without a heatsink due to better heat spreading.
Tested the command "sudo MEMTESTER_TEST_MASK=0x1000 memtester 128M" some times and it froze every time at:
"Bit Flip : testing 85"
"Bit Flip : testing 165"
Had to hard boot every time, this is the complete report for the third time. if froze at "Bit Flip: testing 11"
.***. Monday, 16 April 2018, 11:43:47 am UTC
***** Linux 4.14.30-v7+ armv7l GNU/Linux
|*| Filesystem Size Used Avail Use% Mounted on
|*| /dev/root 15G 7.6G 6.3G 55% /
..|*|.. Uptime.............: 0 days, 00h00m47s
.*** * ***. Memory.............: 549312kB (Free) / 766776kB (Total)
*******@@** Running Processes..: 113
`*****@@**' IP Address.........: 192.168.1.93
`*******' Temperature........: CPU: 52°C/125°F GPU: 51°C/123°F
`"""' The RetroPie Project,
https://retropie.org.uk
pi@retropie:~ $ vcgencmd get_config int
arm_freq=1400
audio_pwm_mode=514
config_hdmi_boost=5
core_freq=400
desired_osc_freq=0x33e140
desired_osc_freq_boost=0x3c45b0
disable_commandline_tags=2
disable_l2cache=1
display_hdmi_rotate=-1
display_lcd_rotate=-1
force_eeprom_read=1
force_pwm_open=1
framebuffer_ignore_alpha=1
framebuffer_swap=1
gpu_freq=300
hdmi_force_cec_address=65535
init_uart_clock=0x2dc6c00
lcd_framerate=60
over_voltage_avs=37500
over_voltage_avs_boost=0x23186
over_voltage_sdram_p=2
overscan_scale=1
pause_burst_frames=1
program_serial_random=1
sdram_freq=500
sdram_schmoo=0x2000020
pi@retropie:~ $ sudo MEMTESTER_TEST_MASK=0x1000 memtester 128M
memtester version 4.3.0 (32-bit)
Copyright (C) 2001-2012 Charles Cazabon.
Licensed under the GNU General Public License version 2 (only).
pagesize is 4096
pagesizemask is 0xfffff000
using testmask 0x1000
want 128MB (134217728 bytes)
got 128MB (134217728 bytes), trying mlock ...locked.
Loop 1:
Stuck Address : ok
Bit Flip : testing 11
I will try now the same command with the 1200 and 450 values for arm_freq and sdram_freq.
